Hello everyone,
I need to implement a hysteresis current controller with 28335 DSP. My question is can I manually control the PWM pins of the DSP, based on the command from the hysteresis controller? In that way I can generate the ON signal for the upper switches of the inverter and the complementary signal with the desired dead time will be generated by the ePWM module.
Cheers,
Mohammad
