Other Parts Discussed in Thread: DRV8305, MOTORWARE
Hi Champs,
My customer is testing proj_lab11e using Teknic_M2310PLN04K and F28069M launchpad+DRV8305 BoostXL. The motorware version is motorware_1_01_00_18. They found motor cannot startup with high current. The startup phase current scope capture is as follows. And also the fault LED will be lighted on. The wire connection are alright, and the motor's hall sensor is OK.
Would you kindly help to check the reason?
Thanks.
BR,
Young
