• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Hercules™ Safety Microcontrollers » Hercules™ Safety Microcontrollers Forum » TMS470MF06607 ECLK Jitter spec
Share
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Hiroshi Kimizuka
Posted by Hiroshi Kimizuka
on Feb 01 2012 06:29 AM
Expert3510 points
My customer would like to clarify about the jitter value of the ECLK output (@20MHz) in TMS470MF06607.
Is there any characterized data of the jitter value on ECLK of TMS470MF06607 ?
Or, is there any calculation methodology to figure out the jitter value for ECLK, like a TMS470 App. note; Impact of ZPLL Jitter on CAN Communicatio
http://www.ti.com/lit/an/spna070a/spna070a.pdf    ?
Thanks and Best Regards,
KIMIZUKA
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Brian Fortman
    Posted by Brian Fortman
    on Feb 01 2012 08:41 AM
    Expert5255 points
    Kimizuka san,
    thank you for your post.  One of our experts will get back to you soon.
    Report Abuse
    • Reply
  • Haixiao Weng
    Posted by Haixiao Weng
    on Feb 01 2012 10:05 AM
    Genius9565 points
    While waiting for our experts, let me clarify some points.
    1, The best way to get a low jitter ECLK is to output the oscillator clock through ECLK. For example, if you want a 20MHz ECLK, then use a 20MHz crystal, and put the oscillator as the ECLK source. In this case, the ECLK jitter is dependant on the crystal that you use. Based on my experience 3 years ago on another device (same oscillator and PLL module), the ECLK jitter std value is around 10-20ps.
    2. If you choose PLL as the HCLK and VCLK source, and then divide the VCLK down as the ECLK output, then the ECLK jitter is dependant on the crystal and the PLL setting. The PLL jitter can be minimized by:
    NR is the input clock divider, which controls the frequency of the adjust pulse. A lower NR value means the error in PLL frequency is compensated faster, resulting in less jitter. The adjust pulse will go through a low pass filter (LF) before it applies to the VCO. The cut-off frequency of this low pass filter is controlled by the BWADJ field inPLLCTL2 register. A lower BWADJ value results in less jitter. During normal operation, any BWADJ less than 7 will be treated as 7. A Larger NF also generates less jitter.
    Haixiao
    Report Abuse
    • Reply
  • Hiroshi Kimizuka
    on Feb 07 2012 06:08 AM
    Expert3510 points
    Hi Haixiao,
    Thank you for your explanation.
    I just would like to clarify of the phrases; "A lower NR value" means small divisor ?
    "A larger NF" means big divisor ?
    Regarding ECLK jitter spec or observation methodology, I'm still expecting for any feedback from your expert.
    KIMIZUKA
    Report Abuse
    • Reply
  • Haixiao Weng
    on Feb 07 2012 10:42 AM
    Genius9565 points
    Let me give an example:
    Suppose the Crystal freq is 20MHz and you want an HCLK 80MHz, to minimize the jitter:
    1. The INTCLK should < 6.53MHz. So, choose NR=4. INTCLK=20/4=5MHz.
    2. We want NF as big as possible: the Output of PLL (before divisor) is 500MHz maxium according to the user guide, So, NF=480MHz/5MHz=96
    3. According to the datasheet the RCLK should be <145MHz, so, we have to set it to 80MHz. OD=6, R=1.
    4. Eventually, we get: 20/4*96/6/1=80MHz.
    5. Of cause, to minimize the jitter, you have to disable the FM mode and set BWADJ=7.
    Haixiao
    Report Abuse
    • Reply
  • Pratip Kumar
    Posted by Pratip Kumar
    on Feb 08 2012 07:59 AM
    Suggested Answer
    Intellectual2255 points
    KIMIZUKA,
    Let us know if your question is answered.
    Click and 'verify answer' if your question is answered.
    - Pratip
    Report Abuse
    • Reply
  • Pratip Kumar
    on Feb 17 2012 08:14 AM
    KIMIZUKA,
    We assume that you were able get this resolved.
    Please raise a new query if you still need our guidance.
    - Pratip
    Report Abuse
    • Reply
  • Hiroshi Kimizuka
    on Feb 20 2012 04:36 AM
    Verified Answer
    Verified by Hiroshi Kimizuka
    Expert3510 points
    Hi Pratip,
    Very sorry for my long delay of response. This is solved.
    KIMIZUKA
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
