I am trying to create a basic application with a secondary bootloader; however, when I compile the application, the map file has a different entry point then what I have selected. And, when I execute the application, it launches into the generic library boot file rather than the application boot assembly I have put together.
I am using the F28335.cmd file from controlSUITE as well as DSP2833x_CodeStartBranch.asm, and a main.c that has nothing in it.
In the map file I see:
****************************************************************************** TMS320C2000 Linker PC v6.4.4 ****************************************************************************** >> Linked Fri May 22 08:28:30 2015 OUTPUT FILE NAME: <TEST.out> ENTRY POINT SYMBOL: "_c_int00" address: 00338000 MEMORY CONFIGURATION name origin length used unused attr fill ---------------------- -------- --------- -------- -------- ---- -------- PAGE 0: ZONE0 00004000 00001000 00000000 00001000 RWIX RAML0 00008000 00001000 00000000 00001000 RWIX RAML1 00009000 00001000 00000000 00001000 RWIX RAML2 0000a000 00001000 00000000 00001000 RWIX RAML3 0000b000 00001000 00000000 00001000 RWIX ZONE6 00100000 00100000 00000000 00100000 RWIX ZONE7A 00200000 0000fc00 00000000 0000fc00 RWIX FLASHH 00300000 00008000 00000000 00008000 RWIX FLASHG 00308000 00008000 00000000 00008000 RWIX FLASHF 00310000 00008000 00000000 00008000 RWIX FLASHE 00318000 00008000 00000000 00008000 RWIX FLASHD 00320000 00008000 00000000 00008000 RWIX FLASHC 00328000 00008000 00000000 00008000 RWIX FLASHA 00338000 00007f80 000000b8 00007ec8 RWIX CSM_RSVD 0033ff80 00000076 00000000 00000076 RWIX BEGIN 0033fff6 00000002 00000002 00000000 RWIX CSM_PWL 0033fff8 00000008 00000000 00000008 RWIX ADC_CAL 00380080 00000009 00000000 00000009 RWIX OTP 00380400 00000400 00000000 00000400 RWIX IQTABLES 003fe000 00000b50 00000000 00000b50 RWIX IQTABLES2 003feb50 0000008c 00000000 0000008c RWIX FPUTABLES 003febdc 000006a0 00000000 000006a0 RWIX ROM 003ff27c 00000d44 00000000 00000d44 RWIX RESET 003fffc0 00000002 00000000 00000002 RWIX VECTORS 003fffc2 0000003e 00000000 0000003e RWIX PAGE 1: BOOT_RSVD 00000000 00000050 00000000 00000050 RWIX RAMM0 00000050 000003b0 00000000 000003b0 RWIX RAMM1 00000400 00000400 00000300 00000100 RWIX DEV_EMU 00000880 00000180 000000d0 000000b0 RWIX FLASH_REGS 00000a80 00000060 00000008 00000058 RWIX CSM 00000ae0 00000010 00000010 00000000 RWIX ADC_MIRROR 00000b00 00000010 00000010 00000000 RWIX XINTF 00000b20 00000020 0000001e 00000002 RWIX CPU_TIMER0 00000c00 00000008 00000008 00000000 RWIX CPU_TIMER1 00000c08 00000008 00000008 00000000 RWIX CPU_TIMER2 00000c10 00000008 00000008 00000000 RWIX PIE_CTRL 00000ce0 00000020 0000001a 00000006 RWIX PIE_VECT 00000d00 00000100 00000100 00000000 RWIX DMA 00001000 00000200 000000e0 00000120 RWIX MCBSPA 00005000 00000040 00000025 0000001b RWIX MCBSPB 00005040 00000040 00000025 0000001b RWIX ECANA 00006000 00000040 00000034 0000000c