• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Hercules™ Safety Microcontrollers » Hercules™ Safety Microcontrollers Forum » FlexRay - every third interrupt not generated
Share
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
Martin Zeman
Posted by Martin Zeman
on May 03 2012 13:10 PM
Prodigy135 points
I'm handling interrupts generated by FlexRay controller at the start of a FR frame. My handler is set as FIQ. The problem is that for some reason every third FR cycle the interrupt is not generated. Sometimes it leaves out even more often. I have no other interrupts set as FIQ, so it should always have a top priority. I have checked that all the frames in all the cycles are succesfully trasmitted on the bus. Here is a sample of my code:
The FR interrupt handler is in one .c  file:
#pragma INTERRUPT(FR_interrupt, FIQ)
void FR_interrupt(void){
    clear_status_interrupt_register();
    FR_rcv_flg = 1U;
The ISR is in another:
while (running) {
            lwipPeriodicHandle(s_timestamp);
            if (FR_rcv_flg) {
                FR_to_udp();
            if (eth_rcv_flg) {
                decode_udp_runtime();
I know for a fact that every interrupt which is generated is also serviced in "FR_to_udp()" so the problem lies in the interrupt not being generated at all. Does anyone have an idea what might be causing this?
Best regards
Martin
tms570 FlexRay interrupt HDK cycle
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Chuck Davenport
    Posted by Chuck Davenport
    on May 03 2012 13:19 PM
    Expert6315 points
    Hello Martin:
    In order to try and help you get a quick resolution to your issue with the FlexRay interrupts, I am forwarding your post to our FlexRay expert. He should respond shortly.
    Chuck Davenport
    Thanks and Regards,
    Chuck Davenport
    If this response answers your question, please indicate it by verifying the suggested answer when provided.
    Report Abuse
    • Reply
  • Peter Steffan
    Posted by Peter Steffan
    on May 04 2012 04:20 AM
    Prodigy185 points
    Hello Martin,
    From the FlexRay hardware perspective we never saw missing start of cycle interrupts.
    From the code you provided, I could think of 2 possible causes for the issue you see:
    1.  CYCS flag (bit #2) in the SIR (Status Interrupt Register) does not get cleared properly:
    When looking to your interrupt handler I assume that you are clearing the CYCS flag (bit #2) in the SIR (Status Interrupt Register) in the function clear_status_interrupt_register(); Correct?
    Are you sure the flag always gets cleared properly in this subroutine? Since the clearing of one flag can be done in one simple C instruction, I would propose to remove the function call and clear the CYCS flag directly with one instruction in the interrupt handler.
    2. FR_to_udp() does not always get entered after a start of cycle interrupt:
    What concerns me more is the line FR_rcv_flg = 1U; in the interrupt handler, where you set a 'marker' to enter FR_to_udp() later in the ISR. I can not see in your code the exact point where you reset FR_rcv_flg back to 0, but I am sure you do it somewhere.
    However, in case
    • this would happen too late, after the next start of cycle interrupt occurs, or
    • FR_rcv_flg would get corrupted due to any reason (variable unexpectedly gets overwritten, i.e. by a stack overrun or an incorrect pointer),
    then the code might not always enter FR_to_udp(). This could, by mistake, be interpreted as a not generated start of cycle interrupt.
    Peter Steffan
    Report Abuse
    • Reply
  • Martin Zeman
    on May 04 2012 07:18 AM
    Prodigy135 points
    Hello Peter,
    thanks for your suggestions, however I'm not using the start of cycle interrupt but the received frame interrupt. The function clear_status_interrupt_register() indeed does nothing else but clear the whole SIR like this:
    void clear_status_interrupt_register(void){
        frayREG->SIR_UN.SIR_UL = 0xFFFFFFFF;
    Clearing right in the interrupt handler is a good idea, thanks for the suggestion, but it didn't prove to be the cause. After doing some testing I can rule out that FR_to_udp() not entered. Every time an interrupt is generated it is also serviced in FR_to_udp(). The FR_rcv_flg gets reset the first thing in the FR_to_UDP().
    I'm starting to think that the problem might have to do with some of the FR controller parameters. I have 2 nodes with freescale controllers whose parameters are known to me, so I set my tms570ls3137 E-ray controller according to those parameters. I presumed that the parameters are flawless, which they might be, I'm just not certain. The only thing that comes to my mind right now is that the rate correction is applied in every third cycle. That might have something to do with it...
    tms570 FlexRay interrupt HDK rate corretion
    Report Abuse
    • Reply
  • Chuck Davenport
    on Dec 19 2012 14:00 PM
    Expert6315 points
    Hello Martin,
    As of your last posting, it seems you were still having some issues with your FlexRay setup. Were you able to resolve your issue? If so, it might be helpful if you could post your final resolution or simply that it was resolved. If you still need additional help on this topic, please let us know.
    Thanks and Regards,
    Chuck Davenport
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
