We are trying to use the GIOB[5] functionality on pin 55 of a TMS570LS1225 to generate a GIO interrupt.
In any case we try to configure the pin funcionality by PINMMR9[18] bit,but we are not able to set it. Neither the HalcoGen generate code is able to set it.
In any case we are not able to see the pin value on the GIOB DataIn register.
We understand from the manual that for this pin you can not use the GIO output funcionality, but we only want to use it as an input pin. But we don't know how to configure it. Neider seems the HalcoGen to be configuring it in the right way.
Thanks you in advance.
