CGT 5.2.15 - module compilation is incredibly long
Other Parts Discussed in Thread: SHA-256
the compilation of a module that implements the SHA-256 algorithm takes an incredibly long time with CGT 5.2.15. The same source code could be compiled within seconds when using CGT 6.4.1 or GCC (and x86 as a target).
With CGT 5.2.15, the compilation is finished after cca 2 hours when the algorithm has been wrapped in a for-cycle. When the alorithm was fully unrolled, the compilation didn't finish in 30 hours - then I had to turn off the computer.
The code follows:
 * @file
 * @brief               Basic types definitions
 * @par "File:"         types.h
 * @par "Charset:"      UTF-8
// EC1 H1 Protection against multiple header inclusion
#ifndef TYPES_H
#define TYPES_H
// EC1 H1.1 System headers inclusions
// EC1 H1.2 User headers inclusions
// EC1 H2 Global symbolic constants definitions
#if !defined(LITTLE_ENDIAN)
#  define LITTLE_ENDIAN (0x3412u)
#endif
#if !defined(BIG_ENDIAN)
#  define BIG_ENDIAN    (0x1234u)
#endif
#if !defined(BYTE_ORDER)
#  if defined(__TMS320C2000__)
#    define BYTE_ORDER LITTLE_ENDIAN
#  endif
#endif
// EC1 H3 Global parametrized macros definitions
// EC1 H4 Global types definitions
typedef unsigned       int    U16;      /**< Unsigned, 16-bits wide number */
typedef unsigned long  int    U32;      /**< Unsigned, 32-bits wide number */
// EC1 H5 Global variables declarations
// EC1 H6 Global inline functions definitions
// EC1 H7 Global functions prototypes
#endif
 * @file
 * @brief               SHA256 implementation
 * @par "File:"         sha256.h
#ifndef SHA256_H
#define SHA256_H
#include <limits.h>     // CHAR_BIT
#include <stdlib.h>     // size_t
#include "types.h"
#define SHA256_HASH_WORDS        (8u)
#define SHA256_BUFFER_LEN       (16u)
#define SHA256_BUFFER_LEN_BYTE  ((SHA256_BUFFER_LEN * sizeof(U32)) * ((size_t) CHAR_BIT / 8u))
#define SHA256_DATA_LEN_BYTE     (8u)   // data length is stored as a 64-bit big endian word
 * @brief SHA-256 context
typedef struct {
  U32 hash[SHA256_HASH_WORDS];
  U32 buffer[SHA256_BUFFER_LEN];
  U32 total_len;
  U32 buffer_ptr;
} SHA256_CONTEXT;
 * @brief Initializes SHA-256 context
 * @param[out] Pointer to SHA256_CONTEXT
void SHA256_init(SHA256_CONTEXT *pSC);
 * @brief Processes input data
 * @param[in,out] pSC   Pointer to SHA256_CONTEXT
 * @param[in]     pData Pointer to data
 * @param[in]     len   Length of data as a number of octets
void SHA256_update(SHA256_CONTEXT *pSC, const void *pData, U32 len);
 * @brief Finishes the SHA256 calculation.
void SHA256_finalize(SHA256_CONTEXT *pSC);
#endif
 * @file
 * @par "File:"         sha256.c
// EC1 C0 System headers inclusions
#if !defined(__TMS320C2000__)
#include <string.h>     // memcpy
#endif
// EC1 C1 User headers inclusions
#include "sha256.h"
#include "types.h"
// EC1 C2 Private symbolic constants definitions
#define SHA256_BLOCK_SIZE_BITS (512u)
#define SHA256_ROUNDS           (64u)
#define H0      (0x6A09E667u)
