Other Parts Discussed in Thread: HALCOGEN
I have a code extracted from a script (.gel) sent here at TI forum to enable the CTIs.
But sometimes (not always!) when running the code line showed below, I have a Data Abort Exception (a Synchronous External Abort).
When that happens, if I simply turn off and then on the power supply of the dev. board, it all starts working perfectly (i.e. no exceptions and the CTI is enabled).
The code that causes the excpetion is:
*(int *) 0xffa07fb0 = 0xc5acce55; /* Unlock writes to CTI */
Any thoughts on what could be the source of this issue?
Thank you,
Marcio
