• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Hercules™ Safety Microcontrollers » Hercules™ Safety Microcontrollers Forum » How to store a value to a memory location which is defined in linker command file
Share
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
joy liu
Posted by joy liu
on Aug 08 2012 12:12 PM
Prodigy175 points
A table run time located on M3 flash need to be accessed from R4 flash code. To achieve this, I located a 4 bytes memory on M3 flash in linker command file using a name. When the address of the table is available, the C code will store the address of the table to the memory through this name. Below is the code just doing this.
 void * table_ptr[2];
table_ptr[0] = getTableAddress();   /* the address of the table is now stored in the 1st element of the table_ptr array */
unsigned int  * memory_ptr;
memory_ptr = &memory_label    /* memory_label is defined in linker command file with a fixed memory address */
*memory_ptr = (unsigned int) (table_ptr[0]);
The above code doesn't work and the content at  memory_lable is still blank after executing the code. dose anyone know what is the problem and how to solve it. Thank you.
Joy
ARM® Cortex™-M3
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Zhaohong Zhang
    Posted by Zhaohong Zhang
    on Aug 08 2012 14:41 PM
    Genius9255 points
    Joy,
    Your last instruction should be
    *memory_ptr = (unsigned int) (*table_ptr[0]);
    From your debugger, you should be able to check if memory_ptr and table_ptr[0] have the correct address.
    Thanks and regards,
    Zhaohong
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
