  • Answer Suggested
Compiler/TMS320F28377S: Applications doesn´t start, when defining too big arrays (e.g. "double myDoubles[200]") => LaunchXL-F28377S
Part Number: TMS320F28377S
Hello there,
we´re running a "LaunchXL-F28377S" Evalboard.
We´re facing the effect, that the application doesn´t start, if a too big array is defined, for example a double Array with 200 entries.
I don´t think it´s a lag of RAM, because the Compile doesn´t complain that, plus all the RAM is defined to be used for variables.
The effect is, that the application can be loaded to to flash with the debugger emulator and the visiual program pointer starts at the very first line
of main()
Once the run button is pressed, the application crashes.
Does someone have an idea?
best regards!!
    Where is the array declared? Do you mind sharing your .map file and .cmd file?
    Whitney
  • In reply to Whitney Dewey:
    Hello Whintey,
    yes, i do so.
    To be honest, i´m not sure, which .cmd file the compiler uses. By looking in the project properties->Build->C2000 Linker-> "Summary of flags set"  the direction is
    ti\controlSUITE\device_support\F2837xS\v210\F2837xS_common\cmd
    There are several .cmd files; from the installed examples i guess
    best regards,
    Jasson
    The .map file
    i´m sorry, for some reason, my Laptop doesn´t load up the file using the "Insert File" function, find below that the .cmd file
                 TMS320C2000 Linker PC v15.12.3
    >> Linked Thu May 18 11:01:15 2017
    OUTPUT FILE NAME:   <SW_Board_02.out>
    ENTRY POINT SYMBOL: "code_start"  address: 00080000
    MEMORY CONFIGURATION
             name            origin    length      used     unused   attr    fill
    PAGE 0:
      RAMM0                 00000122   000002de  00000000  000002de  RWIX
      RAMLS0                00008000   00000800  00000094  0000076c  RWIX
      RAMLS1                00008800   00000800  00000000  00000800  RWIX
      RAMLS2                00009000   00000800  00000000  00000800  RWIX
      RAMLS3                00009800   00000800  00000000  00000800  RWIX
      RAMLS4                0000a000   00000800  00000000  00000800  RWIX
      RAMD0                 0000b000   00000800  00000000  00000800  RWIX
      BEGIN                 00080000   00000002  00000002  00000000  RWIX
      FLASHA                00080002   00001ffe  00000000  00001ffe  RWIX
      FLASHB                00082000   00002000  00002000  00000000  RWIX
      FLASHC                00084000   00002000  000009b1  0000164f  RWIX
      FLASHD                00086000   00002000  00000094  00001f6c  RWIX
      FLASHE                00088000   00008000  00000000  00008000  RWIX
      FLASHF                00090000   00008000  00000328  00007cd8  RWIX
      FLASHG                00098000   00008000  00000000  00008000  RWIX
      FLASHH                000a0000   00008000  00000000  00008000  RWIX
      FLASHI                000a8000   00008000  00000000  00008000  RWIX
      FLASHJ                000b0000   00008000  00000000  00008000  RWIX
      FLASHK                000b8000   00002000  00000000  00002000  RWIX
      FLASHL                000ba000   00002000  00000000  00002000  RWIX
      FLASHM                000bc000   00002000  00000000  00002000  RWIX
      FLASHN                000be000   00002000  00000000  00002000  RWIX
      RESET                 003fffc0   00000002  00000000  00000002  RWIX
    PAGE 1:
      BOOT_RSVD             00000002   00000120  00000000  00000120  RWIX
      RAMM1                 00000400   00000400  00000100  00000300  RWIX
      ADCA_RESULT           00000b00   00000020  00000018  00000008  RWIX
      ADCB_RESULT           00000b20   00000020  00000018  00000008  RWIX
      ADCC_RESULT           00000b40   00000020  00000018  00000008  RWIX
      ADCD_RESULT           00000b60   00000020  00000018  00000008  RWIX
      CPU_TIMER0            00000c00   00000008  00000008  00000000  RWIX
      CPU_TIMER1            00000c08   00000008  00000008  00000000  RWIX
      CPU_TIMER2            00000c10   00000008  00000008  00000000  RWIX
      PIE_CTRL              00000ce0   00000020  0000001a  00000006  RWIX
      PIE_VECT              00000d00   00000200  000001c0  00000040  RWIX
      DMA                   00001000   00000200  000000e0  00000120  RWIX
      CLA1                  00001400   00000040  0000003e  00000002  RWIX
      EPWM1                 00004000   00000100  00000100  00000000  RWIX
      EPWM2                 00004100   00000100  00000100  00000000  RWIX
      EPWM3                 00004200   00000100  00000100  00000000  RWIX
      EPWM4                 00004300   00000100  00000100  00000000  RWIX
      EPWM5                 00004400   00000100  00000100  00000000  RWIX
      EPWM6                 00004500   00000100  00000100  00000000  RWIX
      EPWM7                 00004600   00000100  00000100  00000000  RWIX
      EPWM8                 00004700   00000100  00000100  00000000  RWIX
      EPWM9                 00004800   00000100  00000100  00000000  RWIX
      EPWM10                00004900   00000100  00000100  00000000  RWIX
      EPWM11                00004a00   00000100  00000100  00000000  RWIX
      EPWM12                00004b00   00000100  00000100  00000000  RWIX
      ECAP1                 00005000   00000020  00000020  00000000  RWIX
      ECAP2                 00005020   00000020  00000020  00000000  RWIX
      ECAP3                 00005040   00000020  00000020  00000000  RWIX
      ECAP4                 00005060   00000020  00000020  00000000  RWIX
      ECAP5                 00005080   00000020  00000020  00000000  RWIX
      ECAP6                 000050a0   00000020  00000020  00000000  RWIX
      EQEP1                 00005100   00000040  00000022  0000001e  RWIX
      EQEP2                 00005140   00000040  00000022  0000001e  RWIX
      EQEP3                 00005180   00000040  00000022  0000001e  RWIX
      DACA                  00005c00   00000010  00000008  00000008  RWIX
      DACB                  00005c10   00000010  00000008  00000008  RWIX
      DACC                  00005c20   00000010  00000008  00000008  RWIX
      CMPSS1                00005c80   00000020  00000020  00000000  RWIX
      CMPSS2                00005ca0   00000020  00000020  00000000  RWIX
      CMPSS3                00005cc0   00000020  00000020  00000000  RWIX
      CMPSS4                00005ce0   00000020  00000020  00000000  RWIX
      CMPSS5                00005d00   00000020  00000020  00000000  RWIX
      CMPSS6                00005d20   00000020  00000020  00000000  RWIX
      CMPSS7                00005d40   00000020  00000020  00000000  RWIX
      CMPSS8                00005d60   00000020  00000020  00000000  RWIX
      SDFM1                 00005e00   00000080  00000080  00000000  RWIX
      SDFM2                 00005e80   00000080  00000080  00000000  RWIX
      MCBSPA                00006000   00000040  00000024  0000001c  RWIX
      MCBSPB                00006040   00000040  00000024  0000001c  RWIX
      SPIA                  00006100   00000010  00000010  00000000  RWIX
      SPIB                  00006110   00000010  00000010  00000000  RWIX
      ***                  00006120   00000010  00000010  00000000  RWIX
      SPID                  00006130   00000010  00000000  00000010  RWIX
      UPP                   00006200   00000100  00000048  000000b8  RWIX
      WD                    00007000   00000040  0000002b  00000015  RWIX
      NMIINTRUPT            00007060   00000010  00000007  00000009  RWIX
      XINT                  00007070   00000010  0000000b  00000005  RWIX
      SCIA                  00007200   00000010  00000010  00000000  RWIX
      SCIB                  00007210   00000010  00000010  00000000  RWIX
      SCIC                  00007220   00000010  00000010  00000000  RWIX
      SCID                  00007230   00000010  00000010  00000000  RWIX
      I2CA                  00007300   00000040  00000022  0000001e  RWIX
      I2CB                  00007340   00000040  00000022  0000001e  RWIX
      ADCA                  00007400   00000080  00000080  00000000  RWIX
      ADCB                  00007480   00000080  00000080  00000000  RWIX
      ADCC                  00007500   00000080  00000080  00000000  RWIX
      ADCD                  00007580   00000080  00000080  00000000  RWIX
      INPUT_XBAR            00007900   00000020  00000020  00000000  RWIX
      XBAR                  00007920   00000020  00000020  00000000  RWIX
      SYNC_SOC              00007940   00000010  00000006  0000000a  RWIX
      DMACLASRCSEL          00007980   00000040  0000001a  00000026  RWIX
      EPWM_XBAR             00007a00   00000040  00000040  00000000  RWIX
      CLB_XBAR              00007a40   00000040  00000000  00000040  RWIX
      OUTPUT_XBAR           00007a80   00000040  00000040  00000000  RWIX
      GPIOCTRL              00007c00   00000180  00000180  00000000  RWIX
      GPIODAT               00007f00   00000030  00000030  00000000  RWIX
      RAMLS5                0000a800   00000800  000007f6  0000000a  RWIX
      RAMD1                 0000b800   00000800  00000000  00000800  RWIX
      RAMGS0                0000c000   00001000  00000000  00001000  RWIX
      RAMGS1                0000d000   00001000  00000000  00001000  RWIX
      RAMGS2                0000e000   00001000  00000000  00001000  RWIX
      RAMGS3                0000f000   00001000  00000000  00001000  RWIX
      RAMGS4                00010000   00001000  00000000  00001000  RWIX
      RAMGS5                00011000   00001000  00000000  00001000  RWIX
      RAMGS6                00012000   00001000  00000000  00001000  RWIX
      RAMGS7                00013000   00001000  00000000  00001000  RWIX
      RAMGS8                00014000   00001000  00000000  00001000  RWIX
      RAMGS9                00015000   00001000  00000000  00001000  RWIX
