we have a project that tries to send mixed identifiers on the same CAN bus / from the same DCAN module. Somehow it seems that only the last configured message is taken into account. If we are configuring several messages with extended IDs and a few ones with standard CAN ID while those standard CANs are processed last, all messages that are sent out only carry a 11bit ID. If it is the other way around, even those messages configured as standard ID will be sent with an extended ID (standard ID plus filled in 0's).
We found a similar problem here : https://e2e.ti.com/support/microcontrollers/hercules/f/312/t/484322?tisearch=e2e-quicksearch&keymatch=tms570%20can%20extended
But this thread didn't gave us the right clue for a solution.
Can you tell, if mixed IDs are working on the same CAN module?
Best regards
