Hello
configured the TZ in my program like this when i run it with out SC the TZ GPIO24 or 59
it is tripping (no PWM wave), that means it is not entering to ISR
#include "F28x_Project.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
#define PWM_Prd 10000;
#define Phi1 1500; // (625)45 DEG PHASE
#define Phi2 1500; // (625)45 DEG PHASE
#define PI 3.14159265358979323846
//Uint32 EPwm1TZIntCount;
//Uint32 EPwm2TZIntCount;
//void InitTzGpio(void);
void InitEPwm1_2Example(void);
void LED_init(); //LED on control card
//void InitEPwm2Example(void);//void InitEPwm3Example(void);//void InitEPwm4Example(void);//void InitEPwm5Example(void);//void InitEPwm6Example(void);
//void InitEPwmGpio_TZ(void);
__interrupt void epwm1_isr(void);
unsigned int i=0,m=0,k=0;
unsigned int a=0;
unsigned int b[101]={0};
void main(void)
InitSysCtrl();
for(m=0;m<100;m++)
a=sin(PI*0.02*m);
b[m]= 5000*a + 5000; //50% HALF SINE WAVE cycle.
b[100]=0;
InitGpio();
EALLOW;
InitEPwm1Gpio();
InitEPwm2Gpio();
InitEPwm3Gpio();
InitEPwm4Gpio();
InitEPwm5Gpio();
InitEPwm6Gpio();
// InitTzGpio(); //TZ1 = GPIO12, TZ2 = GPIO13
// InitEPwmGpio_TZ();
//GpioCtrlRegs.GPBDIR.bit.GPIO52 = 1;
EDIS;
DINT;
InitPieCtrl();
IER = 0x0000;
IFR = 0x0000;
InitPieVectTable();
EALLOW;
PieVectTable.EPWM1_INT = &epwm1_isr;
InitEPwm1_2Example();
//InitEPwm2Example();//InitEPwm3Example();//InitEPwm4Example(); //InitEPwm5Example(); //InitEPwm6Example();
EDIS;
IER |= M_INT3;
PieCtrlRegs.PIEIER3.bit.INTx1 = 1;
PieCtrlRegs.PIEIER3.bit.INTx2 = 1;
PieCtrlRegs.PIEIER3.bit.INTx3 = 1;
EINT; // Enable Global interrupt INTM
ERTM; // Enable Global realtime interrupt DBGM
for(;;)
asm (" NOP");
GpioDataRegs.GPBDAT.bit.GPIO52 = 1;
GpioCtrlRegs.GPAMUX2.bit.GPIO26 = 1; // GPIO26 = GPIO26 //GREEN_1
if (EPwm1Regs.TZFLG.bit.OST == 0 && EPwm2Regs.TZFLG.bit.OST == 0)
{//IF#1 No fault,perform the ISR
a=sin(PI*0.02*i);
if (a>=0)
{//if#2
EPwm1Regs.CMPA.bit.CMPA =b[i]; //EPwm1Regs.CMPB.bit.CMPB =b[i];
EPwm2Regs.CMPA.bit.CMPA =b[i]; // EPwm2Regs.CMPB.bit.CMPB =b[i];
EPwm3Regs.CMPA.bit.CMPA =b[i]; // EPwm3Regs.CMPB.bit.CMPB =b[i];
EPwm4Regs.CMPA.bit.CMPA =b[i]; // EPwm4Regs.CMPB.bit.CMPB =b[i];
EPwm5Regs.CMPA.bit.CMPA =b[i];// EPwm5Regs.CMPB.bit.CMPB =b[i];
EPwm6Regs.CMPA.bit.CMPA =b[i];// EPwm6Regs.CMPB.bit.CMPB =b[i];
else
{//else for if#2
EPwm1Regs.CMPA.bit.CMPA =b[i];// EPwm1Regs.CMPB.bit.CMPB =b[i];
EPwm2Regs.CMPA.bit.CMPA =b[i];// EPwm2Regs.CMPB.bit.CMPB =b[i];
EPwm3Regs.CMPA.bit.CMPA =b[i];// EPwm3Regs.CMPB.bit.CMPB =b[i];
EPwm4Regs.CMPA.bit.CMPA =b[i];// EPwm4Regs.CMPB.bit.CMPB =b[i];
}//end of else for if#2
i++;
if (i==101)
{ //if#3
i=0; }//end of if#3
EALLOW;
//EPwm1Regs.TZCLR.bit.OST = 1;
//EPwm1Regs.TZCLR.bit.INT = 1;
EDIS;
PieCtrlRegs.PIEACK.all = PIEACK_GROUP3;
GpioDataRegs.GPBDAT.bit.GPIO52 = 0;
}//end of if#1 TZ1 for Pwm rectifier fault
else //one-shot fault
{//else for if#1
