I recently purchased a DRV8301-HC evaluation kit and it seems that the quick start guides on the memory stick are all for DRV8312.
I've tried looking online for the correct ones, but have had no luck...
This document applies for the above kit too.
"For this lab we are using the Three Phase BLDC Motor Kit with DRV8312 and Piccolo™ MCU
(DRV8312-C2-KIT) (the DRV8302-HC-C2-KIT or DRV8301-HC-C2-KIT can also be used) with a Piccolo
F28035 controlCARD™ subsystem to run the sensorless InstaSPIN™ BLDC technique. "
You can follow the same procedure.
Gautam
I'd appreciate it if the documentation for the DRV8301 specifically were available somewhere.
