Hi, when I compile the code, I got the issue " fatal error #6001: cannot open file ".\Bootloader_2.map": No error" or " fatal error #6001: cannot open file ".\Bootloader_2.map": No such file or directory". Here is the compile log. And the cmd file is pasted in this post. Anyone can help me with this? Thanks
Building target: "Bootloader_2.out"
Invoking: C2000 Linker
"C:/ti/ccsv8/tools/compiler/ti-cgt-c2000_16.9.11.LTS/bin/cl2000" -v28 -ml -mt --cla_support=cla1 --float_support=fpu32 --tmu_support=tmu0 --vcu_support=vcu2 --advice:performance=all --define=_F2837xS --define=BOOTLOADER=TRUE -g --diag_warning=225 --diag_wrap=off --display_error_number -z -m"Bootloader_2.map" --stack_size=0x200 --warn_sections -i"C:/ti/ccsv8/tools/compiler/ti-cgt-c2000_16.9.11.LTS/lib" -i"D:/OBC_Firmware/Bootloader_2/include/VCU2API/lib" -i"D:/OBC_Firmware/Bootloader_2/include/FlashAPI" -i"C:/ti/ccsv8/tools/compiler/ti-cgt-c2000_16.9.11.LTS/include" --reread_libs --diag_wrap=off --display_error_number --xml_link_info="Bootloader_2_linkInfo.xml" --rom_model -o "Bootloader_2.out" "./FlashInterface.obj" "./GlobalMath.obj" "./c2837xSBoard_Realtime_Support.obj" "./main.obj" "./App/AppSrc/AppDID.obj" "./App/AppSrc/AppDTC.obj" "./App/AppSrc/AppIO.obj" "./App/AppSrc/Bootloader.obj" "./App/AppSrc/CANApp.obj" "./App/AppSrc/Fifo.obj" "./App/AppSrc/GeneralFunction.obj" "./App/AppSrc/OS.obj" "./App/AppSrc/crc32.obj" "./App/AppSrc/crc8.obj" "./App/AppSrc/flashrchw.obj" "./App/AppSrc/msTickCounter.obj" "./App/AppSrc/nvdata.obj" "./App/AppSrc/securityAccess.obj" "./App/UDS/ISOUDS_ClrDTC/ISOUDS_ClrDTC.obj" "./App/UDS/ISOUDS_CntrlDTCSetting/ISOUDS_CntrlDTCSetting.obj" "./App/UDS/ISOUDS_CommCntrl/ISOUDS_CommCntrl.obj" "./App/UDS/ISOUDS_ECUReset/ISOUDS_ECUReset.obj" "./App/UDS/ISOUDS_IOCtrlByID/ISOUDS_IOCtrlByID.obj" "./App/UDS/ISOUDS_MAIN/ISOUDS.obj" "./App/UDS/ISOUDS_RdDTCInf/ISOUDS_RdDTCInf.obj" "./App/UDS/ISOUDS_RdDaByID/ISOUDS_RdCfg.obj" "./App/UDS/ISOUDS_RdDaByID/ISOUDS_RdDaByID.obj" "./App/UDS/ISOUDS_ReqDwnld/ISOUDS_ReqDwnld.obj" "./App/UDS/ISOUDS_RtnCntrl/ISOUDS_RtnCfg.obj" "./App/UDS/ISOUDS_RtnCntrl/ISOUDS_RtnCntrl.obj" "./App/UDS/ISOUDS_SA/ISOUDS_SA.obj" "./App/UDS/ISOUDS_StrtDiagSess/ISOUDS_StrtDiagSess.obj" "./App/UDS/ISOUDS_TrnsfrDa/ISOUDS_TrnsfrDa.obj" "./App/UDS/ISOUDS_TrnsfrExit/ISOUDS_TrnsfrExit.obj" "./App/UDS/ISOUDS_TstrPrsnt/ISOUDS_TstrPrsnt.obj" "./App/UDS/ISOUDS_WrDaByID/ISOUDS_WrCfg.obj" "./App/UDS/ISOUDS_WrDaByID/ISOUDS_WrDaByID.obj" "./App/UDS/UDS_App/UDSApp.obj" "./App/UDS/UDS_App/UDSApp_CommCntrl.obj" "./App/UDS/UDS_App/UDSApp_CommonDID.obj" "./App/UDS/UDS_App/UDSApp_DTC.obj" "./App/udsclient/canTransport.obj" "./App/udsclient/udsServices.obj" "./Driver/Driver_Src/adc_library.obj" "./Driver/Driver_Src/can_library.obj" "./Driver/Driver_Src/crc_library.obj" "./Driver/Driver_Src/flash_library.obj" "./Driver/Driver_Src/gpio_library.obj" "./Driver/Driver_Src/pwm_library.obj" "./Driver/Driver_Src/sys_library.obj" "./Driver/Driver_Src/timer_library.obj" "./Link/LinkSrc/CanCommon.obj" "./Link/LinkSrc/CrcInterface.obj" "./Link/LinkSrc/INT.obj" "./Link/LinkSrc/SystemInterface.obj" "./Link/LinkSrc/TIMER.obj" "./Link/UDS_ISOTP/ISOTP.obj" "./Link/UDS_ISOTP/ISOTP_Cfg.obj" "./Link/UDS_ISOTP/UDSFifo.obj" "./source/F2837xS_Adc.obj" "./source/F2837xS_CodeStartBranch.obj" "./source/F2837xS_CpuTimers.obj" "./source/F2837xS_DBGIER.obj" "./source/F2837xS_DefaultISR.obj" "./source/F2837xS_Dma.obj" "./source/F2837xS_ECap.obj" "./source/F2837xS_EPwm.obj" "./source/F2837xS_EQep.obj" "./source/F2837xS_Emif.obj" "./source/F2837xS_GlobalVariableDefs.obj" "./source/F2837xS_Gpio.obj" "./source/F2837xS_I2C.obj" "./source/F2837xS_Mcbsp.obj" "./source/F2837xS_PieCtrl.obj" "./source/F2837xS_PieVect.obj" "./source/F2837xS_Sci.obj" "./source/F2837xS_Spi.obj" "./source/F2837xS_SysCtrl.obj" "./source/F2837xS_TempSensorConv.obj" "./source/F2837xS_Upp.obj" "./source/F2837xS_can.obj" "./source/F2837xS_sci_io.obj" "./source/F2837xS_sdfm_drivers.obj" "./source/F2837xS_struct.obj" "./source/F2837xS_usDelay.obj" "../28377S_BootLoader.cmd" "../F2837xS_Headers_nonBIOS.cmd" "../rts2800_fpu32_fast_supplement.lib" "../include/FlashAPI/F021_API_F2837xS_FPU32.lib" "../include/VCU2API/lib/c28x_vcu0_crcTables_library.lib" "../include/VCU2API/lib/c28x_vcu0_crcTables_library_fpu32.lib" "../include/VCU2API/lib/c28x_vcu0_library.lib" "../include/VCU2API/lib/c28x_vcu0_library_fpu32.lib" "../include/VCU2API/lib/c28x_vcu2_library.lib" "../include/VCU2API/lib/c28x_vcu2_library_fpu32.lib" -llibc.a -l"D:/OBC_Firmware/Bootloader_2/include/FlashAPI/F021_API_F2837xS_FPU32.lib" -l"D:/OBC_Firmware/Bootloader_2/include/VCU2API/lib/c28x_vcu2_library_fpu32.lib"
<Linking>
".\Bootloader_2.map", line 1: fatal error #6001: cannot open file ".\Bootloader_2.map": No error
>> Compilation failure
makefile:286: recipe for target 'Bootloader_2.out' failed
gmake[1]: *** [Bootloader_2.out] Error 1
makefile:282: recipe for target 'all' failed
gmake: *** [all] Error 2
MEMORY
PAGE 0 : /* Program Memory */
/* Memory (RAM/FLASH) blocks can be moved to PAGE1 for data allocation */
/* BEGIN is used for the "boot to Flash" bootloader mode */
BOOTBEGIN : origin = 0x080000, length = 0x000002
RAMM0 : origin = 0x000122, length = 0x0002DE
RAMD0 : origin = 0x00B000, length = 0x000800
RAMAPP : origin = 0x008000, length = 0x000800
RAMAPP_1 : origin = 0x008800, length = 0x000800
RAMAPP_2 : origin = 0x009000, length = 0x000800
RAMLS3 : origin = 0x009800, length = 0x000800
RAMBOOT : origin = 0x00A000, length = 0x000800 /*Here is the RAM for Bootloader use*/
RAMBOOT_1 : origin = 0x01A000, length = 0x001000
RAMBOOT_2 : origin = 0x01B000, length = 0x001000
RESET : origin = 0x3FFFC0, length = 0x000002
/* Flash sectors */
BOOTFLASH : origin = 0x080002, length = 0x00FFFE
FLASHF : origin = 0x090000, length = 0x008000 /* on-chip Flash */
FLASHG : origin = 0x098000, length = 0x008000 /* on-chip Flash */
FLASHH : origin = 0x0A0000, length = 0x008000 /* on-chip Flash */
FLASHI : origin = 0x0A8000, length = 0x008000 /* on-chip Flash */
