When attempting to use the I2C in master transmit mode on the TMS320F28069, I have found I am unable to transmit more than 2 data bytes although I am attempting to transmit many more (250 bytes). My scope is indicating that the slave is ack'ing the address byte and the two data bytes, but then the I2C transmission stops. See my code below. When i pause the code in the debugger, I am stuck in the following while loop:
while ( (I2caRegs.I2CSTR.bit.XRDY == 0 ) && (I2caRegs.I2CSTR.bit.ARDY == 0 )){};
I am not using the FIFO and simply trying to poll the (I2caRegs.I2CSTR.bit.XRDY bit.
Any ideas on what could be going on?
Thank you.
void Init_Master(void)
EALLOW;
GpioCtrlRegs.GPBPUD.bit.GPIO32 = 0; // Enable pull-up for GPIO32 (SDAA)
GpioCtrlRegs.GPBPUD.bit.GPIO33 = 0; // Enable pull-up for GPIO33 (SCLA)
GpioCtrlRegs.GPBQSEL1.bit.GPIO32 = 3; // Asynch input GPIO32 (SDAA)
GpioCtrlRegs.GPBQSEL1.bit.GPIO33 = 3; // Asynch input GPIO33 (SCLA)
GpioCtrlRegs.GPBMUX1.bit.GPIO32 = 1; // Configure GPIO32 for SDAA operation
GpioCtrlRegs.GPBMUX1.bit.GPIO33 = 1; // Configure GPIO33 for SCLA operation
EDIS;
I2caRegs.I2CMDR.all = 0x0000; // I2C in reset
I2caRegs.I2CPSC.all = 4; // Prescaler - need 7-12 Mhz on module clk
I2caRegs.I2CCLKL = 40; // NOTE: must be non zero
I2caRegs.I2CCLKH = 40; // NOTE: must be non zero
I2caRegs.I2CIER.all = 0x00; // No interrupts enabled
I2caRegs.I2CMDR.all = 0x0020; // Take I2C out of reset
// Stop I2C when suspended
I2caRegs.I2COAR = 0x0004; // Own Address
return;
void Write_Master(uint8_t address, uint8_t * write_data, uint8_t bytes)
int16_t i;
/* Check for Bus Busy */
while ((I2caRegs.I2CSTR.bit.BB == 1 ));
/* Disable I2C during configuration */
I2caRegs.I2CMDR.all = 0;
/* Set the I2C controller to write len bytes */
I2caRegs.I2CCNT = bytes;
I2caRegs.I2CSAR = 0x08;
I2caRegs.I2CMDR.bit.IRS = 1;
I2caRegs.I2CMDR.bit.TRX = 1;
I2caRegs.I2CMDR.bit.STP = 1;
I2caRegs.I2CMDR.bit.MST = 1;
I2caRegs.I2CMDR.bit.FREE = 1;
I2caRegs.I2CMDR.bit.STT = 1;
/* Transmit data */
for (i = 0; i < bytes-4; i++)
// Wait for "XRDY" flag to transmit data or "ARDY" if we get NACKed
I2caRegs.I2CDXR = ICC_TEST_PATTERN;
// If a NACK occurred then SCL is held low and STP bit cleared
if ( I2caRegs.I2CSTR.bit.NACK == 1 )
I2caRegs.I2CMDR.all = 0; // reset I2C so SCL isn't held low
iic_comm_error = NO_ACK_ON_WRITE_ERROR;
return;
return;