RWIX ECANA_LAM 00006040 00000040 00000040 00000000 RWIX ECANA_MOTS 00006080 00000040 00000040 00000000 RWIX ECANA_MOTO 000060c0 00000040 00000040 00000000 RWIX ECANA_MBOX 00006100 00000100 00000100 00000000 RWIX ECANB 00006200 00000040 00000034 0000000c RWIX ECANB_LAM 00006240 00000040 00000040 00000000 RWIX ECANB_MOTS 00006280 00000040 00000040 00000000 RWIX ECANB_MOTO 000062c0 00000040 00000040 00000000 RWIX ECANB_MBOX 00006300 00000100 00000100 00000000 RWIX EPWM1 00006800 00000022 00000022 00000000 RWIX EPWM2 00006840 00000022 00000022 00000000 RWIX EPWM3 00006880 00000022 00000022 00000000 RWIX EPWM4 000068c0 00000022 00000022 00000000 RWIX EPWM5 00006900 00000022 00000022 00000000 RWIX EPWM6 00006940 00000022 00000022 00000000 RWIX ECAP1 00006a00 00000020 00000020 00000000 RWIX ECAP2 00006a20 00000020 00000020 00000000 RWIX ECAP3 00006a40 00000020 00000020 00000000 RWIX ECAP4 00006a60 00000020 00000020 00000000 RWIX ECAP5 00006a80 00000020 00000020 00000000 RWIX ECAP6 00006aa0 00000020 00000020 00000000 RWIX EQEP1 00006b00 00000040 00000040 00000000 RWIX EQEP2 00006b40 00000040 00000040 00000000 RWIX GPIOCTRL 00006f80 00000040 0000002e 00000012 RWIX GPIODAT 00006fc0 00000020 00000020 00000000 RWIX GPIOINT 00006fe0 00000020 0000000a 00000016 RWIX SYSTEM 00007010 00000020 00000020 00000000 RWIX SPIA 00007040 00000010 00000010 00000000 RWIX SCIA 00007050 00000010 00000010 00000000 RWIX XINTRUPT 00007070 00000010 00000010 00000000 RWIX ADC 00007100 00000020 0000001e 00000002 RWIX SCIB 00007750 00000010 00000010 00000000 RWIX SCIC 00007770 00000010 00000010 00000000 RWIX I2CA 00007900 00000040 00000022 0000001e RWIX RAML4 0000c000 00001000 00000008 00000ff8 RWIX RAML5 0000d000 00001000 00000000 00001000 RWIX RAML6 0000e000 00001000 00000000 00001000 RWIX RAML7 0000f000 00001000 00000000 00001000 RWIX ZONE7B 0020fc00 00000400 00000000 00000400 RWIX FLASHB 00330000 00008000 00000000 00008000 RWIX CSM_PWL 0033fff8 00000008 00000008 00000000 RWIX PARTID 00380090 00000001 00000001 00000000 RWIX SECTION ALLOCATION MAP output attributes/ section page origin length input sections -------- ---- ---------- ---------- ---------------- ramfuncs 0 00008000 00000000 UNINITIALIZED .text 0 00338000 000000a2 00338000 00000046 rts2800_fpu32.lib : boot.obj (.text) 00338046 00000019 : args_main.obj (.text) 0033805f 00000019 : exit.obj (.text) 00338078 00000016 DSP2833x_CodeStartBranch.obj (.text) 0033808e 0000000b main.obj (.text) 00338099 00000009 rts2800_fpu32.lib : _lock.obj (.text) .cinit 0 003380a2 00000016 003380a2 0000000a rts2800_fpu32.lib : exit.obj (.cinit) 003380ac 00000005 <whole-program> (.cinit:__lock) 003380b1 00000005 <whole-program> (.cinit:__unlock) 003380b6 00000002 --HOLE-- [fill = 0] .pinit 0 00338000 00000000 UNINITIALIZED codestart * 0 0033fff6 00000002 0033fff6 00000002 DSP2833x_CodeStartBranch.obj (codestart)
Any thoughts as to why this isn't working as one would expect?
Thanks in advance.
