Other Parts Discussed in Thread: HALCOGEN
Hi Team,
My customer now is using TMS570LS1227 as the traction inverter controller, which required at least ASIL-C level. while customer is using the safeTI Diagnostic library 2.3.1 for knowing the how to implement the safety library, but report an issue that the demo provided by the library run to while(1) within void _excpt_vec_abort_pref(); but with the emulator connected and debug step by step, the code will be executed well. Could you kindly give comments on this issue? PS: The demo file path: C:\ti\Hercules\SafeTI Diagnostic Library\2.3.1\build\TMS570LS1227_NoOS; Expect for your reply, thanks. Best Regards Benjamin
