Hi All,
I am using TMS320F28377D controller for my inverter application. I am using CAN communication protocol : I have read from user manual that transmit object can be changed to dynamically. That means that I can change the msgID runtime. Am I right?
Now that question is: can I do same thing for reception? Can I change msgID runtime for receiving object. If yes, then is there any specific process that I should follow.
Currently I am using example code folder named “can_loopback_interrupts_cpu01”.
If I change msgID then is there any requirement of msg box enable/disable as in piccolo?
Thanks and Regads,
Maulik Timbadiya
