Dears,
When I try to connect TMS570LS20206ASPGE to the PC using XDS200 via CCStudio 6.0, I get the below error:
Dears,
Sim,
At first look, your schematics look correct.
If I understand your problem, connection are possible, but it is not stable.
Can you try to reduce the JTAG speed? This is possible using the following tab in CCS.
Double click on your target configuration, and go to Advance Setup->Target Configuration. The following page will open:
Dear Jean-Marc,
Thank you for your reply.
I will try to change JTAG speed.
Dear Jean-Marc,
My customer tested your suggestion. But It did not solve the problem.
So they checked circuit by oscilloscope. I attached the file.
please refer to the attached file.
Please review this files.
Thanks & Regards,
