Other Parts Discussed in Thread: CONTROLSUITE
I am tasked with configuring code security module of control sub system in F28M35H52C chip. I want to be certain before tying anything on the chip. All the literature i have gone through indicates that i should include .asm file with passwords and assign those variables to correct memory location by changing the linker command file. But it seems that in the F28M35x_Headers_nonBIOS.cmd file those memory sections are already created and some variables are already assigned to them.
/* //########################################################################### // FILE: F28M3Xx_Headers_nonBIOS.cmd // TITLE: F28M3Xx Peripheral registers linker command file // DESCRIPTION: // This file is for use in Non-BIOS applications. // Linker command file to place the peripheral structures // used within the F28M3Xx headerfiles into the correct memory // mapped locations. // This version of the file includes the PieVectorTable structure. // For BIOS applications, please use the F28M3Xx_Headers_BIOS.cmd file // which does not include the PieVectorTable structure. //########################################################################### // $TI Release: F28M35x Support Library v220 $ // $Release Date: Tue Sep 26 15:35:11 CDT 2017 $ // $Copyright: Copyright (C) 2011-2017 Texas Instruments Incorporated - // http://www.ti.com/ ALL RIGHTS RESERVED $ //########################################################################### */ MEMORY { PAGE 0: /* Program Memory */ PAGE 1: /* Data Memory */ DEV_EMU : origin = 0x000880, length = 0x000180 /* device emulation registers */ CSM : origin = 0x000AE0, length = 0x000020 /* code security module registers */ ADC1_RESULT : origin = 0x000B00, length = 0x000020 /* ADC1 Results register */ ADC2_RESULT : origin = 0x000B40, length = 0x000020 /* ADC2 Results register */ CPU_TIMER0 : origin = 0x000C00, length = 0x000008 /* CPU Timer0 registers */ CPU_TIMER1 : origin = 0x000C08, length = 0x000008 /* CPU Timer1 registers */ CPU_TIMER2 : origin = 0x000C10, length = 0x000008 /* CPU Timer2 registers */ PIE_CTRL : origin = 0x000CE0, length = 0x000020 /* PIE control registers */ PIE_VECT : origin = 0x000D00, length = 0x000100 /* PIE Vector Table */ PIE_VECT_CP : origin = 0x000E00, length = 0x000100 /* PIE Vector Table Copy */ DMA : origin = 0x001000, length = 0x000200 /* DMA registers */ ASYSCTRLCONFIG : origin = 0x001700, length = 0x000080 /* Analog System Control Configuration Registers */ FLASH_REGS : origin = 0x004000, length = 0x000300 /* Flash Control registers */ FLASH_ECC : origin = 0x004300, length = 0x000040 /* Flash/OTP ECC Error Log registers */ M3PLL : origin = 0x004400, length = 0x000010 /* M3 PLL Clock Configuration Registers */ EPI_REGS : origin = 0x004430, length = 0x000010 /* EPI Registers */ RAM_REGS : origin = 0x004900, length = 0x000080 /* RAM Control registers */ RAM_ERR_REGS : origin = 0x004A00, length = 0x000080 /* RAM ECC/PARITY/ACCESS Error Log Registers */ CM_MC_IPC : origin = 0x004E00, length = 0x000040 /* C28 Control to Master IPC registers */ MCBSPA : origin = 0x005000, length = 0x000040 /* McBSP-A registers */ EPWM1 : origin = 0x005100, length = 0x000080 /* EPWM1 + HRPWM registers */ EPWM2 : origin = 0x005180, length = 0x000080 /* EPWM2 + HRPWM registers */ EPWM3 : origin = 0x005200, length = 0x000080 /* EPWM3 + HRPWM registers */ EPWM4 : origin = 0x005280, length = 0x000080 /* EPWM4 + HRPWM registers */ EPWM5 : origin = 0x005300, length = 0x000080 /* EPWM5 + HRPWM registers */ EPWM6 : origin = 0x005380, length = 0x000080 /* EPWM6 + HRPWM registers */ EPWM7 : origin = 0x005400, length = 0x000080 /* EPWM7 + HRPWM registers */ EPWM8 : origin = 0x005480, length = 0x000080 /* EPWM8 + HRPWM registers */ EPWM9 : origin = 0x005500, length = 0x000080 /* EPWM9 registers (no HRPWM) */ ECAP1 : origin = 0x005A00, length = 0x000020 /* Enhanced Capture 1 registers */ ECAP2 : origin = 0x005A20, length = 0x000020 /* Enhanced Capture 2 registers */ ECAP3 : origin = 0x005A40, length = 0x000020 /* Enhanced Capture 3 registers */ ECAP4 : origin = 0x005A60, length = 0x000020 /* Enhanced Capture 4 registers */ ECAP5 : origin = 0x005A80, length = 0x000020 /* Enhanced Capture 5 registers */ ECAP6 : origin = 0x005AA0, length = 0x000020 /* Enhanced Capture 6 registers */ EQEP1 : origin = 0x005B00, length = 0x000040 /* Enhanced QEP 1 registers */ EQEP2 : origin = 0x005B40, length = 0x000040 /* Enhanced QEP 2 registers */ EQEP3 : origin = 0x005B80, length = 0x000040 /* Enhanced QEP 3 registers */ GPIOG1CTRL : origin = 0x005F80, length = 0x000040 /* GPIO control registers */ GPIOG1DAT : origin = 0x005FC0, length = 0x000020 /* GPIO data registers */ GPIOG1TRIP : origin = 0x005FE0, length = 0x000020 /* GPIO trip/LPM registers */ COMP1 : origin = 0x006400, length = 0x000020 /* Comparator + DAC 1 registers */ COMP2 : origin = 0x006420, length = 0x000020 /* Comparator + DAC 2 registers */ COMP3 : origin = 0x006440, length = 0x000020 /* Comparator + DAC 3 registers */ COMP4 : origin = 0x006460, length = 0x000020 /* Comparator + DAC 4 registers */ COMP5 : origin = 0x006480, length = 0x000020 /* Comparator + DAC 5 registers */ COMP6 : origin = 0x0064A0, length = 0x000020 /* Comparator + DAC 6 registers */ GPIOG2CTRL : origin = 0x006F80, length = 0x000040 /* GPIO control registers */ GPIOG2DAT : origin = 0x006FC0, length = 0x000020 /* GPIO data registers */ SYSTEM : origin = 0x007010, length = 0x000020 /* System control registers */ SPIA : origin = 0x007040, length = 0x000010 /* SPI-A registers */ SCIA : origin = 0x007050, length = 0x000010 /* SCI-A registers */ NMIINTRUPT : origin = 0x007060, length = 0x000010 /* NMI Watchdog Interrupt Registers */ XINTRUPT : origin = 0x007070, length = 0x000010 /* external interrupt registers */ ADC1 : origin = 0x007100, length = 0x000080 /* ADC1 registers */ ADC2 : origin = 0x007180, length = 0x000080 /* ADC2 registers */ I2CA : origin = 0x007900, length = 0x000040 /* I2C-A registers */ FLASH_EXE_ONLY : origin = 0x13FFF2, length = 0x000002 /* FLASH execution only locations */ ECSL_PWL : origin = 0x13FFF4, length = 0x000004 /* FLASH ECSL password locations */ CSM_PWL : origin = 0x13FFF8, length = 0x000008 /* FLASH CSM password locations. */ } SECTIONS { /*** PIE Vect Table and Boot ROM Variables Structures ***/ UNION run = PIE_VECT, PAGE = 1 { PieVectTableFile GROUP { EmuKeyVar EmuBModeVar FlashCallbackVar FlashScalingVar } } /*** Peripheral Frame 0 Register Structures ***/ DevEmuRegsFile : > DEV_EMU, PAGE = 1 CsmRegsFile : > CSM, PAGE = 1 UNION run = ADC1_RESULT, PAGE = 1 { AdcResultFile Adc1ResultFile } Adc2ResultFile : > ADC2_RESULT, PAGE = 1 CpuTimer0RegsFile : > CPU_TIMER0, PAGE = 1 CpuTimer1RegsFile : > CPU_TIMER1, PAGE = 1 CpuTimer2RegsFile : > CPU_TIMER2, PAGE = 1 PieCtrlRegsFile : > PIE_CTRL, PAGE = 1 PieVectTableCopyFile : > PIE_VECT_CP, PAGE = 1 DmaRegsFile : > DMA, PAGE = 1 AnalogSysctrlRegsFile : > ASYSCTRLCONFIG, PAGE = 1 /*** Peripheral Frame 1 Register Structures ***/ FlashCtrlRegsFile : > FLASH_REGS, PAGE = 1 FlashEccRegsFile : > FLASH_ECC, PAGE = 1 M3PllRegsFile : > M3PLL, PAGE = 1 EpiRegsFile : > EPI_REGS PAGE = 1 RAMRegsFile : > RAM_REGS, PAGE = 1 RAMErrRegsFile : > RAM_ERR_REGS,PAGE = 1 CtoMIpcRegsFile : > CM_MC_IPC, PAGE = 1 /*** Peripheral Frame 2 Register Structures ***/ SysCtrlRegsFile : > SYSTEM, PAGE = 1 SpiaRegsFile : > SPIA, PAGE = 1 SciaRegsFile : > SCIA, PAGE = 1 NmiIntruptRegsFile: > NMIINTRUPT, PAGE = 1 XIntruptRegsFile : > XINTRUPT, PAGE = 1 UNION run = ADC1, PAGE = 1 { AdcRegsFile Adc1RegsFile } Adc2RegsFile : > ADC2, PAGE = 1 I2caRegsFile : > I2CA, PAGE = 1 /*** Peripheral Frame 3 Register Structures ***/ McbspaRegsFile : > MCBSPA, PAGE = 1 EPwm1RegsFile : > EPWM1, PAGE = 1 EPwm2RegsFile : > EPWM2, PAGE = 1 EPwm3RegsFile : > EPWM3, PAGE = 1 EPwm4RegsFile : > EPWM4, PAGE = 1 EPwm5RegsFile : > EPWM5, PAGE = 1 EPwm6RegsFile : > EPWM6, PAGE = 1 EPwm7RegsFile : > EPWM7, PAGE = 1 EPwm8RegsFile : > EPWM8, PAGE = 1 EPwm9RegsFile : > EPWM9, PAGE = 1 ECap1RegsFile : > ECAP1, PAGE = 1 ECap2RegsFile : > ECAP2, PAGE = 1 ECap3RegsFile : > ECAP3, PAGE = 1 ECap4RegsFile : > ECAP4, PAGE = 1 ECap5RegsFile : > ECAP5, PAGE = 1 ECap6RegsFile : > ECAP6, PAGE = 1 EQep1RegsFile : > EQEP1, PAGE = 1 EQep2RegsFile : > EQEP2, PAGE = 1 EQep3RegsFile : > EQEP3, PAGE = 1 UNION run = GPIOG1CTRL, PAGE = 1 { GpioCtrlRegsFile GpioG1CtrlRegsFile } UNION run = GPIOG1DAT, PAGE = 1 { GpioDataRegsFile GpioG1DataRegsFile } UNION run = GPIOG1TRIP, PAGE = 1 { GpioTripRegsFile GpioG1TripRegsFile } Comp1RegsFile : > COMP1, PAGE = 1 Comp2RegsFile : > COMP2, PAGE = 1 Comp3RegsFile : > COMP3, PAGE = 1 Comp4RegsFile : > COMP4, PAGE = 1 Comp5RegsFile : > COMP5, PAGE = 1 Comp6RegsFile : > COMP6, PAGE = 1 GpioG2CtrlRegsFile : > GPIOG2CTRL, PAGE = 1 GpioG2DataRegsFile : > GPIOG2DAT, PAGE = 1 /*** Code Security Module Register Structures ***/ FlashExeOnlyFile : > FLASH_EXE_ONLY, PAGE = 1 EcslPwlFile : > ECSL_PWL, PAGE = 1 CsmPwlFile : > CSM_PWL, PAGE = 1 } /* */
I have no idea where and when these variables are created Please help me to clarify this issue. Thanks.
