I would like to sample three phase ac using ADC in TM320F28075, what are the issues that may arise ? and precautions to be taken ?
Hi Joseph,
The ADC can only resolve a voltage in the range of 0 to VREFHI (typically around 0 to 2.5V), so you will need to build some signal conditioning circuits to turn the voltages and/or currents into voltages in this range. For best results, you will want to drive the ADC inputs with a low impedance source, which typically will be an op-amp.
From a SW perspective, you can take advantage of the multiple ADCs on this device to sample your voltages and/or currents simultaneously. For best performance, you need to make sure the ADCs operate synchronously, so you will want to configure same numbered SOCs with identical S+H duration and trigger select.
