i have worked with the sample codes Halcogen. how can i control the duty cycle of PWM signal externally. i need sample codes and procedure for generating/controlling the PWM signal output from the controller.
No i need to change the duty cycle of PWM based on the feed back from sensor module.(flow sensor).
Can you check if this article on the e2e website helps:
Hercules LaunchPad Type II: ePWM example - change duty cycle with the user buttons
