I am working on software that need to write in flash while using the CSM.
The approach I used to allow the software to momentary be able to use the flash api, is to wrap the function call with an unlock and a locking function.
the functions are define as the following:
#pragma CODE_SECTION(configctrl_CSMUnlock, "ramfuncs"); Uint16 configctrl_CSMUnlock(); #pragma CODE_SECTION(configctrl_CSMlock, "ramfuncs"); void configctrl_CSMlock();
Uint16 configctrl_CSMUnlock() { volatile Uint16 temp; // Load the key registers with the current password // These are defined in Example_Flash2803x_CsmKeys.asm EALLOW; CsmRegs.KEY0 = PRG_key0; CsmRegs.KEY1 = PRG_key1; CsmRegs.KEY2 = PRG_key2; CsmRegs.KEY3 = PRG_key3; CsmRegs.KEY4 = PRG_key4; CsmRegs.KEY5 = PRG_key5; CsmRegs.KEY6 = PRG_key6; CsmRegs.KEY7 = PRG_key7; EDIS; // Perform a dummy read of the password locations // if they match the key values, the CSM will unlock temp = CsmPwl.PSWD0; temp = CsmPwl.PSWD1; temp = CsmPwl.PSWD2; temp = CsmPwl.PSWD3; temp = CsmPwl.PSWD4; temp = CsmPwl.PSWD5; temp = CsmPwl.PSWD6; temp = CsmPwl.PSWD7; // If the CSM unlocked, return succes, otherwise return // failure. if ( (CsmRegs.CSMSCR.all & 0x0001) == 0) { return STATUS_SUCCESS; } else { return STATUS_FAIL_CSM_LOCKED; } } //---------------------------------------------------------------------------------- void configctrl_CSMlock() { EALLOW; CsmRegs.CSMSCR.bit.FORCESEC=1; EDIS; }
Although, theses functions seems not to be always effective and the flash api return csm related errors.
Is there something wrong with the approach I used? Is there any timing specification to take into account while enabling/disabling the CSM?
Simon
