hi sir,
i am using TMS470MF06607 microcontroller.
i generate the hex file for my project. but i don't know how to flash the hex file in to my micro controller.
i want to flash only the hex file into my micro controller not the .out file.
i just mentioned what step i followed to generate the hex file, can you please tell me is it right way or not ?
steps i followed:
properties -> ARM Hex Utility -> Output Formate Option
from here i generate the hex file (intel format). after generating i got the 4 types of hex files. like: project.i1 , project.i2 , project.i3 , project.hex .
from this four hex file which one i want to use for flashing purpose.
1) can you tell me the proper procedure to generate the hex file ??
2) how i want to flash the hex file into the micro ?? i want to flash the hex file alone is it possible ??? possible means how ??
3) is it any flash tool is available to flash the hex file alone into the micro controller ??? is it available means can you please tell how i want to use that flash tool aslo???
can you please provide me the solution for this issue
regards
Arun Kumar.N
