hi,
I have the card drv8301 69m and I would be interested in understanding the operation of the modules ECAP, in particorare I would like to connect these inputs Sum of the three hall sensors with digital output 1-0 of my BLDC motor 6 magnetic poles. (attached data sheet).
looking at the datasheet with hall sensors mounted sa sb sc have a resolution of 12 degrees this is correct?
what I would do, but that I have a real need help not code already done but an explanation of why you have to enter certain lines of your codes never otherwise would not understand how to program this complicated micro.
I would like to read the values from the three cap 1 2 3 have for example 011 and then convert this value into an angle increment or decrement if the direction of rotation is reversed.
Thanks for those who will help me in this path.