GpioCtrlRegs.GPAMUX2.bit.GPIO25 = 1; // GPIO25 = GPIO25 //RED
}//end of else for if#1
}//end of ISR
void InitEPwm1_2Example()
GpioCtrlRegs.GPAMUX2.bit.GPIO27 = 1; // GPIO27 = GPIO27 //GREEN_2 this led is glowing
// // Setup counter mode //
EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; // Count up and down
EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Disable phase loading
EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO;
// Clock Settings
ClkCfgRegs.SYSCLKDIVSEL.bit.PLLSYSCLKDIV =0;
ClkCfgRegs.PERCLKDIVSEL.bit.EPWMCLKDIV=0;
EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1;
// // Setup shadowing //
EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_IMMEDIATE;
EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_IMMEDIATE;
// Set compare A value
EPwm1Regs.AQCTLA.bit.PRD = AQ_SET; // Set PWM1A on event A, up
EPwm1Regs.AQCTLA.bit.CAU = AQ_CLEAR; // Clear PWM1A on event B, down
EPwm1Regs.AQCTLB.bit.CBU = AQ_SET; // Set PWM1B on event A, up
EPwm1Regs.AQCTLB.bit.PRD = AQ_CLEAR; // Clear PWM1B on event B, down
//PWM settings
EPwm1Regs.TBPRD = PWM_Prd; // Set timer period 801 TBCLKs
EPwm1Regs.TBPHS.bit.TBPHS = 0; // Phase is 0
EPwm1Regs.TBCTR = 0;
EPwm2Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; // Count up and down
EPwm2Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Disable phase loading
EPwm2Regs.TBCTL.bit.PRDLD = TB_SHADOW;
EPwm2Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;
EPwm2Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm2Regs.TBCTL.bit.CLKDIV = TB_DIV1;
EPwm2Regs.CMPCTL.bit.SHDWAMODE = CC_IMMEDIATE;
EPwm2Regs.CMPCTL.bit.SHDWBMODE = CC_IMMEDIATE;
// // Set actions //
EPwm2Regs.AQCTLA.bit.PRD = AQ_CLEAR; // Set PWM1A on event A, up
EPwm2Regs.AQCTLA.bit.CAU = AQ_SET; // Clear PWM1A on event B, down
EPwm2Regs.AQCTLB.bit.PRD = AQ_SET; // Set PWM1B on event A, up
EPwm2Regs.AQCTLB.bit.CBU = AQ_CLEAR; // Clear PWM1B on event B, down
EPwm2Regs.TBPRD = PWM_Prd; // Set timer period 801 TBCLKs
EPwm2Regs.TBPHS.bit.TBPHS = 0; // Phase is 0
EPwm2Regs.TBCTR = 0;
EPwm3Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; // Count up and down
EPwm3Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Disable phase loading
EPwm3Regs.TBCTL.bit.PRDLD = TB_SHADOW;
EPwm3Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;
EPwm3Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm3Regs.TBCTL.bit.CLKDIV = TB_DIV1;
EPwm3Regs.CMPCTL.bit.SHDWAMODE = CC_IMMEDIATE;
EPwm3Regs.CMPCTL.bit.SHDWBMODE = CC_IMMEDIATE;
EPwm3Regs.AQCTLA.bit.PRD = AQ_SET; // Set PWM1A on event A, up
EPwm3Regs.AQCTLA.bit.CAU = AQ_CLEAR; // Clear PWM1A on event B, down
EPwm3Regs.AQCTLB.bit.PRD = AQ_CLEAR; // Set PWM1B on event A, up
EPwm3Regs.AQCTLB.bit.CBU = AQ_SET; // Clear PWM1B on event B, down
EPwm3Regs.TBPRD = PWM_Prd; // Set timer period 801 TBCLKs
EPwm3Regs.TBPHS.bit.TBPHS = 10000 - Phi1; // Phase is 0
