Other Parts Discussed in Thread: CONTROLSUITE
I'm trying to use the uIP example for the master core v210. It works but now I need a UDP connection just to send some sensor data. I saw that the example stabilish a TCP connection but I can't see where the Texas put the option to stabilish a UDP connection. I saw also in the example that if a UDP package arrives, it tests the udp port but it is always 0, so, it will never calls the UIP_UDP_APPCALL. I looked for the call for uip_udp_connect() but I can't find.
Thank you.