#define H1      (0xBB67AE85u)
#define H2      (0x3C6EF372u)
#define H3      (0xA54FF53Au)
#define H4      (0x510E527Fu)
#define H5      (0x9B05688Cu)
#define H6      (0x1F83D9ABu)
#define H7      (0x5BE0CD19u)
// EC1 C3 Private parametrized macros definitions
#define SHR32(x, c) ((U32)(x) >> (c))
#define ROTR32(x, c) (((U32)(x) >> (c)) | (U32)((U32)(x) << (((size_t) sizeof(U32) * CHAR_BIT) - (c))))
#define Ch(x, y, z) (((x) & (y)) ^ ((~(x)) & (z)))
#define Maj(x, y, z) (((x) & (y)) ^ ((x) & (z)) ^ ((y) & (z)))
#define SIGMA0(x) (ROTR32((x),  2u) ^ ROTR32((x), 13u) ^ ROTR32((x), 22u))
#define SIGMA1(x) (ROTR32((x),  6u) ^ ROTR32((x), 11u) ^ ROTR32((x), 25u))
#define sigma0(x) (ROTR32((x),  7u) ^ ROTR32((x), 18u) ^ SHR32((x),  3u))
#define sigma1(x) (ROTR32((x), 17u) ^ ROTR32((x), 19u) ^ SHR32((x), 10u))
#define M(w0, w14, w9, w1) w0 = sigma1(w14) + (w9) + sigma0(w1) + (w0);
#define EXPAND \
  M(w0 , w14, w9 , w1 ) \
  M(w1 , w15, w10, w2 ) \
  M(w2 , w0 , w11, w3 ) \
  M(w3 , w1 , w12, w4 ) \
  M(w4 , w2 , w13, w5 ) \
  M(w5 , w3 , w14, w6 ) \
  M(w6 , w4 , w15, w7 ) \
  M(w7 , w5 , w0 , w8 ) \
  M(w8 , w6 , w1 , w9 ) \
  M(w9 , w7 , w2 , w10) \
  M(w10, w8 , w3 , w11) \
  M(w11, w9 , w4 , w12) \
  M(w12, w10, w5 , w13) \
  M(w13, w11, w6 , w14) \
  M(w14, w12, w7 , w15) \
  M(w15, w13, w8 , w0 )
#define F(w) \
  T1 = h + SIGMA1(e) + Ch(e, f, g) + K[jj] + (w); \
  T2 = SIGMA0(a) + Maj(a, b, c); \
  h = g; \
  g = f; \
  f = e; \
  e = d + T1; \
  d = c; \
  c = b; \
  b = a; \
  a = T1 + T2; \
  jj++;
// EC1 C4 Private types definitions
// EC1 C5A Global variables definitions
// EC1 C5B Private variables definitions
static const U32 padding[SHA256_BLOCK_SIZE_BITS / (sizeof(U32) * CHAR_BIT)] = {
#if (BYTE_ORDER == BIG_ENDIAN)
  0x80000000u, 0x00000000u, 0x00000000u, 0x00000000u,
  0x00000000u, 0x00000000u, 0x00000000u, 0x00000000u,
#else
  0x00000080u, 0x00000000u, 0x00000000u, 0x00000000u,
#endif
static const U32 K[SHA256_ROUNDS] = {
  0x428A2F98u, 0x71374491u, 0xB5C0FBCFu, 0xE9B5DBA5u,
  0x3956C25Bu, 0x59F111F1u, 0x923F82A4u, 0xAB1C5ED5u,
  0xD807AA98u, 0x12835B01u, 0x243185BEu, 0x550C7DC3u,
  0x72BE5D74u, 0x80DEB1FEu, 0x9BDC06A7u, 0xC19BF174u,
  0xE49B69C1u, 0xEFBE4786u, 0x0FC19DC6u, 0x240CA1CCu,
  0x2DE92C6Fu, 0x4A7484AAu, 0x5CB0A9DCu, 0x76F988DAu,
  0x983E5152u, 0xA831C66Du, 0xB00327C8u, 0xBF597FC7u,
  0xC6E00BF3u, 0xD5A79147u, 0x06CA6351u, 0x14292967u,
  0x27B70A85u, 0x2E1B2138u, 0x4D2C6DFCu, 0x53380D13u,
  0x650A7354u, 0x766A0ABBu, 0x81C2C92Eu, 0x92722C85u,
  0xA2BFE8A1u, 0xA81A664Bu, 0xC24B8B70u, 0xC76C51A3u,
  0xD192E819u, 0xD6990624u, 0xF40E3585u, 0x106AA070u,
  0x19A4C116u, 0x1E376C08u, 0x2748774Cu, 0x34B0BCB5u,
  0x391C0CB3u, 0x4ED8AA4Au, 0x5B9CCA4Fu, 0x682E6FF3u,
  0x748F82EEu, 0x78A5636Fu, 0x84C87814u, 0x8CC70208u,
  0x90BEFFFAu, 0xA4506CEBu, 0xBEF9A3F7u, 0xC67178F2u
// EC1 C6 Private inline functions definitions
static inline U32 switchEndianity(U32 data)
  return data;
#else
