I am using SPI 28027 Code.
How to test with example code.
Have you downloaded ControlSUITE? This contains all of our example code for the device. You can take them and modify them to your needs. There are some links in my Footer that contain workshop and training material as well.
Do you have a specific question you would like answered?
Mark
I am not sure I understand your question.
You can use the example code provided in ControlSUITE. Compile, load, and run the programs on the ControlCard. If you wish to see the SPI signals on a scope, or connect them to an external device, you will have to find which GPIOs you are using and connect them externally.
Here is a direct link to the Piccolo Multi-day Workshop that you can go through:
Mark
