Dear Team,
We are trying to configure LIN on 280049 in slave mode.
In our driverlib, we only provided an API _initModule() to configure LIN in master mode.
In order to configure the LIN in slave mode, we modified the code in lin.c(in driverlib documents). And putted the corresponding code in main.c.
However, the code cannot jump into interrupt function. Could you please help review the configuration or provide a correct example to configure LIN communication?
I noted our modification in bold characters.
void
LIN_init_Module(uint32_t base)
// Check the arguments.
ASSERT(LIN_isBaseValid(base));
EALLOW;
// Reset LIN module
// Release from hard reset
LIN_disableModule(base);
LIN_enableModule(base);
// Enter Software Reset State
LIN_enterSoftwareReset(base);
// Enable LIN Mode
LIN_disableSCIMode(base);
// Set LIN mode to Master
LIN_setLINMode(base, LIN_MODE_LIN_SLAVE);
// Enable Fixed baud rate mode
//LIN_disableAutomaticBaudrate(base);
LIN_enableAutomaticBaudrate(base);
// Use the set frame length and not ID4/ID5 bits for length control
LIN_setCommMode(base, LIN_COMM_LIN_USELENGTHVAL);
// Setup to continue operating on emulation suspend
LIN_setDebugSuspendMode(base, LIN_DEBUG_COMPLETE);
// Use Enhanced Checksum
LIN_setChecksumType(base, LIN_CHECKSUM_ENHANCED);
// Message filtering uses slave task ID byte
//LIN_setMessageFiltering(base, LIN_MSG_FILTER_IDSLAVE);
LIN_setMessageFiltering(base, LIN_MSG_FILTER_IDBYTE);
// Disable Internal loopback for external communication
LIN_disableIntLoopback(base);
// Enable multi-buffer mode
LIN_enableMultibufferMode(base);
// Enable parity check on received ID
LIN_enableParity(base);
// Enable transfer of data to and from the shift registers
LIN_enableDataTransmitter(base);
LIN_enableDataReceiver(base);
// Enable the triggering of checksum compare on extended frames
LIN_triggerChecksumCompare(base);
// Set LIN interrupts to disabled
LIN_disableInterrupt(base, LIN_INT_ALL);
// Set Baud Rate Settings - 100MHz Device
//LIN_setBaudRatePrescaler(base, 96U, 11U);
LIN_setMaximumBaudRate(base, 100000000U);
// Set response field to 1 byte
LIN_setFrameLength(base, 1U);
// Configure sync field
// Sync break (13 + 5 = 18 Tbits)
// Sync delimiter (1 + 3 = 4 Tbits)
LIN_setSyncFields(base, 5U, 3U);
// Set Mask ID so TX/RX match will always happen
LIN_setTxMask(base, 0xFFU);
LIN_setRxMask(base, 0xFFU);
// Disable IODFT testing and external loopback mode
LIN_disableExtLoopback(base);
// Finally exit SW reset and enter LIN ready state
LIN_exitSoftwareReset(base);
EDIS;
inline void Config_LIN(uint32_t base)
// Interrupts that are used in this example are re-mapped to
// ISR functions found within this file.
// This registers the interrupt handler in PIE vector table.
Interrupt_register(INT_LINA_0, &level0ISR);
Interrupt_register(INT_LINA_1, &level1ISR);
// Enable the LIN interrupt signals
Interrupt_enable(INT_LINA_0);
Interrupt_enable(INT_LINA_1);
// Initialize the LIN module
LIN_initModule(LINA_BASE);
// Enable Internal Loopback mode
LIN_enableIntLoopback(LINA_BASE);
// Enable interrupts for when an header identifier is received
LIN_enableInterrupt(LINA_BASE, LIN_INT_ID);
// Set the interrupt priority line
// Default is set to Interrupt line 0 (high priority)
// Comment out "LIN_setInterruptLevel0" and uncomment
// "LIN_setInterruptLevel1" to change to interrupt line 1 (low priority)
LIN_setInterruptLevel0(LINA_BASE, LIN_INT_ALL);
//LIN_setInterruptLevel1(LINA_BASE, LIN_INT_ALL);
LIN_enableParity(LINA_BASE);
// Enable global interrupt lines and clear status to known value
LIN_enableGlobalInterrupt(LINA_BASE, LIN_INTERRUPT_LINE0);
LIN_enableGlobalInterrupt(LINA_BASE, LIN_INTERRUPT_LINE1);
LIN_clearGlobalInterruptStatus(LINA_BASE, LIN_INTERRUPT_LINE0);
LIN_clearGlobalInterruptStatus(LINA_BASE, LIN_INTERRUPT_LINE1);