  return (data >> 24u) | (U32)(data << 24u) | (((data & 0x00FF0000u) >> 8u) | (U32)((data & 0x0000FF00u) << 8u));
#endif
// EC1 C7 Private functions prototypes
static void SHA256_count(SHA256_CONTEXT *pSC);
// EC1 C8A Global functions definitions
 * @brief Initializes SAH-256 context
  pSC->hash[0] = H0;
  pSC->hash[1] = H1;
  pSC->hash[2] = H2;
  pSC->hash[3] = H3;
  pSC->hash[4] = H4;
  pSC->hash[5] = H5;
  pSC->hash[6] = H6;
  pSC->hash[7] = H7;
  pSC->buffer_ptr = 0u;
  pSC->total_len = 0u;
  U16 bfree;
#if defined(__TMS320C2000__)
  U16 bfreeacc = 0u;
#endif
  pSC->total_len += len;
  while(len != 0u)
    bfree = (U16)(SHA256_BUFFER_LEN_BYTE - pSC->buffer_ptr);
    if(bfree > len)
      U16 ii;
      for(ii = 0u; ii < len; ii++)
      { __byte((int *) &pSC->buffer[pSC->buffer_ptr], ii) = __byte((int *) pData, bfreeacc + ii); }
#else
      (void) memcpy(&pSC->buffer[pSC->buffer_ptr], pData, (size_t) len);
#endif
      pSC->buffer_ptr += (U32) len;
      len = 0u;                         // this will end the while-loop
    else
      U16 ii;
      for(ii = 0u; ii < bfree; ii++)
      bfreeacc += bfree;
#else
      (void) memcpy(&pSC->buffer[pSC->buffer_ptr], pData, bfree);
      pData = &((U8 *) pData)[bfree];
#endif
      SHA256_count(pSC);
      len -= bfree;
  U32 bitlenBE = switchEndianity(pSC->total_len * 8u);          // length in bits as a big-endian number
  if(pSC->buffer_ptr < (SHA256_BUFFER_LEN_BYTE - SHA256_DATA_LEN_BYTE))
    U16 ii;
    for(ii = 0u; ii < ((SHA256_BUFFER_LEN_BYTE - SHA256_DATA_LEN_BYTE) - (size_t) pSC->buffer_ptr); ii++)
    { __byte((int *) &pSC->buffer, pSC->buffer_ptr + ii) = __byte((int *) padding, ii); }
#else
    (void) memcpy(&((U8 *) pSC->buffer)[pSC->buffer_ptr], padding, ((SHA256_BUFFER_LEN_BYTE - SHA256_DATA_LEN_BYTE) - (size_t) pSC->buffer_ptr));
#endif
  else
    U16 ii;
    for(ii = 0u; ii < (SHA256_BUFFER_LEN_BYTE - (size_t) pSC->buffer_ptr); ii++)
#else
    (void) memcpy(&((U8 *) pSC->buffer)[pSC->buffer_ptr], padding, SHA256_BUFFER_LEN_BYTE - (size_t) pSC->buffer_ptr);
#endif
    SHA256_count(pSC);
    for(ii = 0u; ii < (SHA256_BUFFER_LEN_BYTE - SHA256_DATA_LEN_BYTE); ii++)
    { __byte((int *) pSC->buffer, ii) = 0; }
#else
    (void) memset(pSC->buffer, 0, SHA256_BUFFER_LEN_BYTE - SHA256_DATA_LEN_BYTE);
#endif
  pSC->buffer[SHA256_BUFFER_LEN - 2u] = 0u;
  pSC->buffer[SHA256_BUFFER_LEN - 1u] = bitlenBE;
  SHA256_count(pSC);
// EC1 C8B Private functions definitions
 * @brief
#if (BYTE_ORDER == LITTLE_ENDIAN)
  U32 w0  = switchEndianity(pSC->buffer[ 0]);
  U32 w1  = switchEndianity(pSC->buffer[ 1]);
  U32 w2  = switchEndianity(pSC->buffer[ 2]);
  U32 w3  = switchEndianity(pSC->buffer[ 3]);
  U32 w4  = switchEndianity(pSC->buffer[ 4]);
  U32 w5  = switchEndianity(pSC->buffer[ 5]);
  U32 w6  = switchEndianity(pSC->buffer[ 6]);
  U32 w7  = switchEndianity(pSC->buffer[ 7]);
  U32 w8  = switchEndianity(pSC->buffer[ 8]);
  U32 w9  = switchEndianity(pSC->buffer[ 9]);
  U32 w10 = switchEndianity(pSC->buffer[10]);
