Dear Sir,
I tried program for the PWM using eCap(capture mode).I used the c2000 picolo Launch Pad Evaluation Kit .But when I dump the Program but after dumping the program I got memory map issue/problem .
C28xx: GEL Output:
Device Calibration not complete, check if device is unlocked and recalibrate.C28xx: Flash Programmer: Warning: The configured device (TMS320F28027), does not match the detected device (). Flash Programming operations could be affected. Please consider modifying your target configuration file.
C28xx: GEL Output:
Device Calibration not complete, check if device is unlocked and recalibrate.C28xx: File Loader: Verification failed: Values at address 0x0000000000008000 do not match Please verify target memory and memory map.
C28xx: GEL: File: C:\Users\Wisdom\Desktop\prasad\pwm_\Debug\pwm_.out: a data verification error occurred, file load failed.
please give me suggestions how to solve the above issue .
Thanks and Regards,
Mahesh K. Joshi
mail id: maheshjoshi91@gmail.com
