I understand there is a lot of stuff programmed in the DSP OTP memory, is there a document that show a memory map and a description of all that stuff?
Martin
Martin
Hello Wang,
Thanks for the information but what I would like is something more complete. For example, the OTP contains the AJSM key, deliberately corrupted data to test ECC protection and more. These memory areas are referred to in various documents but I was wondering if there was a document that shows the complete content of the OTP, TI and customer.
Martin
Hello Martin,
The AJSM 128-bit visible unlock code or lock key (secured device) is at OTP address 0xF000_0000. The part is documented in the device datasheet.
The deliberate ECC errors is not included in LS3237 TRM. Please refer to section 7.6 of spnu562. All the hercules devices have the deliberate ECC errors in OTP at the same address (0xF00803F0 and 0xF00803F8).
I have another question about the deliberate ECC error. In SPNA106D section 2.14, it is said that the OTP contains this data with deliberate ECC errors.
This document is for Cortex -R4F so why are those error not included in the TMS570LS3137? When I read those addresses I see data 0x12345678 and 0x9ABCDEFx but it doesn't generate an error.
Is it about the revision? I am using a chip revision C.
Martin
