Hi
I am facing issues with CCSv6.0, TMS320F28335 while working with a power electronic circuit. I am using ADC,ePWM,CAN in broader terms.
The program works fine with the power electronic converter while sensing ADC and generating PWM, But when CAN communication code is included it faces some issues. The screenshots are attached below:
When I disable the real time mode, program seems to be working fine. But if real time mode is enabled as is desired, it either hangs, does not load or gets debugged and then throws away the error and performs nothing.
Kindly suggest some solutions.
Thanks & regards
Sneha
