On page 2197 of the TRM (SPRUHM8E) we state that there is an issue with the compiler generating two 16 bit access instead of a single 32 bit access when accessing the DCAN registers. It also says that a compiler fix is in the works.
Can you please tell me which versions of the compiler are affected or when this got solved, if?
Is there an intrinsic available to force (all) compiler versions to encode a 32 bit access?
Christian