      RAMGS10               00016000   00001000  00000000  00001000  RWIX
      RAMGS11               00017000   00001000  00000000  00001000  RWIX
      EMIF1                 00047000   00000800  00000070  00000790  RWIX
      EMIF2                 00047800   00000800  00000070  00000790  RWIX
      CANA                  00048000   00000800  00000000  00000800  RWIX
      CANB                  0004a000   00000800  00000000  00000800  RWIX
      FLASHPUMPSEMAPHORE    00050024   00000002  00000002  00000000  RWIX
      DEV_CFG               0005d000   00000180  0000012e  00000052  RWIX
      ANALOG_SUBSYS         0005d180   00000080  00000048  00000038  RWIX
      CLK_CFG               0005d200   00000100  00000032  000000ce  RWIX
      CPU_SYS               0005d300   00000100  00000082  0000007e  RWIX
      ROMPREFETCH           0005e608   00000002  00000002  00000000  RWIX
      DCSM_Z1               0005f000   00000030  00000024  0000000c  RWIX
      DCSM_Z2               0005f040   00000030  00000024  0000000c  RWIX
      DCSM_COMMON           0005f070   00000010  00000008  00000008  RWIX
      MEMCFG                0005f400   00000080  00000080  00000000  RWIX
      EMIF1CONFIG           0005f480   00000020  00000020  00000000  RWIX
      EMIF2CONFIG           0005f4a0   00000020  00000020  00000000  RWIX
      ACCESSPROTECTION      0005f4c0   00000040  00000040  00000000  RWIX
      MEMORYERROR           0005f500   00000040  00000040  00000000  RWIX
      ROMWAITSTATE          0005f540   00000002  00000002  00000000  RWIX
      FLASH0_CTRL           0005f800   00000300  00000182  0000017e  RWIX
      FLASH0_ECC            0005fb00   00000040  00000028  00000018  RWIX
      FLASH1_CTRL           0005fc00   00000300  00000182  0000017e  RWIX
      FLASH1_ECC            0005ff00   00000040  00000028  00000018  RWIX
      DCSM_Z1_OTP           00078000   00000020  00000020  00000000  RWIX
      DCSM_Z2_OTP           00078200   00000020  00000020  00000000  RWIX
    SECTION ALLOCATION MAP
     output                                  attributes/
    section   page    origin      length       input sections
    codestart
    *          0    00080000    00000002
                      00080000    00000002     F2837xS_CodeStartBranch.obj (codestart)
    .cinit     0    00082000    00000088
                      00082000    00000028     epwm_trip_zone.obj (.cinit)
                      00082028    00000019     dac.obj (.cinit)
                      00082041    00000014     serialUART.obj (.cinit)
                      00082055    0000000e     rts2800_fpu32.lib : exit.obj (.cinit)
                      00082063    00000008     ADCSource.obj (.cinit)
                      0008206b    00000005     rts2800_fpu32.lib : _lock.obj (.cinit:__lock)
                      00082070    00000005                       : _lock.obj (.cinit:__unlock)
                      00082075    00000005                       : vars.obj (.cinit)
                      0008207a    00000004     F2837xS_DefaultISR.obj (.cinit)
                      0008207e    00000004     adc.obj (.cinit)
                      00082082    00000004     rts2800_fpu32.lib : memory.obj (.cinit)
                      00082086    00000002     --HOLE-- [fill = 0]
    .pinit     0    00082000    00000000     UNINITIALIZED
    .switch    0    00082088    00000020
                      00082088    00000020     dac.obj (.switch:_spiAint)
    .TI.ramfunc
    *          0    00086000    00000094     RUN ADDR = 00008000
                      00086000    00000090     F2837xS_SysCtrl.obj (.TI.ramfunc)
                      00086090    00000004     F2837xS_usDelay.obj (.TI.ramfunc)
    .stack     1    00000400    00000100     UNINITIALIZED
                      00000400    00000100     --HOLE--
    .esysmem   1    0000a800    00000400     UNINITIALIZED
                      0000a800    00000001     rts2800_fpu32.lib : memory.obj (.esysmem)
                      0000a801    000003ff     --HOLE--
    .reset     0    003fffc0    00000002     DSECT
                      003fffc0    00000002     rts2800_fpu32.lib : boot.obj (.reset)
    .text.1    0    000820a8    00001f58
                      000820a8    0000058f     F2837xS_DefaultISR.obj (.text:retain)
                      00082637    00000001     rts2800_fpu32.lib : newhandler.obj (.text)
                      00082638    000004cf     epwm_trip_zone.obj (.text)
                      00082b07    0000049c     UARTsrcSnk.obj (.text)
                      00082fa3    00000384     F2837xS_SysCtrl.obj (.text)
                      00083327    00000242     ADCSource.obj (.text)
                      00083569    000001d4     F2837xS_Gpio.obj (.text)
                      0008373d    000001d2     rts2800_fpu32.lib : memory.obj (.text)
                      0008390f    00000196     Transform.obj (.text)
                      00083aa5    0000016e     PWMsink.obj (.text)
                      00083c13    00000001     rts2800_fpu32.lib : startup.obj (.text)
                      00083c14    0000016a     ThreePhaseBase.obj (.text)
                      00083d7e    00000162     epwm_trip_zone.obj (.text:retain)
                      00083ee0    000000db     IOExpander.obj (.text)
                      00083fbb    00000029     rts2800_fpu32.lib : exit.obj (.text)
                      00083fe4    0000001a                       : cpy_utils.obj (.text)
                      00083ffe    00000002                       : pre_init.obj (.text)
    .text.2    0    00084000    000009b1
                      00084000    000000d4     F2837xS_Adc.obj (.text)
                      000840d4    000000b2     adc.obj (.text:retain)
                      00084186    000000b2     dac.obj (.text:retain)
                      00084238    000000a4     DACSink.obj (.text)
                      000842dc    0000009d     serialUART.obj (.text:retain)
                      00084379    0000009a     serialUART.obj (.text)
                      00084413    00000096     ThreePhsSysCoordinator.obj (.text)
                      000844a9    00000092     ThreePhsSysOutput.obj (.text)
                      0008453b    0000008a     dac.obj (.text)
                      000845c5    00000088     rts2800_fpu32.lib : fs_div.obj (.text)
                      0008464d    00000079     OnePhaseBase.obj (.text)
                      000846c6    0000005e     EXTADC.obj (.text)
                      00084724    00000058     EXTADCMAX11605.obj (.text)
                      0008477c    00000056     ThreePhsSysInput.obj (.text)
                      000847d2    00000056     rts2800_fpu32.lib : boot.obj (.text)
                      00084828    00000047     SysCommons.obj (.text)
                      0008486f    00000046     rts2800_fpu32.lib : cpy_tbl.obj (.text)
                      000848b5    00000028     F2837xS_PieCtrl.obj (.text)
                      000848dd    00000023     OnePhsSysInput.obj (.text)
                      00084900    00000022     rts2800_fpu32.lib : i_div.obj (.text)
                      00084922    00000020                       : new_.obj (.text)
                      00084942    0000001e                       : memcpy.obj (.text)
                      00084960    00000019     adc.obj (.text)
                      00084979    00000019     rts2800_fpu32.lib : args_main.obj (.text)
                      00084992    00000011     F2837xS_PieVect.obj (.text)
                      000849a3    00000009     rts2800_fpu32.lib : _lock.obj (.text)
                      000849ac    00000005                       : delete.obj (.text)
    .econst    0    00090000    00000328
                      00090000    000001c0     F2837xS_PieVect.obj (.econst:_PieVectTableInit)
                      000901c0    00000050     ThreePhsSysInput.obj (.econst:_ph1)
                      00090210    00000050     ThreePhsSysInput.obj (.econst:_ph2)
                      00090260    00000050     ThreePhsSysInput.obj (.econst:_ph3)
                      000902b0    00000008     ADCSource.obj (.econst:___vtbl__10ADC_Source)
                      000902b8    00000008     SysCommons.obj (.econst:___vtbl__10SysCommons)
                      000902c0    00000008     UARTsrcSnk.obj (.econst:___vtbl__10UARTsrcSnk)
                      000902c8    00000008     IOExpander.obj (.econst:___vtbl__11IO_Expander)
                      000902d0    00000008     OnePhaseBase.obj (.econst:___vtbl__12OnePhaseBase)
                      000902d8    00000008     OnePhsSysInput.obj (.econst:___vtbl__14OnePhsSysInput)
                      000902e0    00000008     ThreePhaseBase.obj (.econst:___vtbl__14ThreePhaseBase)
                      000902e8    00000008     EXTADCMAX11605.obj (.econst:___vtbl__16EXT_ADC_MAX11605)
                      000902f0    00000008     ThreePhsSysInput.obj (.econst:___vtbl__16ThreePhsSysInput)
                      000902f8    00000008     ThreePhsSysOutput.obj (.econst:___vtbl__17ThreePhsSysOutput)
                      00090300    00000008     ThreePhsSysCoordinator.obj (.econst:___vtbl__22ThreePhsSysCoordinator)
                      00090308    00000008     DACSink.obj (.econst:___vtbl__7DACSink)
                      00090310    00000008     EXTADC.obj (.econst:___vtbl__7EXT_ADC)
                      00090318    00000008     PWMsink.obj (.econst:___vtbl__7PWMsink)
                      00090320    00000008     Transform.obj (.econst:___vtbl__9Transform)
    AdcaResultFile
    *          1    00000b00    00000018     UNINITIALIZED
                      00000b00    00000018     F2837xS_GlobalVariableDefs.obj (AdcaResultFile)
    AdcbResultFile
    *          1    00000b20    00000018     UNINITIALIZED
                      00000b20    00000018     F2837xS_GlobalVariableDefs.obj (AdcbResultFile)
    AdccResultFile
    *          1    00000b40    00000018     UNINITIALIZED
                      00000b40    00000018     F2837xS_GlobalVariableDefs.obj (AdccResultFile)
    AdcdResultFile
