Is there any linker script manual available ?
There is a document that explains the assembly language tools in more detail. This document can be found at:
http://focus.ti.com/lit/ug/spnu118h/spnu118h.pdf
This document provides several examples of the linker command file and the scripting syntax.
However, it does not go into enough details regarding the C/C++ compiler. Use the C/C++ Compiler's User Guide at http://focus.ti.com/lit/ug/spnu151e/spnu151e.pdf for details on the compiler.
Thanks.
to keep this post up to date the first document is available here: http://www.ti.com/lit/pdf/spnu118
also check:
http://processors.wiki.ti.com/index.php/ARM_Code_Generation_Users_Guides
