• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Hercules™ Safety Microcontrollers » Hercules™ Safety Microcontrollers Forum » Protection circuit for ESD/EMC immunity on TMS470MF06607
Share
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Hiroshi Kimizuka
Posted by Hiroshi Kimizuka
on Aug 06 2010 10:59 AM
Expert3580 points
I got an inquiry about the protection circuit to be attached on GPIO, CAN, nRST pins of TMS470MF06607 from my customer.
In order to enhance the immunity on ESD/EMC, could you please show the example circuit ?
Thanks in advance and Best Regards,
KIMIZUKA
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Haixiao Weng
    Posted by Haixiao Weng
    on Aug 09 2010 15:53 PM
    Verified Answer
    Verified by Anthony Vaughan
    Genius9945 points
    Kimizuka,
    For reset pin: (user can no-pop the cap/res for nRST, cap for the nPORRST at the beginning, and assemble them if the ECU fails ESD/immunity test).
    For TEST and ENZ pin (Please do not rely on the internal pull down):
    CAN: No protection is needed in the path from MCU to CAN transceiver. If this trace is long (>5cm), please consider reserve the footprint of a SMT capacitor to ground (in the driver end). This capacitor can slow down the edge and mitigate the emission in case it turns to a problem. In the transceiver side, usually, there are a TVS diode and a high voltage capacitor (around 100pF) together for EMC/ESD protection. They should placed as close to the connector as possible. The characteristic of the TVS diode should refer to their customer’s requirement for ESD.
    GPIO pins: if they served as external interrupt purpose, a low pass filter is needed in front of the pin. If they go the connector, please consider the ESD protection. Depending to the requirement, it could be a resistor + a high voltage capacitor, or a TVS diode + a high voltage capacitor.
    Haixiao
    Report Abuse
    • Reply
  • Craig Quick
    Posted by Craig Quick
    on Jan 20 2012 21:47 PM
    Prodigy10 points
    Haixiao,
    I took you advice and used a 1nF cap placed near the nPORRST pin and it helped my ESD immunity. I am curious though, I tried a .1uF can in the same configuration but it did not help. Can you explain why this might be? I am using the 1K pull-up resistor. I don't however know what the internal circuitry of the nRST and nPORRST are inside the micro.
    Any help you could offer would be greatly appreciated. I am just curious now...can't figure out why .1uF wouldn't do....
    Thanks!
    Craig
    Report Abuse
    • Reply
  • Haixiao Weng
    on Jan 21 2012 13:40 PM
    Genius9945 points
    I don't know exactly why 0.1uF does not help in your case. What is the type of this test, contact discharge or air-discharge? What is the schematic and layout of this pin? Is it possible to get the waveform on this pin during ESD test? Anyway, I don't recommend 0.1uF due to other reasons:
    1. The startup ramp (from 20% to 80%) of PORRST should be less than 10us. Therefore, a 0.1uF with a 1k resistor is not suitable.
    2. nRST sometimes is an output pin, 4mA IO, driving an 0.uF capacitor might cause damage on this pin after thousands of powercycling.
    The internal circuit:
    1. PORRST: input with 100uA pull down.
    2. nRST:  input with 100uA pull up or Open drain output (during normal operation, it is input but it is opendrain output when PORRST is low or reset occurs)
    Haixiao
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