    *          1    00000b60    00000018     UNINITIALIZED
                      00000b60    00000018     F2837xS_GlobalVariableDefs.obj (AdcdResultFile)
    CpuTimer0RegsFile
    *          1    00000c00    00000008     UNINITIALIZED
                      00000c00    00000008     F2837xS_GlobalVariableDefs.obj (CpuTimer0RegsFile)
    CpuTimer1RegsFile
    *          1    00000c08    00000008     UNINITIALIZED
                      00000c08    00000008     F2837xS_GlobalVariableDefs.obj (CpuTimer1RegsFile)
    CpuTimer2RegsFile
    *          1    00000c10    00000008     UNINITIALIZED
                      00000c10    00000008     F2837xS_GlobalVariableDefs.obj (CpuTimer2RegsFile)
    PieCtrlRegsFile
    *          1    00000ce0    0000001a     UNINITIALIZED
                      00000ce0    0000001a     F2837xS_GlobalVariableDefs.obj (PieCtrlRegsFile)
    PieVectTableFile
    *          1    00000d00    000001c0     UNINITIALIZED
                      00000d00    000001c0     F2837xS_GlobalVariableDefs.obj (PieVectTableFile)
    EmuKeyVar
    *          1    00000d00    00000001     UNINITIALIZED
                      00000d00    00000001     F2837xS_GlobalVariableDefs.obj (EmuKeyVar)
    EmuBModeVar
    *          1    00000d01    00000001     UNINITIALIZED
                      00000d01    00000001     F2837xS_GlobalVariableDefs.obj (EmuBModeVar)
    FlashCallbackVar
    *          1    00000d02    00000000     UNINITIALIZED
    FlashScalingVar
    DmaRegsFile
    *          1    00001000    000000e0     UNINITIALIZED
                      00001000    000000e0     F2837xS_GlobalVariableDefs.obj (DmaRegsFile)
    Cla1RegsFile
    *          1    00001400    0000003e     UNINITIALIZED
                      00001400    0000003e     F2837xS_GlobalVariableDefs.obj (Cla1RegsFile)
    EPwm1RegsFile
    *          1    00004000    00000100     UNINITIALIZED
                      00004000    00000100     F2837xS_GlobalVariableDefs.obj (EPwm1RegsFile)
    EPwm2RegsFile
    *          1    00004100    00000100     UNINITIALIZED
                      00004100    00000100     F2837xS_GlobalVariableDefs.obj (EPwm2RegsFile)
    EPwm3RegsFile
    *          1    00004200    00000100     UNINITIALIZED
                      00004200    00000100     F2837xS_GlobalVariableDefs.obj (EPwm3RegsFile)
    EPwm4RegsFile
    *          1    00004300    00000100     UNINITIALIZED
                      00004300    00000100     F2837xS_GlobalVariableDefs.obj (EPwm4RegsFile)
    EPwm5RegsFile
    *          1    00004400    00000100     UNINITIALIZED
                      00004400    00000100     F2837xS_GlobalVariableDefs.obj (EPwm5RegsFile)
    EPwm6RegsFile
    *          1    00004500    00000100     UNINITIALIZED
                      00004500    00000100     F2837xS_GlobalVariableDefs.obj (EPwm6RegsFile)
    EPwm7RegsFile
    *          1    00004600    00000100     UNINITIALIZED
                      00004600    00000100     F2837xS_GlobalVariableDefs.obj (EPwm7RegsFile)
    EPwm8RegsFile
    *          1    00004700    00000100     UNINITIALIZED
                      00004700    00000100     F2837xS_GlobalVariableDefs.obj (EPwm8RegsFile)
    EPwm9RegsFile
    *          1    00004800    00000100     UNINITIALIZED
                      00004800    00000100     F2837xS_GlobalVariableDefs.obj (EPwm9RegsFile)
    EPwm10RegsFile
    *          1    00004900    00000100     UNINITIALIZED
                      00004900    00000100     F2837xS_GlobalVariableDefs.obj (EPwm10RegsFile)
    EPwm11RegsFile
    *          1    00004a00    00000100     UNINITIALIZED
                      00004a00    00000100     F2837xS_GlobalVariableDefs.obj (EPwm11RegsFile)
    EPwm12RegsFile
    *          1    00004b00    00000100     UNINITIALIZED
                      00004b00    00000100     F2837xS_GlobalVariableDefs.obj (EPwm12RegsFile)
    ECap1RegsFile
    *          1    00005000    00000020     UNINITIALIZED
                      00005000    00000020     F2837xS_GlobalVariableDefs.obj (ECap1RegsFile)
    ECap2RegsFile
    *          1    00005020    00000020     UNINITIALIZED
                      00005020    00000020     F2837xS_GlobalVariableDefs.obj (ECap2RegsFile)
    ECap3RegsFile
    *          1    00005040    00000020     UNINITIALIZED
                      00005040    00000020     F2837xS_GlobalVariableDefs.obj (ECap3RegsFile)
    ECap4RegsFile
    *          1    00005060    00000020     UNINITIALIZED
                      00005060    00000020     F2837xS_GlobalVariableDefs.obj (ECap4RegsFile)
    ECap5RegsFile
    *          1    00005080    00000020     UNINITIALIZED
                      00005080    00000020     F2837xS_GlobalVariableDefs.obj (ECap5RegsFile)
    ECap6RegsFile
    *          1    000050a0    00000020     UNINITIALIZED
                      000050a0    00000020     F2837xS_GlobalVariableDefs.obj (ECap6RegsFile)
    EQep1RegsFile
    *          1    00005100    00000022     UNINITIALIZED
                      00005100    00000022     F2837xS_GlobalVariableDefs.obj (EQep1RegsFile)
    EQep2RegsFile
    *          1    00005140    00000022     UNINITIALIZED
                      00005140    00000022     F2837xS_GlobalVariableDefs.obj (EQep2RegsFile)
    EQep3RegsFile
    *          1    00005180    00000022     UNINITIALIZED
                      00005180    00000022     F2837xS_GlobalVariableDefs.obj (EQep3RegsFile)
    DacaRegsFile
    *          1    00005c00    00000008     UNINITIALIZED
                      00005c00    00000008     F2837xS_GlobalVariableDefs.obj (DacaRegsFile)
    DacbRegsFile
    *          1    00005c10    00000008     UNINITIALIZED
                      00005c10    00000008     F2837xS_GlobalVariableDefs.obj (DacbRegsFile)
    DaccRegsFile
    *          1    00005c20    00000008     UNINITIALIZED
                      00005c20    00000008     F2837xS_GlobalVariableDefs.obj (DaccRegsFile)
    Cmpss1RegsFile
    *          1    00005c80    00000020     UNINITIALIZED
                      00005c80    00000020     F2837xS_GlobalVariableDefs.obj (Cmpss1RegsFile)
    Cmpss2RegsFile
    *          1    00005ca0    00000020     UNINITIALIZED
                      00005ca0    00000020     F2837xS_GlobalVariableDefs.obj (Cmpss2RegsFile)
    Cmpss3RegsFile
    *          1    00005cc0    00000020     UNINITIALIZED
                      00005cc0    00000020     F2837xS_GlobalVariableDefs.obj (Cmpss3RegsFile)
    Cmpss4RegsFile
    *          1    00005ce0    00000020     UNINITIALIZED
                      00005ce0    00000020     F2837xS_GlobalVariableDefs.obj (Cmpss4RegsFile)
    Cmpss5RegsFile
    *          1    00005d00    00000020     UNINITIALIZED
                      00005d00    00000020     F2837xS_GlobalVariableDefs.obj (Cmpss5RegsFile)
    Cmpss6RegsFile
    *          1    00005d20    00000020     UNINITIALIZED
                      00005d20    00000020     F2837xS_GlobalVariableDefs.obj (Cmpss6RegsFile)
    Cmpss7RegsFile
    *          1    00005d40    00000020     UNINITIALIZED
                      00005d40    00000020     F2837xS_GlobalVariableDefs.obj (Cmpss7RegsFile)
    Cmpss8RegsFile
    *          1    00005d60    00000020     UNINITIALIZED
                      00005d60    00000020     F2837xS_GlobalVariableDefs.obj (Cmpss8RegsFile)
    AdcaRegsFile
    *          1    00007400    00000080     UNINITIALIZED
                      00007400    00000080     F2837xS_GlobalVariableDefs.obj (AdcaRegsFile)
    AdcbRegsFile
    *          1    00007480    00000080     UNINITIALIZED
                      00007480    00000080     F2837xS_GlobalVariableDefs.obj (AdcbRegsFile)
    AdccRegsFile
    *          1    00007500    00000080     UNINITIALIZED
                      00007500    00000080     F2837xS_GlobalVariableDefs.obj (AdccRegsFile)
    AdcdRegsFile
    *          1    00007580    00000080     UNINITIALIZED
                      00007580    00000080     F2837xS_GlobalVariableDefs.obj (AdcdRegsFile)
    AnalogSubsysRegsFile
    *          1    0005d180    00000048     UNINITIALIZED
                      0005d180    00000048     F2837xS_GlobalVariableDefs.obj (AnalogSubsysRegsFile)
    Cla1SoftIntRegsFile
    *          1    00000ce0    00000004     DSECT
                      00000ce0    00000004     F2837xS_GlobalVariableDefs.obj (Cla1SoftIntRegsFile)
    Sdfm1RegsFile
    *          1    00005e00    00000080     UNINITIALIZED
                      00005e00    00000080     F2837xS_GlobalVariableDefs.obj (Sdfm1RegsFile)
    Sdfm2RegsFile
    *          1    00005e80    00000080     UNINITIALIZED
                      00005e80    00000080     F2837xS_GlobalVariableDefs.obj (Sdfm2RegsFile)
    McbspaRegsFile
    *          1    00006000    00000024     UNINITIALIZED
                      00006000    00000024     F2837xS_GlobalVariableDefs.obj (McbspaRegsFile)
    McbspbRegsFile
    *          1    00006040    00000024     UNINITIALIZED
                      00006040    00000024     F2837xS_GlobalVariableDefs.obj (McbspbRegsFile)
    SpiaRegsFile
    *          1    00006100    00000010     UNINITIALIZED
                      00006100    00000010     F2837xS_GlobalVariableDefs.obj (SpiaRegsFile)
    SpibRegsFile
    *          1    00006110    00000010     UNINITIALIZED
                      00006110    00000010     F2837xS_GlobalVariableDefs.obj (SpibRegsFile)
    SpicRegsFile
    *          1    00006120    00000010     UNINITIALIZED
                      00006120    00000010     F2837xS_GlobalVariableDefs.obj (SpicRegsFile)
    UppRegsFile
    *          1    00006200    00000048     UNINITIALIZED
                      00006200    00000048     F2837xS_GlobalVariableDefs.obj (UppRegsFile)
    WdRegsFile
    *          1    00007000    0000002b     UNINITIALIZED
                      00007000    0000002b     F2837xS_GlobalVariableDefs.obj (WdRegsFile)
    NmiIntruptRegsFile
    *          1    00007060    00000007     UNINITIALIZED
