Other Parts Discussed in Thread: CONTROLSUITE
Hello Champs,
I have tested on F28027 Launchpad that if the PC(host) baud rate has been set as integer multiple of the SCI baud rate, for example, the host is 115200 and F28027 SCI is 9600 (115200/9600 = 12), the SCI frame error bit will be seldom set, that is to say, at most conditions there is no frame error and also no any other SCI errors while at the same time the received error is wrong.
Would you please kindly suggest how to recognize this kind of error without any error bit set? Thanks!
Linda
