FORUM RELATED LINKS:
TMS570 Microcontroller forum page: (For technical support and product information for the TMS570 Microcontroller.)http://e2e.ti.com/support/microcontrollers/tms570/f/312.aspx
TMS570 News & Updates forum page: (For the latest news, announcements, and updates)http://e2e.ti.com/support/microcontrollers/tms570/f/363.aspx
TMS570 Safety & Systems forum page:http://e2e.ti.com/support/microcontrollers/tms570/f/362.aspx
TMS570 forum main page: (For viewing all available forums in the TMS570 main forum)http://e2e.ti.com/support/microcontrollers/tms570/f/default.aspx
TI E2E (Engineer to Engineer) main forum page: (TI's main forum page - navigate to forums of different TI groups from here.)http://e2e.ti.com/?DCMP=TIHomeTracking&HQS=Other+OT+home_d_e2e_community
TOOLS RELATED LINKS:
Code composer download link:http://tiexpressdsp.com/index.php/Download_CCS
HalCoGen code generation tool:http://focus.ti.com/docs/toolsw/folders/print/halcogen.html
TMS570 ECC generation tool, nowECC:http://focus.ti.com/docs/toolsw/folders/print/nowecc.html
TMS570 F035 Flash API:http://focus.ti.com/docs/toolsw/folders/print/f035flashapi.html
TMS570 Flash Programming tool, NowFlash:http://focus.ti.com/docs/toolsw/folders/print/nowflash.html
TMS570 F035 FMzPLL Configuration/Calculator tool (for System Clock): http://focus.ti.com/docs/toolsw/folders/print/fmzpll_calculator.html
TMS570 F035 FPLL Configuration/Calculator tool (for FlexRay):http://focus.ti.com/docs/toolsw/folders/print/fpll_calculator.html
TMS570 Microcontroller Development Kit (Part Number: TMDX570LS20SMDK):http://focus.ti.com/docs/toolsw/folders/print/tmdx570ls20smdk.html
TMS570 Microcontroller USB Kit (Part Number: TMDX570LS20SUSB):http://focus.ti.com/docs/toolsw/folders/print/tmdx570ls20susb.html
TMS570 HET IDE/simulator tool:http://focus.ti.com/docs/toolsw/folders/print/het_ide.html
NHET assembler tool (Software Part Number: SPNC019):http://focus.ti.com/docs/toolsw/folders/print/spnc019.html
DOCUMENTATION RELATED LINKS:
TMS570 Transportation and Safety Microcontrollers web page: www.ti.com/tms570
TMS570 Technical Documents page including Application Notes, TRM/User's Guides, Errata etc:http://focus.ti.com/mcu/docs/mcutechdocs.tsp?sectionId=96&tabId=1502&viewType=mostuseful&rootFamilyId=4&familyId=1870
Here are some direct links to TMS570 TRM, Datasheet, Errata and ARM Cortex-R4F TRM: If any of the direct links don't work, navigate to them from the TMS570 Technical Documents page http://focus.ti.com/mcu/docs/mcutechdocs.tsp?sectionId=96&tabId=1502&viewType=mostuseful&rootFamilyId=4&familyId=1870 :
TMS570 series Microcontroller Technical Reference Manual/User's Guide (SPNU489)http://focus.ti.com/lit/ug/spnu489b/spnu489b.pdf
TMS570 series Microcontroller Datasheet (SPNS141):http://focus.ti.com/lit/ds/spns141e/spns141e.pdf
TMS570 series Microcontroller Errata (SPNZ176):http://focus.ti.com/lit/er/spnz176c/spnz176c.pdf
ARM Cortex-R4F Technical Reference Manual:http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0363e/index.html
Here are some direct links to User's Guides: If any of the direct links don't work, navigate to them from the TMS570 Technical Documents page http://focus.ti.com/mcu/docs/mcutechdocs.tsp?sectionId=96&tabId=1502&viewType=mostuseful&rootFamilyId=4&familyId=1870 :
nowECC User's Guide:
http://focus.ti.com/lit/ug/spnu491/spnu491.pdf
nHET Assembler User's Guide:http://focus.ti.com/lit/ug/spnu490/spnu490.pdf TMS470/570 Application Programming Interface User's Specification: http://focus.ti.com/lit/ug/spnu493/spnu493.pdf
TMS570 MDK User Guide (TMDX570LS20SMDK):http://www.keil.com/support/man/docs/mcbtms570/mcbtms570_intro.htm
TM570 Code Gen Tool User Guide: http://processors.wiki.ti.com/index.php/ARM_Code_Generation_Users_Guides
Here are some direct links to Application Notes: If any of the direct links don't work, navigate to them from the TMS570 Technical Documents page http://focus.ti.com/mcu/docs/mcutechdocs.tsp?sectionId=96&tabId=1502&viewType=mostuseful&rootFamilyId=4&familyId=1870 :
"Programming TMS570x Flash Using Flash API" App Note:http://focus.ti.com/general/docs/litabsmultiplefilelist.tsp?literatureNumber=spna117 "Recommended Initializations for TMS570 Microcontrollers Application Report" App Note:http://focus.ti.com/general/docs/litabsmultiplefilelist.tsp?literatureNumber=spna119
"NHET Getting Started" App Note:http://focus.ti.com/general/docs/litabsmultiplefilelist.tsp?literatureNumber=spraba0
TI's Embedded processor wiki webpage:http://tiexpressdsp.com/index.php/Main_Page
Here are some tool vendor links to download supporting software:
Spectrum Digital driver installers for installations without Code Composer Studio:
CCSv4.x : http://support.spectrumdigital.com/ccs42/Updates/features/
CCSv5.x: http://support.spectrumdigital.com/ccs51/Updates/features/
Hi there
Nice to have it condensed but at least this one is obsolete:
substituted by SPNU499
www.ti.com/lit/ug/spnu499/spnu499.pdf
Cheers
Matthias
Hello Matthias,
The spnu489 and spnu499 are the reference manuals for two different microcontrollers, TMS570LS20x and TMS570LS31x/21x respectively. These microcontrollers are different in several aspects and do call for separate reference manuals. There are some chapters that are indeed common to both.
Regards, Sunil