FLASHJ : origin = 0x0B0000, length = 0x008000 /* on-chip Flash */
FLASHK : origin = 0x0B8000, length = 0x002000 /* on-chip Flash */
FLASHL : origin = 0x0BA000, length = 0x002000 /* on-chip Flash */
FLASHM : origin = 0x0BC000, length = 0x002000 /* on-chip Flash */
FLASHN : origin = 0x0BE000, length = 0x002000 /* on-chip Flash */
APPBEGIN : origin = 0x0C0000, length = 0x000002 /* APPCODE start */
APPFLASH :origin = 0x0C0002, length = 0x02FFFE /*APP FLASH*/
FLASHX : origin = 0x0F0000, length = 0x008000 /* on-chip Flash */
FLASHY : origin = 0x0F8000, length = 0x002000 /* on-chip Flash */
FLASHZ : origin = 0x0FA000, length = 0x002000 /* on-chip Flash */
FLASHAA : origin = 0x0FC000, length = 0x002000 /* on-chip Flash */
FLASHAB : origin = 0x0FE000, length = 0x002000 /* on-chip Flash */
PAGE 1 : /* Data Memory */
/* Memory (RAM/FLASH) blocks can be moved to PAGE0 for program allocation */
BOOT_RSVD : origin = 0x000002, length = 0x000120 /* Part of M0, BOOT rom will use this for stack */
RAMM1 : origin = 0x000400, length = 0x000400 /* on-chip RAM block M1 */
RAMD1 : origin = 0x00B800, length = 0x000800
RAMLS5 : origin = 0x00A800, length = 0x000800
BOOTDATA : origin = 0x00C000, length = 0x001000
BOOTDATA_2 : origin = 0x00D000, length = 0x001000
BOOTDATA_3 : origin = 0x00E000, length = 0x001000
RAMGS3 : origin = 0x00F000, length = 0x001000
RAMGS4 : origin = 0x010000, length = 0x001000
RAMGS5 : origin = 0x011000, length = 0x001000
APPDATA : origin = 0x012000, length = 0x001000
APPDATA_1 : origin = 0x013000, length = 0x001000
APPDATA_2 : origin = 0x014000, length = 0x001000
APPDATA_3 : origin = 0x015000, length = 0x001000
RAMGS10 : origin = 0x016000, length = 0x001000
RAMGS11 : origin = 0x017000, length = 0x001000
RAMGS12 : origin = 0x018000, length = 0x001000
RAMGS13 : origin = 0x019000, length = 0x001000
SECTIONS
/* Allocate program areas: */
.cinit : > BOOTFLASH PAGE = 0, ALIGN(4)
.pinit : > BOOTFLASH PAGE = 0, ALIGN(4)
.text : > BOOTFLASH PAGE = 0, ALIGN(4)
codestart : > BOOTBEGIN PAGE = 0, ALIGN(4)
.TI.ramfunc :
LOAD = FLASHBL,
RUN = RAMBOOT | RAMBOOT_1,
LOAD_START(_RamfuncsLoadStart),
LOAD_SIZE(_RamfuncsLoadSize),
LOAD_END(_RamfuncsLoadEnd),
RUN_START(_RamfuncsRunStart),
RUN_SIZE(_RamfuncsRunSize),
RUN_END(_RamfuncsRunEnd),
PAGE = 0, ALIGN(4)
/* Allocate uninitalized data sections: */
.stack : > BOOTDATA PAGE = 1
.ebss : >> BOOTDATA_2 | BOOTDATA_3 PAGE = 1
.esysmem : > BOOTDATA_2 PAGE = 1
/* Initalized sections go in Flash */
.econst : >> BOOTFLASH PAGE = 0, ALIGN(4)
.switch : > BOOTFLASH PAGE = 0, ALIGN(4)
.reset : > RESET, PAGE = 0, TYPE = DSECT /* not used, */
// End of file.
.cinit : > APPFLASH PAGE = 0, ALIGN(4)
.pinit : > APPFLASH, PAGE = 0, ALIGN(4)
.text : > APPFLASH PAGE = 0, ALIGN(4)
codestart : > APPBEGIN PAGE = 0, ALIGN(4)
.TI.ramfunc : {} LOAD = APPFLASH,
RUN = RAMAPP | RAMAPP_1 | RAMAPP_2,
PAGE = 0, ALIGN(4)
.stack : > APPDATA PAGE = 1
.ebss : >> APPDATA | APPDATA_1 | APPDATA_2 PAGE = 1
.esysmem : > APPDATA PAGE = 1
.econst : > APPFLASH PAGE = 0, ALIGN(4)
.switch : > APPFLASH PAGE = 0, ALIGN(4)
