I'm currently using Piccolo lauchPad with booster kit and I am going thru TMS320F28027F datasheets and Timer-section.
Previous Microcontrollers I have used had gating control for Timers which means that external pin is able to enable Timer to run. Now in This Piccolo there seems to be no gating control, only direct clock drive when Timer is set to run by direct register control.
What do you suggest, what is the best way to achieve this functionality, simply polling an input pin and when pin is "high" timer is run, else not run ?
-Jay
