I'm having a little trouble understanding the outputs of the PI controllers for Id and Iq in Lab 11, and I think there might be a fault. Here's my problem.
Hi Matt,
As you mentioned, lab11 has an error for DC_Bus compensation. This will be probably fixed next MW version. In the meantime, You can use the one of the following workarounds.
1) Locate DC_Bus compensation (Kp_Idq * Inv_DC) before current PI controller same as other labs.
2) Change the current PI controller's maximum value from USER_MAX_VS_MAG_PU(0.5) to (Vdc_pu/sqrt(3))
Let me attach some example code soon.
Thansk,
Steve
Steve,
No need for any example code. We can work it out on our end. I think we're going to modify the PI controllers to give us per-unit voltages, so we can subsequently compare the alpha and beta components of the regulators with the measured values, and then convert to duty cycle in the SVPWM module.
Thanks for the confirmation.
Matt