                      00007060    00000007     F2837xS_GlobalVariableDefs.obj (NmiIntruptRegsFile)
    XintRegsFile
    *          1    00007070    0000000b     UNINITIALIZED
                      00007070    0000000b     F2837xS_GlobalVariableDefs.obj (XintRegsFile)
    SciaRegsFile
    *          1    00007200    00000010     UNINITIALIZED
                      00007200    00000010     F2837xS_GlobalVariableDefs.obj (SciaRegsFile)
    ScibRegsFile
    *          1    00007210    00000010     UNINITIALIZED
                      00007210    00000010     F2837xS_GlobalVariableDefs.obj (ScibRegsFile)
    ScicRegsFile
    *          1    00007220    00000010     UNINITIALIZED
                      00007220    00000010     F2837xS_GlobalVariableDefs.obj (ScicRegsFile)
    ScidRegsFile
    *          1    00007230    00000010     UNINITIALIZED
                      00007230    00000010     F2837xS_GlobalVariableDefs.obj (ScidRegsFile)
    I2caRegsFile
    *          1    00007300    00000022     UNINITIALIZED
                      00007300    00000022     F2837xS_GlobalVariableDefs.obj (I2caRegsFile)
    I2cbRegsFile
    *          1    00007340    00000022     UNINITIALIZED
                      00007340    00000022     F2837xS_GlobalVariableDefs.obj (I2cbRegsFile)
    InputXbarRegsFile
    *          1    00007900    00000020     UNINITIALIZED
                      00007900    00000020     F2837xS_GlobalVariableDefs.obj (InputXbarRegsFile)
    XbarRegsFile
    *          1    00007920    00000020     UNINITIALIZED
                      00007920    00000020     F2837xS_GlobalVariableDefs.obj (XbarRegsFile)
    SyncSocRegsFile
    *          1    00007940    00000006     UNINITIALIZED
                      00007940    00000006     F2837xS_GlobalVariableDefs.obj (SyncSocRegsFile)
    DmaClaSrcSelRegsFile
    *          1    00007980    0000001a     UNINITIALIZED
                      00007980    0000001a     F2837xS_GlobalVariableDefs.obj (DmaClaSrcSelRegsFile)
    EPwmXbarRegsFile
    *          1    00007a00    00000040     UNINITIALIZED
                      00007a00    00000040     F2837xS_GlobalVariableDefs.obj (EPwmXbarRegsFile)
    OutputXbarRegsFile
    *          1    00007a80    00000040     UNINITIALIZED
                      00007a80    00000040     F2837xS_GlobalVariableDefs.obj (OutputXbarRegsFile)
    GpioCtrlRegsFile
    *          1    00007c00    00000180     UNINITIALIZED
                      00007c00    00000180     F2837xS_GlobalVariableDefs.obj (GpioCtrlRegsFile)
    GpioDataRegsFile
    *          1    00007f00    00000030     UNINITIALIZED
                      00007f00    00000030     F2837xS_GlobalVariableDefs.obj (GpioDataRegsFile)
    .ebss      1    0000ac00    000003f6     UNINITIALIZED
                      0000ac00    00000208     serialUART.obj (.ebss)
                      0000ae08    0000001a     adc.obj (.ebss)
                      0000ae22    00000012     dac.obj (.ebss)
                      0000ae34    00000008     rts2800_fpu32.lib : memory.obj (.ebss)
                      0000ae3c    00000002     ADCSource.obj (.ebss)
                      0000ae3e    00000002     ThreePhsSysCoordinator.obj (.ebss)
                      0000ae40    000001a0     epwm_trip_zone.obj (.ebss)
                      0000afe0    00000006     rts2800_fpu32.lib : exit.obj (.ebss)
                      0000afe6    00000005     IOExpander.obj (.ebss)
                      0000afeb    00000002     UARTsrcSnk.obj (.ebss)
                      0000afed    00000001     F2837xS_DefaultISR.obj (.ebss)
                      0000afee    00000002     rts2800_fpu32.lib : _lock.obj (.ebss:__lock)
                      0000aff0    00000002                       : _lock.obj (.ebss:__unlock)
                      0000aff2    00000002                       : vars.obj (.ebss)
                      0000aff4    00000001     ThreePhsSysInput.obj (.ebss)
                      0000aff5    00000001     ThreePhsSysOutput.obj (.ebss)
    Emif1RegsFile
    *          1    00047000    00000070     UNINITIALIZED
                      00047000    00000070     F2837xS_GlobalVariableDefs.obj (Emif1RegsFile)
    Emif2RegsFile
    *          1    00047800    00000070     UNINITIALIZED
                      00047800    00000070     F2837xS_GlobalVariableDefs.obj (Emif2RegsFile)
    FlashPumpSemaphoreRegsFile
    *          1    00050024    00000002     UNINITIALIZED
                      00050024    00000002     F2837xS_GlobalVariableDefs.obj (FlashPumpSemaphoreRegsFile)
    DevCfgRegsFile
    *          1    0005d000    0000012e     UNINITIALIZED
                      0005d000    0000012e     F2837xS_GlobalVariableDefs.obj (DevCfgRegsFile)
    ClkCfgRegsFile
    *          1    0005d200    00000032     UNINITIALIZED
                      0005d200    00000032     F2837xS_GlobalVariableDefs.obj (ClkCfgRegsFile)
    CpuSysRegsFile
    *          1    0005d300    00000082     UNINITIALIZED
                      0005d300    00000082     F2837xS_GlobalVariableDefs.obj (CpuSysRegsFile)
    RomPrefetchRegsFile
    *          1    0005e608    00000002     UNINITIALIZED
                      0005e608    00000002     F2837xS_GlobalVariableDefs.obj (RomPrefetchRegsFile)
    DcsmZ1RegsFile
    *          1    0005f000    00000024     UNINITIALIZED
                      0005f000    00000024     F2837xS_GlobalVariableDefs.obj (DcsmZ1RegsFile)
    DcsmZ2RegsFile
    *          1    0005f040    00000024     UNINITIALIZED
                      0005f040    00000024     F2837xS_GlobalVariableDefs.obj (DcsmZ2RegsFile)
    DcsmCommonRegsFile
    *          1    0005f070    00000008     UNINITIALIZED
                      0005f070    00000008     F2837xS_GlobalVariableDefs.obj (DcsmCommonRegsFile)
    MemCfgRegsFile
    *          1    0005f400    00000080     UNINITIALIZED
                      0005f400    00000080     F2837xS_GlobalVariableDefs.obj (MemCfgRegsFile)
    Emif1ConfigRegsFile
    *          1    0005f480    00000020     UNINITIALIZED
                      0005f480    00000020     F2837xS_GlobalVariableDefs.obj (Emif1ConfigRegsFile)
    Emif2ConfigRegsFile
    *          1    0005f4a0    00000020     UNINITIALIZED
                      0005f4a0    00000020     F2837xS_GlobalVariableDefs.obj (Emif2ConfigRegsFile)
    AccessProtectionRegsFile
    *          1    0005f4c0    00000040     UNINITIALIZED
                      0005f4c0    00000040     F2837xS_GlobalVariableDefs.obj (AccessProtectionRegsFile)
    MemoryErrorRegsFile
    *          1    0005f500    00000040     UNINITIALIZED
                      0005f500    00000040     F2837xS_GlobalVariableDefs.obj (MemoryErrorRegsFile)
    RomWaitStateRegsFile
    *          1    0005f540    00000002     UNINITIALIZED
                      0005f540    00000002     F2837xS_GlobalVariableDefs.obj (RomWaitStateRegsFile)
    Flash0CtrlRegsFile
    *          1    0005f800    00000182     UNINITIALIZED
                      0005f800    00000182     F2837xS_GlobalVariableDefs.obj (Flash0CtrlRegsFile)
    Flash0EccRegsFile
    *          1    0005fb00    00000028     UNINITIALIZED
                      0005fb00    00000028     F2837xS_GlobalVariableDefs.obj (Flash0EccRegsFile)
    Flash1CtrlRegsFile
    *          1    0005fc00    00000182     UNINITIALIZED
                      0005fc00    00000182     F2837xS_GlobalVariableDefs.obj (Flash1CtrlRegsFile)
    Flash1EccRegsFile
    *          1    0005ff00    00000028     UNINITIALIZED
                      0005ff00    00000028     F2837xS_GlobalVariableDefs.obj (Flash1EccRegsFile)
    DcsmZ1OtpFile
    *          1    00078000    00000020     NOLOAD SECTION
                      00078000    00000020     F2837xS_GlobalVariableDefs.obj (DcsmZ1OtpFile)
    DcsmZ2OtpFile
    *          1    00078200    00000020     NOLOAD SECTION
                      00078200    00000020     F2837xS_GlobalVariableDefs.obj (DcsmZ2OtpFile)
    MODULE SUMMARY
           Module                           code    ro data   rw data
           F2837xS_GlobalVariableDefs.obj   0       0         8437
           epwm_trip_zone.obj               1585    0         456
           F2837xS_DefaultISR.obj           1423    0         5
           F2837xS_SysCtrl.obj              1188    0         0
           F2837xS_Gpio.obj                 468     0         0
           F2837xS_PieVect.obj              17      0         448
           F2837xS_Adc.obj                  212     0         0
           F2837xS_PieCtrl.obj              40      0         0
           F2837xS_usDelay.obj              8       0         0
           F2837xS_CodeStartBranch.obj      2       0         0
           Total:                           4943    0         9346
        .\Classes\
           UARTsrcSnk.obj                   1180    0         10
           serialUART.obj                   311     0         540
           ADCSource.obj                    578     0         18
           Transform.obj                    406     0         8
           dac.obj                          316     0         75
           PWMsink.obj                      366     0         8
           ThreePhaseBase.obj               362     0         8
           ThreePhsSysInput.obj             86      0         249
           adc.obj                          203     0         30
           IOExpander.obj                   219     0         13
           DACSink.obj                      164     0         8
           ThreePhsSysCoordinator.obj       150     0         10
           ThreePhsSysOutput.obj            146     0         9
           OnePhaseBase.obj                 121     0         8
           EXTADC.obj                       94      0         8
           EXTADCMAX11605.obj               88      0         8
           SysCommons.obj                   71      0         8
           OnePhsSysInput.obj               35      0         8
           Total:                           4896    0         1026
