• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Hercules™ Safety Microcontrollers » Hercules™ Safety Microcontrollers Forum » nowFlash Tool not found by Hercules Safety MCU Demos
Share
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Helge
Posted by Helge
on Jan 05 2012 08:45 AM
Prodigy50 points
I tried to launch the LED demo from Hercules Safety MCU Demos with an RM48 MCU HDK connected via USB, but it does not detect the nowFlash Utility.
The software gives the following error "nowFlash v3.4 or greater was not found on your computer.  Please install nowFlash then try again.".
But nowFlash Rev 3.4.1 is already installed.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Haixiao Weng
    Posted by Haixiao Weng
    on Jan 05 2012 09:01 AM
    Genius9955 points
    Please let me know:
    1) You are running it on xp or windows7?
    2) The directory that you install the Hercules Safety MCU Demos, default is "C:\Program Files\Texas Instruments\Hercules\Hercules Safety MCU Demos"
    3) The directory that you install the nowFlash V3.4.1, default is "C:\ti\nowFlash\v3.41"
    Haixiao
    Report Abuse
    • Reply
  • Helge
    Posted by Helge
    on Jan 05 2012 09:05 AM
    Prodigy50 points
    1.) running on XP
    2.) Because of german localization, the MCU Demos is located under:
    "C:\Programme\Texas Instruments\Hercules\Hercules Safety MCU Demos"
    3.) Nowflash is installed at the default location C:\ti\nowFlash\v3.41
    Report Abuse
    • Reply
  • Haixiao Weng
    on Jan 05 2012 09:58 AM
    Verified Answer
    Verified by Haixiao Weng
    Genius9955 points
    The safety software reads out the registry to find the nowFlash, please
    1) Run regedt32, the Registry Editor windown should pop out.
    2) look for:
    3) Under SOFTWARE, look for:
    4) At this point, the MCU safety software find the nowFlash software.
    5) So, please check your PC registry to see whether the name in the red box are exactly the same (for "nowFlash v3.40", the nowFlash has to be exactly the same).
    Haixiao
    Report Abuse
    • Reply
  • Helge
    Posted by Helge
    on Jan 05 2012 11:12 AM
    Prodigy50 points
    Thank you, this solved the problem!
    Report Abuse
    • Reply
  • 1757001
    Posted by 1757001
    on Jan 12 2012 14:48 PM
    Prodigy105 points
    Hi Haixiao.
    I´m having the same problem.
    I m running Windows 7 Professional SP1 (spanish version) on a 64bit system.
    I´v both nowFlash v3.40 and v3.41 installed:
    - C:\ti\nowFlash\v340
    - C:\ti\nowFlash\v3.41
    Here is a trace of the registry access by the Hercule demo software:
    here are the key entries:
    the names seem to match but the Demo software complain about nowFlash not installed...
    both installed nowFlash are working I already used them out of the DemoSoftware.
    Thank for your help!
    Yasuki.
    Report Abuse
    • Reply
  • Haixiao Weng
    on Jan 12 2012 17:22 PM
    Genius9955 points
    64bit system might be the problem.
    The safety demo is built with labview in a 32bit system.
    I read some posts in National Instrument's website saying that they can not read the registry in such a case.
    I am sorry I can not help further. We may need to push for a 64bit version safety demo to overcome this.
    Haixiao
    Report Abuse
    • Reply
  • Jiri Dobry
    Posted by Jiri Dobry
    on Apr 23 2012 14:01 PM
    Prodigy80 points
    Any news about around problem?
    I have same problem (Win7 64bit Czech) and latast update of nowflash and herkules demo.
    Report Abuse
    • Reply
  • Andreas Christensen
    Posted by Andreas Christensen
    on Apr 27 2012 08:32 AM
    Prodigy10 points
    I'm running 64-bit windows and trying to get the Hercules Demo Software to work.
    Setting the compatibility to Windows XP (Service Pack 3) will get me a step further:
    I now see a new error for "Flash470 not found" which i really didn't expect since i'm having a TMS570LS3137 USB dev. kit.
    In another thread I saw it was stated that a version 2.0 of the Hercules Demo Software should have been released in the middle of April (Source: http://e2e.ti.com/support/microcontrollers/hercules/f/766/p/158060/659667.aspx#659667)
    Well, i guess i have to try using CCS v5 and the source code found in the Hercules Demo Software folder. Wish me luck.
    /Andreas
    Report Abuse
    • Reply
  • Jan Rozek
    Posted by Jan Rozek
    on Jun 04 2012 17:37 PM
    Prodigy40 points
    I have also the problem with NowFlash 3.41, but with a windows 7 32bit version. NowFlash version 3.4.1 is installed by default and if I start the Hercules Safety MCU demo with a RM48 MCU HDK I get the message "You need nowFlash v3.4 or higher". I have also updated to version 3.4.2.
    In difference to the others is the version 3.40 and the components not included. What can I do now?
    Jan
    Report Abuse
    • Reply
  • Manoj R94504
    Posted by Manoj R94504
    on Jun 18 2012 00:28 AM
    Prodigy215 points
    There was a bug in the demo software.The demo software was not working properly for the german machines.The demo software(the launcher GUI) was basically checking  for the nowflash version >3.40 in order to flash the demo software onto the the board.In german machines conversion routines behaved differently as 3.41 is actually represented as 3,41 in german language.This has been fixed now and the solution should be avaiable in the next drop of the demo software.
    Manoj
    Report Abuse
    • Reply
  • Jan Rozek
    Posted by Jan Rozek
    on Jul 24 2012 09:41 AM
    Prodigy40 points
    When is the next fixed version of the demo software avaiable?
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
