TMS570LS2124: DIEIDL and DIEIDH: slightly different description in datasheet vs. TRM?
Part Number: TMS570LS2124
Team,
The description for the DIEID differs in both documents. Which one is correct?
This is in the datasheet (SPNS165B, page 156. 12 bit for X and Y, 8 bit wafer#):
Whereas the TRM (SPNU499B, page 150. 8 bit for X and Y, 6 bit wafer#) has this info:
  Robert
  • Hi Robert,
    The TRM, in this case, is incorrect and the datasheet is correct. As always, posting a question when you encounter an issue such as this is always a good idea to confirm, but also there is a general hierarchy of the documentation in that the Datasheet is the document that takes precedence as this is the document that defines the device specification. The TRM as named, is primarily a reference document.
    I will submit a documentation bug for this so it can be added to the list of issues to be fixed in the next release of the document. Thanks for pointing out this inconsistency so we may address it!
