  • Resolved
TMS570LC4357: When does ESM Group 1 Bit 52 occurs?
Part Number: TMS570LC4357
Hello Support,
I understand when does ESM Group 2 Bit 3 occurs according to
https://e2e.ti.com/support/microcontrollers/hercules/f/312/t/592638
Question is under what condition does ESM Group 1 Bit 52 occurs?
CPU Interconnect Subsystem - Global error          Group1                52
Some details similar to previous link mentioned above from experts will help me understand better.
Thank you.
Pashan
  • Hello Pashan,
    I have forwarded your question to Mr.Crosby. He should reply shortly.
    Thanks and Regards,
    Chuck Davenport
  • In reply to Chuck Davenport:
    The CPU Interconnect subsystem is described in section 4.3 of the Technical Reference Manual. This ESM flag will be set on a parity error in the control or address signals. The most common occurrence of ESM error Group 1 Channel 52 is an inadvertent error that may happen after running the CPU self test at a GCLK frequency greater than the maximum HCLK frequency. This behavior is explained in device erratum DEVICE#48 in the errata document. In that case, the ESM flag may be cleared and the error ignored.
    Bob Crosby
