Other Parts Discussed in Thread: HALCOGEN
I have a working nominal MibSPI loopback implementation and I am trying to use the 27.3.42 I/O-Loopback Test Control Register (IOLPBKTSTCR) to Inject the Various errors during the test.
The only error that I have been able to successfully inject is:
Bit [20] CTRL BITERR Controls inducing of BITERR during I/O loopback test mode. 0 Do not interfere with looped-back data. 1 Induces bit errors by inverting the value of the incoming data during loopback.
Causing a:
Bit [28] BITERR in the RX Ram Flags
Is there any supplemental documentation around mibspi loopback fault injection that I can follow? Does SPI need to be set up in a specific way for the fault injection to work?
Any information would be helpful.
Thank you