  U32 w11 = switchEndianity(pSC->buffer[11]);
  U32 w12 = switchEndianity(pSC->buffer[12]);
  U32 w13 = switchEndianity(pSC->buffer[13]);
  U32 w14 = switchEndianity(pSC->buffer[14]);
  U32 w15 = switchEndianity(pSC->buffer[15]);
#else
  U32 w0  = pSC->buffer[ 0];
  U32 w1  = pSC->buffer[ 1];
  U32 w2  = pSC->buffer[ 2];
  U32 w3  = pSC->buffer[ 3];
  U32 w4  = pSC->buffer[ 4];
  U32 w5  = pSC->buffer[ 5];
  U32 w6  = pSC->buffer[ 6];
  U32 w7  = pSC->buffer[ 7];
  U32 w8  = pSC->buffer[ 8];
  U32 w9  = pSC->buffer[ 9];
  U32 w10 = pSC->buffer[10];
  U32 w11 = pSC->buffer[11];
  U32 w12 = pSC->buffer[12];
  U32 w13 = pSC->buffer[13];
  U32 w14 = pSC->buffer[14];
  U32 w15 = pSC->buffer[15];
#endif
  U32 a = pSC->hash[0];
  U32 b = pSC->hash[1];
  U32 c = pSC->hash[2];
  U32 d = pSC->hash[3];
  U32 e = pSC->hash[4];
  U32 f = pSC->hash[5];
  U32 g = pSC->hash[6];
  U32 h = pSC->hash[7];
  U32 T1;
  U32 T2;
  U16 ii;
  U16 jj;
  for(ii = 0u, jj = 0u; ii < 4u; ii++)
    if(ii != 0u)
      EXPAND
    F(w0)
    F(w1)
    F(w2)
    F(w3)
    F(w4)
    F(w5)
    F(w6)
    F(w7)
    F(w8)
    F(w9)
    F(w10)
    F(w11)
    F(w12)
    F(w13)
    F(w14)
    F(w15)
  pSC->hash[0] += a;
  pSC->hash[1] += b;
  pSC->hash[2] += c;
  pSC->hash[3] += d;
  pSC->hash[4] += e;
  pSC->hash[5] += f;
  pSC->hash[6] += g;
  pSC->hash[7] += h;
# CCDIR=C:\Program Files (x86)\Texas Instruments\C2000 Code Generation Tools 6.4.1
CCDIR=C:\Program Files (x86)\Texas Instruments\C2000 Code Generation Tools 5.2.15
C2000_INCLUDE_DIR="$(CCDIR)\include"
C2000_LIBRARY_DIR="$(CCDIR)\lib"
CC="$(CCDIR)\bin\cl2000.exe"
H2000="$(CCDIR)\bin\hex2000.exe"
PERL=perl
SRCS=sha256.c
OBJS=$(SRCS:.c=.obj)
ASMS=$(SRCS:.c=.asm)
CFLAGS=-c -pdr -pdv -as -g -ss -os -pr -O0 -ml -v28 --float_support=fpu32
INCLUDE=-I${C2000_INCLUDE_DIR}
INCLIBS=-I${C2000_LIBRARY_DIR}
all: $(OBJS)
$(OBJS): $(SRCS)
	@$(PERL) -e "@list=($$sec,$$min,$$hour,$$day,$$mon,$$year,$$wday,$$yday,$$isdst)=localtime(time);$$year+=1900;printf \"Compilation started at %%4d-%%02d-%%02d %%d:%%02d:%%02d\n\", $$year, $$mon + 1, $$day, $$hour, $$min, $$sec"
	$(CC) $(CFLAGS) $(INCLUDE) $^
	@$(PERL) -e "@list=($$sec,$$min,$$hour,$$day,$$mon,$$year,$$wday,$$yday,$$isdst)=localtime(time);$$year+=1900;printf \"Compilation finished at %%4d-%%02d-%%02d %%d:%%02d:%%02d\n\", $$year, $$mon + 1, $$day, $$hour, $$min, $$sec"
.PHONY: clean
clean:
	@del $(OBJS) >NUL 2>&1
	@del $(ASMS) >NUL 2>&1
  • I apologize for the delayed response.
    I can reproduce this long build problem with the version 5.2.15 compiler.  I verified the very next release, version 6.0.1, does not have this problem. Version 6.0.1 was released almost 4 years ago.  Since it seems this issue is fixed, I searched our bug database for a problem report similar to this one.  I could not find it.
    Since it seems this problem is no longer affecting anyone, perhaps it makes sense to not pursue it further.
    Thanks and regards,
    -George
