• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Hercules™ Safety Microcontrollers » Hercules™ Safety Microcontrollers Forum » Connection problems with TMDXRM48HDK or TMDXRM48USB boards
Share
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
This question has suggested answer(s)
Martin Nelisse
Posted by Martin Nelisse
on Mar 06 2012 05:01 AM
Prodigy120 points
After installing the Hercules Development Kit CD-ROM and connecting a TMDXRM48HDK or TMDXRM48USB board, I have problems running the 'Hercules Safety MCU Demos', The downloading of the code to the boards succeeds, but when the programs run the connection to the board is lost. Looking for a cause I noticed an error message in Windows Computer Managment
Looking at the status for this device I see a message mentioning that the device does not start (Code 10). What is going wrong here and how to solve this problem and the communication problems?
Martin
TMDXRM48HDK TMDXRM48USB
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Jean-Marc Mifsud
    Posted by Jean-Marc Mifsud
    on Mar 07 2012 17:24 PM
    Suggested Answer
    Expert8985 points
    Martin,
    Do you have in your PC an XDS560 PCI card? If yes, the driver for this card are not installed.
    This has nothing to do with the demo problem you are facing.
    The demo software uses a COM port to communicate with the board.
    This COM port is a virtual serial port over USB.
    When you plug your TMDXRM48USB board on your PC, Windows should detect this COM port.
    In Computer Management, can you check and see under Ports (COM & LPT) if this virtual port is correctly detected?
    You should see something like "USB Serial Port (COMxx)
    If this is the case, the board is able to communicate with the application running on the PC.
    If it's not the case, try to re-install the driver for this COM Port (Right Click and Update driver).
    Please let me know the result of your debug.
    Jean-Marc
    Jean-Marc
    Application Engineer
    If my reply answers your question please click on the green button "Verify Answer".
    Report Abuse
    • Reply
  • Martin Nelisse
    on Mar 08 2012 02:49 AM
    Prodigy120 points
    I do not have a XDS560 PCI card installed, so why do I get this error message, when I do not have this card installed? Before installation of the HDK I never noticed this message....
    I see this port, depending on the board connected (we have 3x HDK and 1x USB boards)  it becomes COM4, COM6, etc
    When I try to update the driver anyway, it reports that the latest driver is already present.
    However with all boards I experienced similar problems: sometimes the demo software reports that the communication with the board has been lost....
    Martin
    Report Abuse
    • Reply
  • Jean-Marc Mifsud
    on Mar 08 2012 10:09 AM
    Expert8985 points
    Martin,
    I've forwarded your question to our Demo Software Expert.
    He should be helping you shortly.
    Jean-Marc
    Jean-Marc
    Report Abuse
    • Reply
  • Anthony Vaughan
    Posted by Anthony Vaughan
    on Mar 08 2012 15:14 PM
    Intellectual1275 points
    This problem sometimes happens due to COM port system security settings when running the demo software on Windows 7 PCs; to solve the problem run the demo application (Hercules Safety MCU Demos.exe) in 'Windows XP SP3' compatibility mode (click here for more info).  However; from the 'computer management' picture included in the original post it looks like the PC may be running Windows XP or 2000.
    If that is the case, I believe that the virtual COM port driver may not be installed properly on your system.  If this is the case the blue SCIRX and SCITX LEDs (TMDXRM48USB: located on the right side of the board near the USB connector;  TMDXRM48HDK: located on the left side of the board just to the right of the 20 pin ARM JTAG connector) will not blink at all when running any of the demos.
    USB STICK LEDs:        HDK LEDs:
    If this is the case, the first thing to try is uninstalling the virtual COM port from your system and then reinstalling it.  To do this follow these steps:
    1) Download the CDM Uninstaller application from this link. (CDMUninstaller_v1.4.zip)
    2) Open the CDMUninstaller_v1.4.zip file, extract the 'CDMuninstaller GUI.exe' file and run the application. (Make sure that the USB Stick or HDK is plugged into the PC.)
    3) In the CDM Uninstaller application enter the Vendor ID value '0403' and Product ID value 'A6D0'; then click the 'Add' button, then click the 'Remove Devices' button.
    4) After the CDM Uninstaller finishes uninstalling the COM port, unplug the USB Stick or HDK, then replug it into the PC's USB port.  The PC should automatically reinstall the driver.
    5) Run the demo software again and see if this fixes the problem.
    Report Abuse
    • Reply
  • Anthony Vaughan
    on Mar 08 2012 18:02 PM
    Another thing to try would be do download the Hercules Demo Board Information Utility and run it to see what it returns in the 'Board Communications Port' field.
    Report Abuse
    • Reply
  • Martin Nelisse
    on Mar 12 2012 04:56 AM
    Prodigy120 points
    I ran the program on 4x RM48 cards (3xHDK and 1xUSB):
    All reported: "Board Detected: Not Assigned" and "Board Revision: 0"
    The "Board Communications Port" was reported as: ASRL4::INSTR (USB), ASRL6::INSTR (HDK), ASRL8::INSTR (HDK), ASRL10::INSTR (HDK)
    I tried plugging in an out some of the boards, once I succeeded in getting a COM4 on the USB card and COM6 on a HDK card.....
    Martin
    Report Abuse
    • Reply
  • Anthony Vaughan
    on Mar 12 2012 11:22 AM
    Thank you for the information.  The 'Board Detected and Revision' results you received are expected.  The fact that the software returned 'ASRLxxx and COMx' indicates that the demo software driver is able to detect that a demo board is installed and is able to determine a communication port number.
    Can you confirm that you are having problems with the demo software on a PC running Windows XP?  Can you also check if either the SCITX or SCIRX LEDs blink when the demo software is run.  This problem is very much like one we have seen on Windows 7 PCs that have security settings configured to block access to COM ports.  Your PC may also be running some security software that is blocking access to these ports; could you also try temporally disabling any firewall/antivirus/security software that is running on your PC?
    Report Abuse
    • Reply
  • Martin Nelisse
    on Mar 12 2012 11:41 AM
    Prodigy120 points
    I am running Windows XP SP3. The problems occur when I run the 'Hercules Safety MCU Demos' program. The leds you mention blink when there is communication. I do not have privilegs to disable antivirus software (Symantec Endpoint Protection) due to corporate settings, no firewall is currently active,
    Additional info: I now downloaded/flashed a simple self made program on one of the boards which uses serial communication. When I use 'Termite' to communicate to the board, I do not experience communication problems (the serial communictaion in this case is only 9600 baud and involves just sending/receiving simple strings).
    Martin
    Report Abuse
    • Reply
  • Anthony Vaughan
    on Mar 12 2012 14:25 PM
     I checked the capabilities of Symantec Endpoint Protection and found out that it is capable of blocking data transfers to/from USB and COM ports.  Unfortunately it looks like the Symantec software is blocking the serial data to/from the demo software, but is allowing transfers to/from the Termite terminal program.  Without privileges to change the security settings on your PC I do not know how to get the demos to work.  The demo software needs to be able to communicate with the Hercules MCU via the virtual COM port on the development board; otherwise it will display the 'connection has been lost' error that you reported.  Is there another PC that you could use to run the demo software that does not require the Symantec protection software to be running?
    Report Abuse
    • Reply
  • Martin Nelisse
    on Mar 13 2012 02:47 AM
    Prodigy120 points
    Unfortunately all our computers are required to run Symantec Endpoint Protection....
    Martin
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
