i am using serial terminal to view the UART output. did the scroll buffer size affects the output that can be viewed in terminal window.
4645.sys_main.cI am using serial terminal in CCS and also checked with serial Port terminal software to view the output. but i can able to view only three outputs and can not able to view the other three sensor outputs(totally interfaced 6 sensors). please lend me some support to clear the errors. for you reference i have attached my sys main.c file
Thanks and regards
K.Manjunathan