        C:/ti/ccsv6/tools/compiler/c2000_15.12.3.LTS/lib/rts2800_fpu32.lib
           memory.obj                       466     0         12
           fs_div.obj                       136     0         0
           boot.obj                         86      0         0
           cpy_tbl.obj                      70      0         0
           exit.obj                         41      0         20
           i_div.obj                        34      0         0
           new_.obj                         32      0         0
           memcpy.obj                       30      0         0
           cpy_utils.obj                    26      0         0
           args_main.obj                    25      0         0
           _lock.obj                        9       0         14
           vars.obj                         0       0         7
           delete.obj                       5       0         0
           pre_init.obj                     2       0         0
           newhandler.obj                   1       0         0
           startup.obj                      1       0         0
           Total:                           964     0         53
           Heap:                            0       0         1024
           Stack:                           0       0         256
           Grand Total:                     10803   0         11705
    GLOBAL DATA SYMBOLS: SORTED BY DATA PAGE
    address     data page           name
    00000400      10 (00000400)     __stack
    00000b00      2c (00000b00)     _AdcaResultRegs
    00000b20      2c (00000b00)     _AdcbResultRegs
    00000b40      2d (00000b40)     _AdccResultRegs
    00000b60      2d (00000b40)     _AdcdResultRegs
    00000c00      30 (00000c00)     _CpuTimer0Regs
    00000c08      30 (00000c00)     _CpuTimer1Regs
    00000c10      30 (00000c00)     _CpuTimer2Regs
    00000ce0      33 (00000cc0)     _Cla1SoftIntRegs
    00000ce0      33 (00000cc0)     _PieCtrlRegs
    00000d00      34 (00000d00)     _EmuKey
    00000d00      34 (00000d00)     _PieVectTable
    00000d01      34 (00000d00)     _EmuBMode
    00001000      40 (00001000)     _DmaRegs
    00001400      50 (00001400)     _Cla1Regs
    00004000     100 (00004000)     _EPwm1Regs
    00004100     104 (00004100)     _EPwm2Regs
    00004200     108 (00004200)     _EPwm3Regs
    00004300     10c (00004300)     _EPwm4Regs
    00004400     110 (00004400)     _EPwm5Regs
    00004500     114 (00004500)     _EPwm6Regs
    00004600     118 (00004600)     _EPwm7Regs
    00004700     11c (00004700)     _EPwm8Regs
    00004800     120 (00004800)     _EPwm9Regs
    00004900     124 (00004900)     _EPwm10Regs
    00004a00     128 (00004a00)     _EPwm11Regs
    00004b00     12c (00004b00)     _EPwm12Regs
    00005000     140 (00005000)     _ECap1Regs
    00005020     140 (00005000)     _ECap2Regs
    00005040     141 (00005040)     _ECap3Regs
    00005060     141 (00005040)     _ECap4Regs
    00005080     142 (00005080)     _ECap5Regs
    000050a0     142 (00005080)     _ECap6Regs
    00005100     144 (00005100)     _EQep1Regs
    00005140     145 (00005140)     _EQep2Regs
    00005180     146 (00005180)     _EQep3Regs
    00005c00     170 (00005c00)     _DacaRegs
    00005c10     170 (00005c00)     _DacbRegs
    00005c20     170 (00005c00)     _DaccRegs
    00005c80     172 (00005c80)     _Cmpss1Regs
    00005ca0     172 (00005c80)     _Cmpss2Regs
    00005cc0     173 (00005cc0)     _Cmpss3Regs
    00005ce0     173 (00005cc0)     _Cmpss4Regs
    00005d00     174 (00005d00)     _Cmpss5Regs
    00005d20     174 (00005d00)     _Cmpss6Regs
    00005d40     175 (00005d40)     _Cmpss7Regs
    00005d60     175 (00005d40)     _Cmpss8Regs
    00005e00     178 (00005e00)     _Sdfm1Regs
    00005e80     17a (00005e80)     _Sdfm2Regs
    00006000     180 (00006000)     _McbspaRegs
    00006040     181 (00006040)     _McbspbRegs
    00006100     184 (00006100)     _SpiaRegs
    00006110     184 (00006100)     _SpibRegs
    00006120     184 (00006100)     _SpicRegs
    00006200     188 (00006200)     _UppRegs
    00007000     1c0 (00007000)     _WdRegs
    00007060     1c1 (00007040)     _NmiIntruptRegs
    00007070     1c1 (00007040)     _XintRegs
    00007200     1c8 (00007200)     _SciaRegs
    00007210     1c8 (00007200)     _ScibRegs
    00007220     1c8 (00007200)     _ScicRegs
    00007230     1c8 (00007200)     _ScidRegs
    00007300     1cc (00007300)     _I2caRegs
    00007340     1cd (00007340)     _I2cbRegs
    00007400     1d0 (00007400)     _AdcaRegs
    00007480     1d2 (00007480)     _AdcbRegs
    00007500     1d4 (00007500)     _AdccRegs
    00007580     1d6 (00007580)     _AdcdRegs
    00007900     1e4 (00007900)     _InputXbarRegs
    00007920     1e4 (00007900)     _XbarRegs
    00007940     1e5 (00007940)     _SyncSocRegs
    00007980     1e6 (00007980)     _DmaClaSrcSelRegs
    00007a00     1e8 (00007a00)     _EPwmXbarRegs
    00007a80     1ea (00007a80)     _OutputXbarRegs
    00007c00     1f0 (00007c00)     _GpioCtrlRegs
    00007f00     1fc (00007f00)     _GpioDataRegs
    0000a800     2a0 (0000a800)     __sys_memory
    0000ac00     2b0 (0000ac00)     _writeHead
    0000ac01     2b0 (0000ac00)     _writeTail
    0000ac02     2b0 (0000ac00)     _readTail
    0000ac03     2b0 (0000ac00)     _readHead
    0000ac04     2b0 (0000ac00)     _uartActive
    0000ac40     2b1 (0000ac40)     _RxRingBuffer
    0000ad40     2b5 (0000ad40)     _TxRingBuffer
    0000ae08     2b8 (0000ae00)     _adcACycle
    0000ae09     2b8 (0000ae00)     _currentGroup
    0000ae0a     2b8 (0000ae00)     _adc_I
    0000ae16     2b8 (0000ae00)     _adc_U
    0000ae22     2b8 (0000ae00)     _dacSel
    0000ae23     2b8 (0000ae00)     _dacChnlLoctr
    0000ae24     2b8 (0000ae00)     _currentDACgrp
    0000ae25     2b8 (0000ae00)     _fakeDacVal
    0000ae26     2b8 (0000ae00)     _wordHalf
    0000ae2a     2b8 (0000ae00)     _i_Set
    0000ae2f     2b8 (0000ae00)     _i_Band
    0000ae41     2b9 (0000ae40)     _intFlag
    0000ae43     2b9 (0000ae40)     _aOs
    0000ae4f     2b9 (0000ae40)     _slowBlink
    0000ae54     2b9 (0000ae40)     _tPsCptr
    0000ae56     2b9 (0000ae40)     _isl
    0000ae58     2b9 (0000ae40)     _portPtrOut
    0000ae5a     2b9 (0000ae40)     _grid
    0000ae5c     2b9 (0000ae40)     _bat
    0000ae5e     2b9 (0000ae40)     _p1
    0000ae60     2b9 (0000ae40)     _di
    0000ae62     2b9 (0000ae40)     _p2
    0000ae64     2b9 (0000ae40)     _ioE
    0000ae66     2b9 (0000ae40)     _extDacPtr
    0000ae68     2b9 (0000ae40)     _extAdcPtr
    0000ae6c     2b9 (0000ae40)     _extAdc11605Ptr
    0000ae6e     2b9 (0000ae40)     _ioEIso
    0000ae70     2b9 (0000ae40)     _portPtrIn
    0000ae72     2b9 (0000ae40)     _portPtrInIso
    0000ae74     2b9 (0000ae40)     _portPtrOutIso
    0000ae76     2b9 (0000ae40)     _ePwm_Regs_Ptr_1
    0000ae78     2b9 (0000ae40)     _ePwm_Regs_Ptr_2
    0000ae7a     2b9 (0000ae40)     _urtPtr
    0000ae7c     2b9 (0000ae40)     _adcSptr
    0000ae7e     2b9 (0000ae40)     _dacSptr
    0000ae80     2ba (0000ae80)     _EPwm2TZIntCount
    0000ae82     2ba (0000ae80)     _EPwm1TZIntCount
    0000ae84     2ba (0000ae80)     _ports
    0000ae89     2ba (0000ae80)     _portsIn
    0000ae8e     2ba (0000ae80)     _extDacVals
    0000ae96     2ba (0000ae80)     _CpuTimer0
    0000ae9e     2ba (0000ae80)     _adcDummy
    0000aea6     2ba (0000ae80)     _modFrame
    0000aec0     2bb (0000aec0)     _extAdcVals
    0000aed0     2bb (0000aec0)     _extAdc_11605_Vals
    0000aee0     2bb (0000aec0)     _fO
    0000af00     2bc (0000af00)     _str
    0000af40     2bd (0000af40)     _inputVector
    0000afe0     2bf (0000afc0)     ___TI_enable_exit_profile_output
    0000afe2     2bf (0000afc0)     ___TI_cleanup_ptr
    0000afe4     2bf (0000afc0)     ___TI_dtors_ptr
    0000afee     2bf (0000afc0)     __lock
    0000aff0     2bf (0000afc0)     __unlock
    0000aff2     2bf (0000afc0)     __new_handler
    0000aff4     2bf (0000afc0)     _time
    00047000    11c0 (00047000)     _Emif1Regs
    00047800    11e0 (00047800)     _Emif2Regs
    00050024    1400 (00050000)     _FlashPumpSemaphoreRegs
    0005d000    1740 (0005d000)     _DevCfgRegs
    0005d180    1746 (0005d180)     _AnalogSubsysRegs
    0005d200    1748 (0005d200)     _ClkCfgRegs
    0005d300    174c (0005d300)     _CpuSysRegs
    0005e608    1798 (0005e600)     _RomPrefetchRegs
    0005f000    17c0 (0005f000)     _DcsmZ1Regs
    0005f040    17c1 (0005f040)     _DcsmZ2Regs
    0005f070    17c1 (0005f040)     _DcsmCommonRegs
    0005f400    17d0 (0005f400)     _MemCfgRegs
    0005f480    17d2 (0005f480)     _Emif1ConfigRegs
    0005f4a0    17d2 (0005f480)     _Emif2ConfigRegs
    0005f4c0    17d3 (0005f4c0)     _AccessProtectionRegs
    0005f500    17d4 (0005f500)     _MemoryErrorRegs
    0005f540    17d5 (0005f540)     _RomWaitStateRegs
    0005f800    17e0 (0005f800)     _Flash0CtrlRegs
    0005fb00    17ec (0005fb00)     _Flash0EccRegs
    0005fc00    17f0 (0005fc00)     _Flash1CtrlRegs
    0005ff00    17fc (0005ff00)     _Flash1EccRegs
    00078000    1e00 (00078000)     _DcsmZ1Otp
    00078200    1e08 (00078200)     _DcsmZ2Otp
    00090000    2400 (00090000)     _PieVectTableInit
    000902b0    240a (00090280)     ___vtbl__10ADC_Source
    000902b8    240a (00090280)     ___vtbl__10SysCommons
    000902c0    240b (000902c0)     ___vtbl__10UARTsrcSnk
    000902c8    240b (000902c0)     ___vtbl__11IO_Expander
    000902d0    240b (000902c0)     ___vtbl__12OnePhaseBase
    000902d8    240b (000902c0)     ___vtbl__14OnePhsSysInput
    000902e0    240b (000902c0)     ___vtbl__14ThreePhaseBase
    000902e8    240b (000902c0)     ___vtbl__16EXT_ADC_MAX11605
    000902f0    240b (000902c0)     ___vtbl__16ThreePhsSysInput
    000902f8    240b (000902c0)     ___vtbl__17ThreePhsSysOutput
    00090300    240c (00090300)     ___vtbl__22ThreePhsSysCoordinator
    00090308    240c (00090300)     ___vtbl__7DACSink