EPwm3Regs.TBCTR = 0;
EPwm4Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; // Count up and down
EPwm4Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Disable phase loading
EPwm4Regs.TBCTL.bit.PRDLD = TB_SHADOW;
EPwm4Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;
EPwm4Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm4Regs.TBCTL.bit.CLKDIV = TB_DIV1;
EPwm4Regs.CMPCTL.bit.SHDWAMODE = CC_IMMEDIATE;
EPwm4Regs.CMPCTL.bit.SHDWBMODE = CC_IMMEDIATE;
EPwm4Regs.AQCTLA.bit.PRD = AQ_CLEAR; // Set PWM1A on event A, up
EPwm4Regs.AQCTLA.bit.CAU = AQ_SET; // Clear PWM1A on event B, down
EPwm4Regs.AQCTLB.bit.PRD = AQ_SET; // Set PWM1B on event A, up
EPwm4Regs.AQCTLB.bit.CBU = AQ_CLEAR; // Clear PWM1B on event B, down
EPwm4Regs.TBPRD = PWM_Prd; // Set timer period 801 TBCLKs
EPwm4Regs.TBPHS.bit.TBPHS = 10000-Phi1; // Phase is 0
EPwm4Regs.TBCTR = 0;
EPwm5Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; // Count up and down EPwm5Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Disable phase loading
EPwm5Regs.TBCTL.bit.PRDLD = TB_SHADOW;
EPwm5Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;
EPwm5Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm5Regs.TBCTL.bit.CLKDIV = TB_DIV1;
EPwm5Regs.CMPCTL.bit.SHDWAMODE = CC_IMMEDIATE;
EPwm5Regs.CMPCTL.bit.SHDWBMODE = CC_IMMEDIATE;
EPwm5Regs.AQCTLA.bit.PRD = AQ_SET; // Set PWM1A on event A, up
EPwm5Regs.AQCTLA.bit.CAU = AQ_CLEAR; // Clear PWM1A on event B, down
EPwm5Regs.AQCTLB.bit.CBU = AQ_SET; // Set PWM1B on event A, up
EPwm5Regs.AQCTLB.bit.PRD = AQ_CLEAR; // Clear PWM1B on event B, down
EPwm5Regs.TBPRD = PWM_Prd; // Set timer period 801 TBCLKs
EPwm5Regs.TBPHS.bit.TBPHS = 10000 - Phi2; // Phase is 0
EPwm5Regs.TBCTR = 0;
EPwm6Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; // Count up and down
EPwm6Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Disable phase loading
EPwm6Regs.TBCTL.bit.PRDLD = TB_SHADOW;
EPwm6Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;
EPwm6Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm6Regs.TBCTL.bit.CLKDIV = TB_DIV1;
EPwm6Regs.CMPCTL.bit.SHDWAMODE = CC_IMMEDIATE;
EPwm6Regs.CMPCTL.bit.SHDWBMODE = CC_IMMEDIATE;
EPwm6Regs.AQCTLA.bit.PRD = AQ_CLEAR; // Set PWM1A on event A, up
EPwm6Regs.AQCTLA.bit.CAU = AQ_SET; // Clear PWM1A on event B, down
EPwm6Regs.AQCTLB.bit.PRD = AQ_SET; // Set PWM1B on event A, up
EPwm6Regs.AQCTLB.bit.CBU = AQ_CLEAR; // Clear PWM1B on event B, down
EPwm6Regs.TBPRD = PWM_Prd; // Set timer period 801 TBCLKs
EPwm6Regs.TBPHS.bit.TBPHS = 10000 - Phi2; // Phase is 0
EPwm6Regs.TBCTR = 0;
//***Trip ZONE***//
EALLOW;
//GpioCtrlRegs.GPAMUX2.bit.GPIO25 = 1; // GPIO25 = GPIO25 //RED
//Set triped sources
EPwm1Regs.TZSEL.bit.OSHT1 = TZ_ENABLE; //TZ1 as one shot
// EPwm2Regs.TZSEL.bit.OSHT1 = TZ_ENABLE; //TZ1 as one shot
// EPwm3Regs.TZSEL.bit.OSHT1 = TZ_ENABLE; //TZ1 as one shot
