Hello:
In my application, I need to suddenly stop the motor without mechanical brake(motor is running in velocity mode). The motor runs at fixed speed, then it should be stopped VERY VERY quickly.
Can SpinTAC-Velocity achieve the same result as the traditional velocity PI controller for this application?
To achieve this sudden stop, I think I should adjust bandwidth as high as possible and bypass the speed trajectory ramp in lab5d. Am I correct?
Thank you.