    00090310    240c (00090300)     ___vtbl__7EXT_ADC
    00090318    240c (00090300)     ___vtbl__7PWMsink
    00090320    240c (00090300)     ___vtbl__9Transform
    GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
    page  address   name
    abs   ffffffff  .text
    0     00083fbb  C$$EXIT
    0     000845c5  FS$$DIV
    0     00084900  I$$DIV
    0     00084911  I$$MOD
    0     0008262d  _ADCA1_ISR
    0     00082623  _ADCA2_ISR
    0     00082619  _ADCA3_ISR
    0     0008260f  _ADCA4_ISR
    0     00082605  _ADCA_EVT_ISR
    0     000825f1  _ADCB1_ISR
    0     000825e7  _ADCB2_ISR
    0     000825dd  _ADCB3_ISR
    0     000825d3  _ADCB4_ISR
    0     000825c9  _ADCB_EVT_ISR
    0     000825bf  _ADCC1_ISR
    0     000825b5  _ADCC2_ISR
    0     000825ab  _ADCC3_ISR
    0     000825a1  _ADCC4_ISR
    0     00082597  _ADCC_EVT_ISR
    0     0008258d  _ADCD1_ISR
    0     00082583  _ADCD2_ISR
    0     00082579  _ADCD3_ISR
    0     0008256f  _ADCD4_ISR
    0     00082565  _ADCD_EVT_ISR
    0     0008255b  _AUX_PLL_SLIP_ISR
    1     0005f4c0  _AccessProtectionRegs
    0     00084035  _AdcSetMode
    1     00007400  _AdcaRegs
    1     00000b00  _AdcaResultRegs
    1     00007480  _AdcbRegs
    1     00000b20  _AdcbResultRegs
    1     00007500  _AdccRegs
    1     00000b40  _AdccResultRegs
    1     00007580  _AdcdRegs
    1     00000b60  _AdcdResultRegs
    1     0005d180  _AnalogSubsysRegs
    0     00082f9c  _AreFramesAvail__10UARTsrcSnkFv
    0     000831c7  _AuxAuxClkSel
    0     000831e2  _AuxIntOsc2Sel
    0     000831d1  _AuxXtalOscSel
    0     00082551  _CANA0_ISR
    0     00082547  _CANA1_ISR
    0     0008253d  _CANB0_ISR
    0     00082533  _CANB1_ISR
    0     00082529  _CLA1_1_ISR
    0     0008251f  _CLA1_2_ISR
    0     00082515  _CLA1_3_ISR
    0     0008250b  _CLA1_4_ISR
    0     00082501  _CLA1_5_ISR
    0     000824f7  _CLA1_6_ISR
    0     000824ed  _CLA1_7_ISR
    0     000824e3  _CLA1_8_ISR
    0     000824d9  _CLA_OVERFLOW_ISR
    0     000824cf  _CLA_UNDERFLOW_ISR
    0     00084000  _CalAdcINL
    0     0008485b  _CalcCurrentPercentFromAdcDigits__10SysCommonsFUi
    0     000839b3  _CalcCurrentPhase__9TransformFdN21
    0     00082c58  _CalcLRC__10UARTsrcSnkFv
    0     00083d5f  _CalcSinPwm__14ThreePhaseBaseFdT1
    0     00083d43  _CalcSineFormEffFactor__14ThreePhaseBaseFiT1
    0     00084845  _CalcVoltageFromAdcDigits__10SysCommonsFUi
    0     00082db0  _CaptureWrap__10UARTsrcSnkFUi
    0     00082f9a  _CheckParityWord__10UARTsrcSnkFUi
    1     00001400  _Cla1Regs
    0     00000ce0  _Cla1SoftIntRegs
    0     00083fba  _ClearPin__11IO_ExpanderFUiT1
    1     0005d200  _ClkCfgRegs
    0     000844a4  _CloseGridCon__22ThreePhsSysCoordinatorFv
    0     0008449f  _ClosePV1_N__22ThreePhsSysCoordinatorFv
    0     0008449a  _ClosePV1_PN__22ThreePhsSysCoordinatorFv
    0     00084495  _ClosePV1_P__22ThreePhsSysCoordinatorFv
    0     00084490  _ClosePreLoadZwKrs__22ThreePhsSysCoordinatorFv
    1     00005c80  _Cmpss1Regs
    1     00005ca0  _Cmpss2Regs
    1     00005cc0  _Cmpss3Regs
    1     00005ce0  _Cmpss4Regs
    1     00005d00  _Cmpss5Regs
    1     00005d20  _Cmpss6Regs
    1     00005d40  _Cmpss7Regs
    1     00005d60  _Cmpss8Regs
    1     0005d300  _CpuSysRegs
    1     0000ae96  _CpuTimer0
    1     00000c00  _CpuTimer0Regs
    1     00000c08  _CpuTimer1Regs
    1     00000c10  _CpuTimer2Regs
    0     000844cc  _CreateThrePhseSine__17ThreePhsSysOutputFdi
    0     00083306  _CsmUnlock
    0     000824c5  _DATALOG_ISR
    0     000824bb  _DMA_CH1_ISR
    0     000824b1  _DMA_CH2_ISR
    0     000824a7  _DMA_CH3_ISR
    0     0008249d  _DMA_CH4_ISR
    0     00082493  _DMA_CH5_ISR
    0     00082489  _DMA_CH6_ISR
    1     00005c00  _DacaRegs
    1     00005c10  _DacbRegs
    1     00005c20  _DaccRegs
    1     0005f070  _DcsmCommonRegs
    1     00078000  _DcsmZ1Otp
    1     0005f000  _DcsmZ1Regs
    1     00078200  _DcsmZ2Otp
    1     0005f040  _DcsmZ2Regs
    0     000839d9  _Derive__9TransformFd
    1     0005d000  _DevCfgRegs
    0     000830c9  _DisableDog
    0     000832c4  _DisablePeripheralClocks
    1     00007980  _DmaClaSrcSelRegs
    1     00001000  _DmaRegs
    0     0008247f  _ECAP1_ISR
    0     00082475  _ECAP2_ISR
    0     0008246b  _ECAP3_ISR
    0     00082461  _ECAP4_ISR
    0     00082457  _ECAP5_ISR
    0     0008244d  _ECAP6_ISR
    1     00005000  _ECap1Regs
    1     00005020  _ECap2Regs
    1     00005040  _ECap3Regs
    1     00005060  _ECap4Regs
    1     00005080  _ECap5Regs
    1     000050a0  _ECap6Regs
    0     00082443  _EMIF_ERROR_ISR
    0     00082436  _EMPTY_ISR
    0     0008242c  _EMU_ISR
    0     00082422  _EPWM10_ISR
    0     00082418  _EPWM10_TZ_ISR
    0     0008240e  _EPWM11_ISR
    0     00082404  _EPWM11_TZ_ISR
    0     000823fa  _EPWM12_ISR
    0     000823f0  _EPWM12_TZ_ISR
    0     000823e6  _EPWM1_ISR
    0     000823dc  _EPWM1_TZ_ISR
    0     000823d2  _EPWM2_ISR
    0     000823c8  _EPWM2_TZ_ISR
    0     000823be  _EPWM3_ISR
    0     000823b4  _EPWM3_TZ_ISR
    0     000823aa  _EPWM4_ISR
    0     000823a0  _EPWM4_TZ_ISR
    0     00082396  _EPWM5_ISR
    0     0008238c  _EPWM5_TZ_ISR
    0     00082382  _EPWM6_ISR
    0     00082378  _EPWM6_TZ_ISR
    0     0008236e  _EPWM7_ISR
    0     00082364  _EPWM7_TZ_ISR
    0     0008235a  _EPWM8_ISR
    0     00082350  _EPWM8_TZ_ISR
    0     00082346  _EPWM9_ISR
    0     0008233c  _EPWM9_TZ_ISR
    1     00004900  _EPwm10Regs
    1     00004a00  _EPwm11Regs
    1     00004b00  _EPwm12Regs
    1     00004000  _EPwm1Regs
    1     0000ae82  _EPwm1TZIntCount
    1     00004100  _EPwm2Regs
    1     0000ae80  _EPwm2TZIntCount
    1     00004200  _EPwm3Regs
    1     00004300  _EPwm4Regs
    1     00004400  _EPwm5Regs
    1     00004500  _EPwm6Regs
    1     00004600  _EPwm7Regs
    1     00004700  _EPwm8Regs
    1     00004800  _EPwm9Regs
    1     00007a00  _EPwmXbarRegs
    0     00082332  _EQEP1_ISR
    0     00082328  _EQEP2_ISR
    0     0008231e  _EQEP3_ISR
    1     00005100  _EQep1Regs
    1     00005140  _EQep2Regs
    1     00005180  _EQep3Regs
    1     0005f480  _Emif1ConfigRegs
    1     00047000  _Emif1Regs
    1     0005f4a0  _Emif2ConfigRegs
    1     00047800  _Emif2Regs
    1     00000d01  _EmuBMode
    1     00000d00  _EmuKey
    0     000848d4  _EnableInterrupts
    0     00008090  _F28x_usDelay
    0     00082314  _FLASH_CORRECTABLE_ERROR_ISR
    0     0008230a  _FPU_OVERFLOW_ISR
    0     00082300  _FPU_UNDERFLOW_ISR
    0     00082f86  _FeedAnalogVals__10UARTsrcSnkFiUi
    0     00082f72  _FeedBitCodedVals__10UARTsrcSnkFUcUi
    0     00082ad0  _FillValsToString__FPUiPUcl
    0     00083f98  _FinishReadDevice2__11IO_ExpanderFv
    0     00083f91  _FinishReadDevice__11IO_ExpanderFv
    0     00084775  _FinishReadDevice__16EXT_ADC_MAX11605Fv
    0     0008471d  _FinishReadDevice__7EXT_ADCFv
    1     0005f800  _Flash0CtrlRegs
    1     0005fb00  _Flash0EccRegs
    1     0005fc00  _Flash1CtrlRegs
    1     0005ff00  _Flash1EccRegs
    0     0000807c  _FlashOff_Bank0
    0     00008068  _FlashOff_Bank1
    1     00050024  _FlashPumpSemaphoreRegs
    0     00082dc2  _FourAscsToInt16__10UARTsrcSnkFP18int16ToModHexStrct
    0     0008372d  _GPIO_EnableUnbondedIOPullups
    0     00083708  _GPIO_EnableUnbondedIOPullupsFor100Pin
    0     000836ef  _GPIO_EnableUnbondedIOPullupsFor176Pin
    0     000836db  _GPIO_ReadPin
    0     000836b9  _GPIO_SetupLock
    0     00083664  _GPIO_SetupPinMux
    0     000835dd  _GPIO_SetupPinOptions
    0     000835d6  _GPIO_SetupXINT1Gpio
    0     000835cf  _GPIO_SetupXINT2Gpio
    0     000835c8  _GPIO_SetupXINT3Gpio
    0     000835c1  _GPIO_SetupXINT4Gpio
    0     000835ba  _GPIO_SetupXINT5Gpio
    0     000835a0  _GPIO_WritePin
    0     00082da7  _GetAmtOfRxBytes__10UARTsrcSnkFUiT1
    0     00082f6f  _GetFC__10UARTsrcSnkFv
    0     000846c2  _GetI__12OnePhaseBaseFv
    0     00083d40  _GetI__14ThreePhaseBaseFUi
    0     00083f8b  _GetInPort__11IO_ExpanderFUi
    0     00084842  _GetNegZwKrsRawVal__10SysCommonsFv
    0     00083c09  _GetNextPWMregRef__7PWMsinkFv
    0     000839fe  _GetNextPhaseVal__9TransformFdN21
    0     0008355e  _GetNxtAdcIref__10ADC_SourceFv
    0     00083553  _GetNxtAdcUref__10ADC_SourceFv
    0     00082f6e  _GetNxtFrame__10UARTsrcSnkFv
    0     00083f6d  _GetNxtPin__11IO_ExpanderFPPUiPUi
    0     000842d1  _GetNxt_i_Band__7DACSinkFv
    0     000842c6  _GetNxt_i_Set__7DACSinkFv
    0     00083f67  _GetOutPort__11IO_ExpanderFUi
    0     00083c02  _GetPWMregRef__7PWMsinkFUi
    0     0008483f  _GetPosZwKrsRawVal__10SysCommonsFv
    0     000846bf  _GetPwmRegRef__12OnePhaseBaseFv
    0     00083d38  _GetPwmRegRef__14ThreePhaseBaseFUi
    0     00082f4c  _GetRecVal__10UARTsrcSnkFv
    0     0008476b  _GetSpecChnl__16EXT_ADC_MAX11605FUi
    0     00084713  _GetSpecChnl__7EXT_ADCFUi
    0     00083f5c  _GetSpecPin__11IO_ExpanderFPPUiPUi
    0     000842bf  _GetSpec_i_Band__7DACSinkFUi
    0     000842b8  _GetSpec_i_Set__7DACSinkFUi
    0     00083548  _GetSpecificAdcIref__10ADC_SourceFUi
    0     0008353d  _GetSpecificAdcUref__10ADC_SourceFUi
    0     00082f49  _GetStartAdr__10UARTsrcSnkFv
    0     000846b4  _GetU__12OnePhaseBaseFv
    0     00083d30  _GetU__14ThreePhaseBaseFUi
    0     0008448e  _GetZwKrsPreLoadPin__22ThreePhsSysCoordinatorFv
    0     0008448c  _GetZwKrsPreLoadPort__22ThreePhsSysCoordinatorFv
    0     000846a6  _GetZwKrsU__12OnePhaseBaseFv
    1     00007c00  _GpioCtrlRegs
    1     00007f00  _GpioDataRegs
    0     000832f5  _HALT
    0     000832e1  _HIB
    0     00082dba  _HexAsciToDecNibble__10UARTsrcSnkFUc
    0     000822f6  _I2CA_FIFO_ISR
    0     000822ec  _I2CA_ISR
    0     000822e2  _I2CB_FIFO_ISR
    0     000822d8  _I2CB_ISR
    1     00007300  _I2caRegs
    1     00007340  _I2cbRegs
    0     000832bb  _IDLE
    0     000822ce  _ILLEGAL_ISR
    0     000822c4  _IPC0_ISR
    0     000822ba  _IPC1_ISR