// EPwm1Regs.TZSEL.bit.CBC2 = TZ_ENABLE; //TZ2 as Cycle by cycle
// EPwm2Regs.TZSEL.bit.CBC2 = TZ_ENABLE; //TZ2 as Cycle by cycle
// EPwm3Regs.TZSEL.bit.CBC2 = TZ_ENABLE; //TZ2 as Cycle by cycle
//Set trip action
// EPwm1Regs.TZCTL.bit.TZA = TZ_FORCE_LO; //PWM1A goes low when triped
// EPwm1Regs.TZCTL.bit.TZB = TZ_FORCE_LO; //PWM1B goes low when triped
// EPwm2Regs.TZCTL.bit.TZA = TZ_FORCE_LO; //PWM2A goes low when triped
// EPwm2Regs.TZCTL.bit.TZB = TZ_FORCE_LO; //PWM2B goes low when triped
// EPwm3Regs.TZCTL.bit.TZA = TZ_FORCE_LO; //PWM3A goes low when triped
// EPwm3Regs.TZCTL.bit.TZB = TZ_FORCE_LO; //PWM3B goes low when triped
// EPwm5Regs.TZCTL.bit.TZA = TZ_FORCE_LO; //PWM5A goes low when triped
// EPwm5Regs.TZCTL.bit.TZB = TZ_FORCE_LO; //PWM5B goes low when triped
// EPwm6Regs.TZCTL.bit.TZA = TZ_FORCE_LO; //PWM6A goes low when triped
// EPwm6Regs.TZCTL.bit.TZB = TZ_FORCE_LO; //PWM6B goes low when triped
// EPwm1Regs.TZEINT.bit.OST = 1;
EDIS;
// Enable INT Settings
EPwm1Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO; // Select INT on Zero event
EPwm1Regs.ETSEL.bit.INTEN = 1; // Enable INT
EPwm1Regs.ETPS.bit.INTPRD = ET_1ST; // Generate INT on 3rd evenT
// GpioCtrlRegs.GPAMUX2.bit.GPIO25 = 1; // GPIO25 = GPIO25 //RED
void LED_init()
EALLOW;
// GPIO-39 - PIN FUNCTION = LED10 on controlCARD
//GpioCtrlRegs.GPBMUX1.bit.GPIO39 = 0; // 0=GPIO, 1=CANTX-A, 2=Resv, 3=Resv
//GpioCtrlRegs.GPBDIR.bit.GPIO39 = 1; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO39 = 1; // uncomment if --> Set Low initially
//GpioDataRegs.GPBSET.bit.GPIO39 = 1; // uncomment if --> Set High initially
// GPIO-34 - PIN FUNCTION = LED9 on controlCARD
//GpioCtrlRegs.GPBMUX1.bit.GPIO34 = 0; // 0=GPIO, 1=COMP2OUT, 2=EPWMSYNCI, 3=ADCSOCA
//GpioCtrlRegs.GPBDIR.bit.GPIO34 = 1; // 1=OUTput, 0=INput
// GpioDataRegs.GPBCLEAR.bit.GPIO34 = 1; // uncomment if --> Set Low initially
//GpioDataRegs.GPBSET.bit.GPIO34 = 1; // uncomment if --> Set High initially
// GPIO-52 - PIN FUNCTION = LED GREEN
// GpioCtrlRegs.GPBMUX2.bit.GPIO52 = 0; //
// GpioCtrlRegs.GPBDIR.bit.GPIO52 = 1; // 1=OUTput, 0=INput
// GpioDataRegs.GPBCLEAR.bit.GPIO52 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPBSET.bit.GPIO52 = 1; // uncomment if --> Set High initially
// GPIO-53 - PIN FUNCTION = LED GREEN
// GpioCtrlRegs.GPBMUX2.bit.GPIO53 = 0; //
// GpioCtrlRegs.GPBDIR.bit.GPIO53 = 1; // 1=OUTput, 0=INput
// GpioDataRegs.GPBCLEAR.bit.GPIO53 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPBSET.bit.GPIO53 = 1; // uncomment if --> Set High initially
// GPIO-56 - PIN FUNCTION = LED RED
// GpioCtrlRegs.GPBMUX2.bit.GPIO56 = 0; //
// GpioCtrlRegs.GPBDIR.bit.GPIO56 = 1; // 1=OUTput, 0=INput
// GpioDataRegs.GPBCLEAR.bit.GPIO56 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPBSET.bit.GPIO56 = 1; // uncomment if --> Set High initially
EDIS;
