I would like to understand if Flash API programming is the same processes like EEPROM emulation and what are the odds between the two.
I saw the sprab69 document and also the Flash2833x_API_Readme and trying to understand the differences.
For example Flash API blocks all the interruptions during write/read. Does the same happen during EEPROM emulation use?
In general I'm trying to find a simplest way to save some data from ADC measurements for post-processing analysis.
The save procedure must be done during normal code execution without blocking interrupts (or maybe for micro seconds only)
Is there another possible way doing this?
Alex