    0     000822b0  _IPC2_ISR
    0     000822a6  _IPC3_ISR
    0     0008332f  _InitAdc__10ADC_SourceFv
    0     000831ef  _InitAuxPll
    0     00083aad  _InitEPWMmodules__7PWMsinkFv
    0     00082a99  _InitEPwm1Example__Fv
    0     00082a5d  _InitEPwm2Example__Fv
    0     00082a41  _InitEPwmGpio_TZ__Fv
    0     00008000  _InitFlash_Bank0
    0     00008034  _InitFlash_Bank1
    0     00083569  _InitGpio
    0     000830d6  _InitPeripheralClocks
    0     000848b5  _InitPieCtrl
    0     00084992  _InitPieVectTable
    0     0008317f  _InitSysCtrl
    0     0008300a  _InitSysPll
    0     00082638  _InitTimer_0__Fv
    0     00082a40  _InitTzGpio__Fv
    0     00082b0f  _InitUART__10UARTsrcSnkFv
    0     00082a1b  _Init_I2C__Fv
    0     00084240  _Init__7DACSinkFv
    1     00007900  _InputXbarRegs
    0     00082c32  _Int16To4hexAsciis__10UARTsrcSnkFP18int16ToModHexStrct
    0     0008398e  _Integrator__9TransformFd
    0     000847cc  _IsPhaseLocked__16ThreePhsSysInputFv
    0     00083988  _IsPllSynced__9TransformFv
    0     0008229c  _MCBSPA_RX_ISR
    0     00082292  _MCBSPA_TX_ISR
    0     00082288  _MCBSPB_RX_ISR
    0     0008227e  _MCBSPB_TX_ISR
    1     00006000  _McbspaRegs
    1     00006040  _McbspbRegs
    1     0005f400  _MemCfgRegs
    1     0005f500  _MemoryErrorRegs
    0     00082dd8  _ModToApp_ConvertAndCheckFC1toFC4__10UARTsrcSnkFPUcUiPi
    0     00083961  _MovAvrg__9TransformFd
    0     00082274  _NMI_ISR
    0     0008226a  _NOTUSED_ISR
    0     00082c2a  _NibbleToHexAscii__10UARTsrcSnkFUc
    1     00007060  _NmiIntruptRegs
    0     00083917  _NullMovAvrg__9TransformFv
    0     00084487  _OpenGridCon__22ThreePhsSysCoordinatorFv
    0     00084482  _OpenPV1_N__22ThreePhsSysCoordinatorFv
    0     0008447d  _OpenPV1_PN__22ThreePhsSysCoordinatorFv
    0     00084478  _OpenPV1_P__22ThreePhsSysCoordinatorFv
    0     00084473  _OpenPreLoadZwKrs__22ThreePhsSysCoordinatorFv
    1     00007a80  _OutputXbarRegs
    0     00082260  _PIE_RESERVED_ISR
    0     0008395e  _PLLcontroler__9TransformFdN21
    1     00000ce0  _PieCtrlRegs
    1     00000d00  _PieVectTable
    0     00090000  _PieVectTableInit
    0     00084407  _PutCharPhy
    0     000843dc  _PutCharsPhy
    0     000846a2  _PutDAC_I_Band_Val__12OnePhaseBaseFUi
    0     0008469f  _PutDAC_I_Band__12OnePhaseBaseFPUi
    0     0008468d  _PutDAC_I_Set_Val__12OnePhaseBaseFi
    0     0008468a  _PutDAC_I_Set__12OnePhaseBaseFPUi
    0     00083d25  _PutDACref__14ThreePhaseBaseFPUi
    0     00083cfa  _PutDACval__14ThreePhaseBaseFUii
    0     00083ce7  _PutDutyCyclesToPwmRegs__14ThreePhaseBaseFUlN21
    0     00084687  _PutIref__12OnePhaseBaseFPUi
    0     00083cdc  _PutIref__14ThreePhaseBaseFPUi
    0     0008483d  _PutNegZwKrsRef__10SysCommonsFPUi
    0     00083cd1  _PutNxtPwmRegRef__14ThreePhaseBaseFPVUl
    0     0008483b  _PutPosZwKrsRef__10SysCommonsFPUi
    0     00084684  _PutPwmRegRef__12OnePhaseBaseFPVUl
    0     00084682  _PutUref__12OnePhaseBaseFPUi
    0     00083cc7  _PutUref__14ThreePhaseBaseFPUi
    0     00082256  _RAM_ACCESS_VIOLATION_ISR
    0     0008224c  _RAM_CORRECTABLE_ERROR_ISR
    0     00082242  _RTOS_ISR
    0     00086094  _RamfuncsLoadEnd
    abs   00000094  _RamfuncsLoadSize
    0     00086000  _RamfuncsLoadStart
    0     00008094  _RamfuncsRunEnd
    abs   00000094  _RamfuncsRunSize
    0     00008000  _RamfuncsRunStart
    0     00082e81  _ReadSerial__10UARTsrcSnkFv
    0     00083000  _ReleaseFlashPump
    0     00084402  _ResetTX
    0     00082da4  _ResetTxPp__10UARTsrcSnkFv
    1     0005e608  _RomPrefetchRegs
    1     0005f540  _RomWaitStateRegs
    0     00084443  _RunCoordinator__22ThreePhsSysCoordinatorFv
    0     000847af  _RunRefSys__16ThreePhsSysInputFv
    0     00083c4e  _RunRmsFilter__14ThreePhaseBaseFv
    0     0008467a  _Run__12OnePhaseBaseFv
    0     0008434c  _RxInt
    1     0000ac40  _RxRingBuffer
    0     00082238  _SCIA_RX_ISR
    0     0008222e  _SCIA_TX_ISR
    0     00082224  _SCIB_RX_ISR
    0     0008221a  _SCIB_TX_ISR
    0     00082210  _SCIC_RX_ISR
    0     00082206  _SCIC_TX_ISR
    0     000821fc  _SCID_RX_ISR
    0     000821f2  _SCID_TX_ISR
    0     000821e8  _SD1_ISR
    0     000821de  _SD2_ISR
    0     000821d4  _SPIA_RX_ISR
    0     000821ca  _SPIA_TX_ISR
    0     000821c0  _SPIB_RX_ISR
    0     000821b6  _SPIB_TX_ISR
    0     000821ac  _SPIC_RX_ISR
    0     000821a2  _SPIC_TX_ISR
    0     00082ff5  _STANDBY
    0     00082198  _SYS_PLL_SLIP_ISR
    1     00007200  _SciaRegs
    1     00007210  _ScibRegs
    1     00007220  _ScicRegs
    1     00007230  _ScidRegs
    1     00005e00  _Sdfm1Regs
    1     00005e80  _Sdfm2Regs
    0     00082fe3  _SeizeFlashPump_Bank0
    0     00082fd1  _SeizeFlashPump_Bank1
    0     00082d05  _SendAnalogModBusDatas__10UARTsrcSnkFUi
    0     00082c64  _SendBitCodedModBusDatas__10UARTsrcSnkFUi
    0     000843f6  _SendCharPhy
    0     00082c27  _SendChar__10UARTsrcSnkFUc
    0     000843f1  _SendCharsPhy
    0     00082c23  _SendChars__10UARTsrcSnkFPUcUi
    0     00082fc3  _ServiceDog
    0     00084441  _SetMyInputSys__22ThreePhsSysCoordinatorFP16ThreePhsSysInput
    0     0008443f  _SetMyOutputSys__22ThreePhsSysCoordinatorFP17ThreePhsSysOutput
    0     00083f5b  _SetPin__11IO_ExpanderFUiT1
    0     00084675  _SetPwm__12OnePhaseBaseFUi
    0     0008443b  _SetUsollOut__22ThreePhsSysCoordinatorFi
    0     00082c18  _Sg16BitValToString__10UARTsrcSnkFlPUc
    1     00006100  _SpiaRegs
    1     00006110  _SpibRegs
    1     00006120  _SpicRegs
    0     00084960  _StartCon
    0     0008353a  _StartCycle__10ADC_SourceFv
    0     000842b5  _StartCycle__7DACSinkFv
    0     000845a5  _StartDACcycle
    0     00083f50  _StartReadDevice__11IO_ExpanderFv
    0     00084761  _StartReadDevice__16EXT_ADC_MAX11605Fv
    0     00084709  _StartReadDevice__7EXT_ADCFv
    0     0008438d  _StartTrans
    0     00082c15  _Start__10UARTsrcSnkFv
    1     00007940  _SyncSocRegs
    0     00082fb9  _SysIntOsc1Sel
    0     00082faf  _SysIntOsc2Sel
    0     00082fa3  _SysXtalOscSel
    0     0008218e  _TIMER0_ISR
    0     00082184  _TIMER1_ISR
    0     0008217a  _TIMER2_ISR
    0     00084379  _TransfHwfifoToSwBuf
    0     00084747  _TransferRes__16EXT_ADC_MAX11605Fv
    0     000846e9  _TransferRes__7EXT_ADCFv
    0     000842dc  _TxInt
    1     0000ad40  _TxRingBuffer
    0     00082170  _UPPA_ISR
    0     00082166  _USBA_ISR
    0     0008215c  _USER10_ISR
    0     00082152  _USER11_ISR
    0     00082148  _USER12_ISR
    0     0008213e  _USER1_ISR
    0     00082134  _USER2_ISR
    0     0008212a  _USER3_ISR
    0     00082120  _USER4_ISR
    0     00082116  _USER5_ISR
    0     0008210c  _USER6_ISR
    0     00082102  _USER7_ISR
    0     000820f8  _USER8_ISR
    0     000820ee  _USER9_ISR
    0     00082bac  _Unsg16BitValToString__10UARTsrcSnkFUlPUc
    1     00006200  _UppRegs
    0     000820e4  _VCU_ISR
    0     000820da  _WAKE_ISR
    1     00007000  _WdRegs
    0     0008453b  _WriteDACtoFIFO
    0     00083f41  _WriteDevice__11IO_ExpanderFv
    0     00083f2e  _WritePort__11IO_ExpanderFUi
    0     000820d0  _XINT1_ISR
    0     000820c6  _XINT2_ISR
    0     000820bc  _XINT3_ISR
    0     000820b2  _XINT4_ISR
    0     000820a8  _XINT5_ISR
    1     00007920  _XbarRegs
    1     00007070  _XintRegs
    1     00000500  __STACK_END
    abs   00000100  __STACK_SIZE
    abs   00000400  __SYSMEM_SIZE
    1     0000afe2  ___TI_cleanup_ptr
    1     0000afe4  ___TI_dtors_ptr
    1     0000afe0  ___TI_enable_exit_profile_output
    abs   ffffffff  ___TI_pprof_out_hndl
    abs   ffffffff  ___TI_prof_data_size
    abs   ffffffff  ___TI_prof_data_start
    abs   ffffffff  ___binit__
    abs   ffffffff  ___c_args__
    0     00082000  ___cinit__
    0     00083527  ___ct__10ADC_SourceFv
    0     00084830  ___ct__10SysCommonsFv
    0     00082b59  ___ct__10UARTsrcSnkFv
    0     00083ee8  ___ct__11IO_ExpanderFUiUcN42
    0     0008465e  ___ct__12OnePhaseBaseFv
    0     000848ee  ___ct__14OnePhsSysInputFv
    0     00083c25  ___ct__14ThreePhaseBaseFv
    0     0008472c  ___ct__16EXT_ADC_MAX11605FUc
    0     00084793  ___ct__16ThreePhsSysInputFv
    0     000844ba  ___ct__17ThreePhsSysOutputFv
    0     0008441b  ___ct__22ThreePhsSysCoordinatorFv
    0     000842a1  ___ct__7DACSinkFv
    0     000846ce  ___ct__7EXT_ADCFUc
    0     00083bf3  ___ct__7PWMsinkFv
    0     0008391f  ___ct__9TransformFv
    0     00082637  ___default_new_handler__Fv
    0     000849ac  ___dl__FPv
    0     00083327  ___dt__10ADC_SourceFv
    0     00084828  ___dt__10SysCommonsFv
    0     00082b07  ___dt__10UARTsrcSnkFv
    0     00083ee0  ___dt__11IO_ExpanderFv
    0     0008464d  ___dt__12OnePhaseBaseFv
    0     000848dd  ___dt__14OnePhsSysInputFv
    0     00083c14  ___dt__14ThreePhaseBaseFv
    0     00084724  ___dt__16EXT_ADC_MAX11605Fv
    0     0008477c  ___dt__16ThreePhsSysInputFv
    0     000844a9  ___dt__17ThreePhsSysOutputFv
    0     00084413  ___dt__22ThreePhsSysCoordinatorFv
    0     00084238  ___dt__7DACSinkFv
    0     000846c6  ___dt__7EXT_ADCFv
    0     00083aa5  ___dt__7PWMsinkFv
    0     0008390f  ___dt__9TransformFv
    abs   ffffffff  ___etext__
    0     00084922  ___nw__FUl
    abs   ffffffff  ___pinit__
    abs   ffffffff  ___text__
    0     000902b0  ___vtbl__10ADC_Source
    0     000902b8  ___vtbl__10SysCommons
    0     000902c0  ___vtbl__10UARTsrcSnk
    0     000902c8  ___vtbl__11IO_Expander
    0     000902d0  ___vtbl__12OnePhaseBase
    0     000902d8  ___vtbl__14OnePhsSysInput
    0     000902e0  ___vtbl__14ThreePhaseBase
    0     000902e8  ___vtbl__16EXT_ADC_MAX11605
    0     000902f0  ___vtbl__16ThreePhsSysInput
    0     000902f8  ___vtbl__17ThreePhsSysOutput
    0     00090300  ___vtbl__22ThreePhsSysCoordinator
    0     00090308  ___vtbl__7DACSink
    0     00090310  ___vtbl__7EXT_ADC
    0     00090318  ___vtbl__7PWMsink
    0     00090320  ___vtbl__9Transform
