Each hex value from the auto generated c files causes at least one MISRA message.
#1393-D (MISRA-C:2004 10.1/R) The value of an expression of integer type shall not be implicitly
converted to a different underlying type if it is not a conversion to a wider integer type of the same
signedness
Rule 10.6 (required): A “U” suffix shall be applied to all constants of unsigned type.
Since Hercules controllers are intended for use in safety related context, it would be be helpful to get auto generated code that is MISRA compliant.
The messages are found with TI built in MISRA checker and third party tools.
The tool is involved with
d:\xxx>c:\ti\Hercules\bin\hetp.exe -v2 -hc32 -x -n0 d:\xxx\ATEL\ATEL.het
NHET Assembler Release 1.7
Texas Instruments Incorporated.
PASS 1
PASS 2
No Errors, No Warnings
d:\xxx>c:\ti\Hercules\bin\hetp.exe -v2 -hc32 -x -n1 d:\xxx\BTEL\BTEL.het
PASS 1
PASS 2
Best Regards
Olaf
