• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Hercules™ Safety Microcontrollers » Hercules™ Safety Microcontrollers Forum » NHET for Safety applications
Share
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
This question has suggested answer(s)
Albert Kulangiev
Posted by Albert Kulangiev
on Apr 04 2012 05:07 AM
Prodigy20 points
I have some questions regarding the NHET modules of the TMS570.
My concern is the usage of NHET for safety applications. Since it is possible to change the NHET code during run-time by changing the NHET RAM directly in the main c-code. Which makes the NHET not really relevant for safety applications I guess?!?
1) When using NHET for safety applications are there any issues that have to be considered in order to prevent "violation of RAM access" from ""outside" e.g. Bit manipulation?
2) Are there any safety aspects of the NHET?
3) How can the NHET (RAM) be verified?
4) Is the NHET certified?
5 )What if I want to use for example NHET1 for QM part and NHET2 for ASIL part.How can I make sure that both NHETs won't interfere with each other?
6) Are there some guidelines how to write NHET programs so that such problems can not occur?
Thanks in advance!
Regards, Albert
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • KGreb
    Posted by KGreb
    on Apr 04 2012 13:30 PM
    Suggested Answer
    Expert6025 points
    The NHET (and previous HET) peripherals have been used in safety critical automotive applications for over a decade.  NHET configuration in SRAM is inherently no different than other peripherals which have memory mapped control registers; if typical precautions with memory protection are taken, you should not see any problem in using the NHET.
    1.  Per bus master memory protection units can be used to block access to the NHET configuration memory on undesired accesses.  You can also perform a periodic CRC on the NHET program memory using the CPU or DMA/CRC module to check NHET memory (assuming static programmation).
    2.  Please see the TMS570LS31x/21x safety manual available at www.ti.com/hercules for information on using the NHET in safety applications.
    3.  As noted in safety manual, NHET memory has built-in parity diagnostic, PBIST SRAM test capability, and is memory mapped to support additional testing via CPU.
    4.  I am not aware of any standard which would require review and certification of any peripheral for safety critical usage.
    5.  Each NHET has a memory protection unit upon its bus master.  This can be used to limit access from each NHET to dedicated, non-overlapping memory spaces.
    6.  Please see the TMS570LS31x/21x safety manual available at www.ti.com/hercules for information on using the NHET in safety applications.
    Karl
    Report Abuse
    • Reply
  • Albert Kulangiev
    on Apr 06 2012 04:30 AM
    Prodigy20 points
    Hello Karl,
    thanks for the answer!
    Can you provide a simple code example of how you would execute a PBIST on NHET RAM?
    In the Safety Manuel I read something about SRAM CRC-64 Testing which can be used to verify the contents of the NHET RAM
    That sounds interesting but I couldn't find further information on that on how this can be implemented?
    Albert
    Report Abuse
    • Reply
  • KGreb
    Posted by KGreb
    on Apr 09 2012 07:33 AM
    Expert6025 points
    Hello Albert,
    The HALCoGen tool should allow you to create a simple PBIST test for the NHET RAM.
    For CRC testing, you can configure the DMA to read from NHET RAM and write to the CRC module to generate the CRC without CPU intervention.  Optionally you can do the same with the CPU if you do not want to program the DMA.
    In general, the safety manual will give you the hint of what you need to do to execute a test, but the TRM will provide the details of how to use a specific diagnostic.  This is done to avoid duplication of content.
    Karl
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