    0     00084979  __args_main
    1     0000afee  __lock
    1     0000aff2  __new_handler
    0     000849ab  __nop
    0     000849a7  __register_lock
    0     000849a3  __register_unlock
    1     00000400  __stack
    1     0000a800  __sys_memory
    0     00083c13  __system_post_cinit
    0     00083ffe  __system_pre_init
    1     0000aff0  __unlock
    1     0000ae43  _aOs
    0     00083fbb  _abort
    1     0000ae08  _adcACycle
    0     000840d4  _adcAint
    1     0000ae9e  _adcDummy
    1     0000ae7c  _adcSptr
    1     0000ae0a  _adc_I
    1     0000ae16  _adc_U
    1     0000ae5c  _bat
    0     000847d2  _c_int00
    0     000838f8  _calloc
    0     000838f6  _chkheap
    0     0008486f  _copy_in
    0     00083dd8  _cpu_timer0_isr__Fv
    1     0000ae24  _currentDACgrp
    1     0000ae09  _currentGroup
    1     0000ae23  _dacChnlLoctr
    1     0000ae22  _dacSel
    1     0000ae7e  _dacSptr
    0     00083fe4  _ddcopy
    1     0000ae60  _di
    0     00083fe4  _dpcopy
    1     0000ae76  _ePwm_Regs_Ptr_1
    1     0000ae78  _ePwm_Regs_Ptr_2
    0     00083dc2  _epwm1_tzint_isr__Fv
    0     00083d7e  _epwm2_tzint_isr__Fv
    0     00083fbd  _exit
    1     0000ae6c  _extAdc11605Ptr
    1     0000ae68  _extAdcPtr
    1     0000aec0  _extAdcVals
    1     0000aed0  _extAdc_11605_Vals
    1     0000ae66  _extDacPtr
    1     0000ae8e  _extDacVals
    1     0000aee0  _fO
    1     0000ae25  _fakeDacVal
    0     0008373d  _free
    0     000838d8  _free_memory
    0     000829f3  _genInputVector__FPfi
    1     0000ae5a  _grid
    1     0000ae2f  _i_Band
    1     0000ae2a  _i_Set
    1     0000af40  _inputVector
    1     0000ae41  _intFlag
    1     0000ae64  _ioE
    1     0000ae6e  _ioEIso
    1     0000ae56  _isl
    0     00082674  _main
    0     000837a6  _malloc
    0     000838b6  _max_free
    0     00084942  _memcpy
    0     00083781  _minit
    1     0000aea6  _modFrame
    1     0000ae5e  _p1
    1     0000ae62  _p2
    0     00083fe4  _pdcopy
    1     0000ae70  _portPtrIn
    1     0000ae72  _portPtrInIso
    1     0000ae58  _portPtrOut
    1     0000ae74  _portPtrOutIso
    1     0000ae84  _ports
    1     0000ae89  _portsIn
    0     00083fe4  _ppcopy
    1     0000ac03  _readHead
    1     0000ac02  _readTail
    0     00083804  _realloc
    1     0000ae4f  _slowBlink
    0     00084186  _spiAint
    1     0000af00  _str
    1     0000ae54  _tPsCptr
    1     0000aff4  _time
    1     0000ac04  _uartActive
    1     0000ae7a  _urtPtr
    1     0000ae26  _wordHalf
    1     0000ac00  _writeHead
    1     0000ac01  _writeTail
    abs   ffffffff  binit
    0     00082000  cinit
    0     00080000  code_start
    abs   ffffffff  etext
    abs   ffffffff  pinit
    GLOBAL SYMBOLS: SORTED BY Symbol Address
    page  address   name
    0     00082000  cinit
    0     000820e4  _VCU_ISR
    0     000821de  _SD2_ISR
    0     000821e8  _SD1_ISR
    0     00082274  _NMI_ISR
    0     0008242c  _EMU_ISR
    0     00082674  _main
    0     00082ff5  _STANDBY
    0     000832bb  _IDLE
    0     000832e1  _HIB
    0     000832f5  _HALT
    0     0008373d  _free
    0     00083781  _minit
    0     000837a6  _malloc
    0     00083804  _realloc
    0     000838f6  _chkheap
    0     000838f8  _calloc
    0     00083fbb  C$$EXIT
    0     00083fbb  _abort
    0     00083fbd  _exit
    0     00083fe4  _ddcopy
    0     00083fe4  _dpcopy
    0     00083fe4  _pdcopy
    0     00083fe4  _ppcopy
    0     000840d4  _adcAint
    0     00084186  _spiAint
    0     000842dc  _TxInt
    0     0008434c  _RxInt
    0     00084402  _ResetTX
    0     000845c5  FS$$DIV
    0     000847d2  _c_int00
    0     0008486f  _copy_in
    0     00084900  I$$DIV
    0     00084911  I$$MOD
    0     00084942  _memcpy
    0     000849ab  __nop
    1     00000400  __stack
    1     00000d00  _EmuKey
    1     00001000  _DmaRegs
    1     00006200  _UppRegs
    1     00007000  _WdRegs
    1     0000ae0a  _adc_I
    1     0000ae16  _adc_U
    1     0000ae22  _dacSel
    1     0000ae2a  _i_Set
    1     0000ae2f  _i_Band
    1     0000ae41  _intFlag
    1     0000ae43  _aOs
    1     0000ae54  _tPsCptr
    1     0000ae56  _isl
    1     0000ae5a  _grid
    1     0000ae5c  _bat
    1     0000ae5e  _p1
    1     0000ae60  _di
    1     0000ae62  _p2
    1     0000ae64  _ioE
    1     0000ae6e  _ioEIso
    1     0000ae7a  _urtPtr
    1     0000ae7c  _adcSptr
    1     0000ae7e  _dacSptr
    1     0000ae84  _ports
    1     0000ae89  _portsIn
    1     0000aee0  _fO
    1     0000af00  _str
    1     0000afee  __lock
    1     0000aff0  __unlock
    1     0000aff4  _time
    abs   ffffffff  .text
    abs   ffffffff  binit
    abs   ffffffff  etext
    abs   ffffffff  pinit
    [592 symbols]
  • Thanks for the information. What is the scope of the array? Is it declared globally? Locally?
    I know you said when you hit run the application crashes. If you were to place some breakpoints or step through the code, can you get an idea of where exactly the crash happens?
    Whitney
    The array is a local array in the private declaration area of a C++ class without any type specifiers like "static", "volatile"
    The class is instance is made at the beginning of the main() function.
    The debuggers virtual Programpointer doesn´t even reach the instantiation of the class. It opens a window saying "No source for available for
    0x3fe493
    a few lines of the disassambly :
    3fe493:   7625        ESTOP0
    3fe494:   6F00        SB           0, UNC
    3fe495:   761B        ASP
    3fe496:   FFF0        PUSH         RB
    3fe497:   0005        PUSH         AR1H:AR0H
    3fe498:   ABBD        MOVL         *SP++, XT
    3fe499:   A8BD        MOVL         *SP++, XAR4
    3fe49a:   A0BD        MOVL         *SP++, XAR5
    3fe49b:   C2BD        MOVL         *SP++, XAR6
    3fe49c:   C3BD        MOVL         *SP++, XAR7
    3fe49d:   E20000BD    MOV32        *SP++, STF
    3fe49f:   E20300BD    MOV32        *SP++, R0H
    3fe4a1:   E20301BD    MOV32        *SP++, R1H
    In the console is written
    "C28xx_CPU1: AutoRun: Target not run as breakpoint could not be set: Error enabling this function: This task cannot be accomplished with the existing AET resources."
    If i run the application without breakpoints, the results are the same.
    best regards,
    Jasson
  • In reply to user4221161:
    Okay, that address is the ITRAP interrupt handler in the boot ROM, meaning an invalid instruction was fetched. It's not uncommon for that to happen when your stack overflows. That seems plausible given that the problem depends on the size of a local variable.
    Can you try making the stack bigger and see if that helps? If you don't know already how to do that, it's in Properties->Build->C2000 Linker->Basic Options.
    Whitney
    Is your instance inside main or outside?  If it's inside, your stack will have to be huge.
    Hello Whitney,
    i have found, which original .cmd file is used
    2837xS_Generic_FLASH_lnk_ori.txt
    As you can see from the naming, i have post-indexed it with an _ori, meaning original, since i have edited it.
    As suggested, i changed the stack size in the CCS. It was x100. First i changed it to x400 which is the size of the RAMM1.
    Since that didn´t worked (still the ETrap) i also moved RAMM0 from PAGE 0 to PAGE 1 and ored it with RAMM1 in the SECTIONS area of the file.
    Current .cmd file:
    2837xS_Generic_FLASH_lnk.txt
    Now i can´t compile and i get the message
    ""C:/ti/controlSUITE/device_support/F2837xS/v210/F2837xS_common/cmd/2837xS_Generic_FLASH_lnk.cmd", line 66: error #10099-D:
       program will not fit into available memory.  run placement with
       alignment/blocking fails for section ".stack" size 0x6de page 1.  Available
       memory ranges:
       RAMM0        size: 0x2de        unused: 0x2de        max hole: 0x2de
       RAMM1        size: 0x400        unused: 0x400        max hole: 0x400
    error #10010: errors encountered during linking; "SW_Board_02.out" not built"
    Does this mean the programm doesn´t fit in the assigned flash memory? The assigned flash memories are
    .text               : >> FLASHB | FLASHC | FLASHD | FLASHE      PAGE = 0, ALIGN(4)
    according to the memory map it results in an available space of   dec.57344  | hex.E000 bytes of flash.
    I´m not sure, if i read the memory map file correct - there is a area with a head line "Module Summary" with a clolumn "code"
    giving a "Grand Total" of 10302. Does this mean, the overall code size is 10,302 bytes?
    SW_Board_02_MAP.txt
    ...i see now, my thought with "oring" the RAMS is wrong.
    I uncommented the RAMGS blocks 6 to 9 and defined an space named "STACK_RAM" which has the starting adress of RAMGS6 and the length of RAMGS6 to RAMGS9 combined.
    Also i defined a stack size of h.4000 in the CCS and i can see a stack of h.4000 in the map file.
    But i have still the same effect, that the application goes to E-Trap16kOfRamCMDfile.txt
    SW_Board_02_16k_MapFile.txt
    I figured out, that the system behaves differentely if i run the application by pressing the green triangle "run" button, or if i go step by step (Step into with F5).
    With the run button, the application ends in the E-Trap at [3fe493:   7625        ESTOP0 ]
    If i go step by step, it ends at 0x0 when leaving the constructor of a basecalss used in the very first instance of an object in the beginning of main();.
    The instance at the beginning of main is "OnePhsSysInput".
    "OnePhsSysInput" inherits from  "OnePhaseBase" which in turn inherits from "SysCommons" which implements an interface "I_SysCommons("OnePhsSysInput" -> "OnePhaseBase" -> "SysCommons")
    The app chrashes when leaving the constructor of OnePhaseBase
    I have bunddled the files ina  .7z zipped file
    InputSystems.7z
    What happens if you declare the object globally rather than in main on the stack?
