Other Parts Discussed in Thread: HALCOGEN
Dear Support,
I tried to use capGetSignal functions to capture PWM signals. I could use it with several HET1 pins except HET1_11. It seems to me it measures well the duty cycle but I can see 100 times bigger value in case of period than it should be. I tried to use the HET2_18 as well (it's on the same pin) but I got the same problem. Can you help me to solve this problem? Thank you!
hetRAM1:
HET configuration:
Kind regards,
Keno
