CCS/TMS570LC4357: MibSPI Master w DMA example. MiBSPI5 communication does not start (spna231)
Part Number: TMS570LC4357
Other Parts Discussed in Thread: HALCOGEN,
I tried to port the example code from spna231.pdf (www.ti.com/.../spna231) from RM48 to TMS570LC43. As far as I can see, the DMA channel for MibSPI5 is the same for both controllers.
I replicated all relevant settings for HALCoGen, and copied the logic from the original project's main to HL_sys_main.
The program compiles and runs but does not start the MibSPI5 communication. I tried to use it with and without ENA functionality.
Settings done in HALCoGen:
Drivers
MibSPI5
GIO (for led)
MPU
Enable MPU background region
GIO
Set GIOB_6 to output (User Led 2)
PINMUX
MibSPI5
GIOB6 J2
Interupts
33: DMA FTCA on
MibSPI5
GLOBAL
OVR ON
BIT ON
DES ON
PAR ON
TIM ON
DLN ON
DATA Format 0
Baudrate 20000
Wait for Enable -- if desired
Parity enable  -- if desired
WDELAY 5
Delays
7 5 10 10
Transfer Group 0
Lock Transmission
Buffer Mode 5
Lenght 64
Chip Select Hold ON
Oneshot transfer OFF
PORT
SCI 1 SPI  -- not used
SCI 2 SPI  -- not used
SCI 3 SPI  -- not used
SIMO1 DIR OUT
SIMO2 DIR OUT
SIMO3 DIR OUT
I've attached the ported CCS project to this report.
content of the HL_sys_main.c (same as original main.c, but using a different LED (one from the LaunchXL2 on GIO B 6, instead of one of the HET pins)
/** @file HL_sys_main.c
*   @brief Application main file
*   @date 07-July-2017
*   @version 04.07.00
*   This file contains an empty main function,
*   which can be used for the application.
* Copyright (C) 2009-2016 Texas Instruments Incorporated - www.ti.com
*  Redistribution and use in source and binary forms, with or without
*  modification, are permitted provided that the following conditions
*  are met:
*    Redistributions of source code must retain the above copyright
*    Redistributions in binary form must reproduce the above copyright
*    documentation and/or other materials provided with the
*    distribution.
*    Neither the name of Texas Instruments Incorporated nor the names of
*  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
*  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
*  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
*  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
*  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
*  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
*  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
*  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
*  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
*  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
*  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE BEGIN (0) */
/* USER CODE END */
/* Include Files */
#include "HL_sys_common.h"
/* USER CODE BEGIN (1) */
#include "HL_sys_dma.h"
#include "HL_gio.h"
#include "HL_mibspi.h"
#define LEDPORT gioPORTB
#define LEDPIN 6ul
#pragma DATA_ALIGN(source, 8); /* Note: It is very important to keep the data alignment on 64-bit for the DMA */
static uint16_t source[64];
mibspiRAM_t * const pMibSpiP5Ram = mibspiRAM5;
/* USER CODE END */
/** @fn void main(void)
*   @brief Application main function
*   @note This function is empty by default.
*   This function is called after startup.
*   The user can use this function to implement the application.
/* USER CODE BEGIN (2) */
/* USER CODE END */
int main(void)
/* USER CODE BEGIN (3) */
    int32_t  i32Index   = 0l;
    uint16_t ui16Index2 = 0u;
    uint16_t ui16Check  = 0u;
    g_dmaCTRL g_dmaCTRLPKT;
    gioInit();
    mibspiInit();
    mibspiREG5->DMACNTLEN  =    0ul; /* Disable Large Count */
    mibspiREG5->DMACTRL[0] =  ( 1ul << 31)   /* Auto-disable of DMA channel (in MibSPIP) after ICOUNT+1 transfers. */
                            | (63ul << 24)   /* Buffer utilized to trigger DMA transfer. */
                            | ( 0ul << 20)   /* RXDMA_MAPx */
                            | ( 2ul << 16)   /* TXDMA_MAPx */
                            | ( 0ul << 15)   /* Receive data DMA channel enable. */
                            | ( 0ul << 14)   /* Transmit data DMA channel enable. */
                            | ( 0ul << 13)   /* Non-interleaved DMA block transfer. This bit is available in master mode only. */
                            | ( 0ul <<  8);  /* ICOUNTx */
    /* Enable DMA module : this brings DMA out of reset */
    dmaEnable();
    /* Configure DMA Control Packed (structure is part of dma.c) */
    g_dmaCTRLPKT.SADD      = (uint32_t)(&source[0]);  /* initial source address */
    g_dmaCTRLPKT.DADD      = (uint32_t)(&(pMibSpiP5Ram->tx[0].data)); /* initial destination address */
    g_dmaCTRLPKT.CHCTRL    = 0ul; /* channel control */
    g_dmaCTRLPKT.RDSIZE    = ACCESS_64_BIT; /* read size */
    g_dmaCTRLPKT.WRSIZE    = ACCESS_16_BIT; /* write size */
    g_dmaCTRLPKT.FRCNT     = 1; /* frame count */
    g_dmaCTRLPKT.ELCNT     = (sizeof(source) / sizeof(source[0])) / 4;   /* element count */
    g_dmaCTRLPKT.ELSOFFSET = 1ul << g_dmaCTRLPKT.RDSIZE; /* element source offset */
    g_dmaCTRLPKT.FRSOFFSET = 0ul << g_dmaCTRLPKT.RDSIZE; /* frame source offset */
    g_dmaCTRLPKT.ELDOFFSET = 2ul << g_dmaCTRLPKT.WRSIZE; /* element destination offset */
    g_dmaCTRLPKT.FRDOFFSET = 0ul << g_dmaCTRLPKT.WRSIZE; /* frame destination offset */
    g_dmaCTRLPKT.PORTASGN  = 4ul; /* port b */
    g_dmaCTRLPKT.TTYPE     = FRAME_TRANSFER ; /* transfer type */
    g_dmaCTRLPKT.ADDMODERD = ADDR_OFFSET;     /* address mode read */
    g_dmaCTRLPKT.ADDMODEWR = ADDR_OFFSET;     /* address mode write */
    g_dmaCTRLPKT.AUTOINIT  = AUTOINIT_ON;     /* autoinit, on, MIBSPI controls DMA transfers (ICOUNT) */
    /* Assign DMA Control Packet to Channel 0 */
    dmaSetCtrlPacket(DMA_CH0, g_dmaCTRLPKT);
    /* Assign DMA request: channel-0 with request line - 8 */
    dmaReqAssign(DMA_CH0, 6ul); /* Request Line 6 is MIBSPI5[2], this is MIBSPI5 in buffered mode */
    /* Set the DMA Channel 0 to trigger on h/w request */
    dmaSetChEnable(DMA_CH0, DMA_HW);
    /* Enable Parallel Mode for high data throughput */
    mibspiPmodeSet(mibspiREG5, PMODE_4_DATALINE, DATA_FORMAT0);
    do
        static _Bool    qFirstLoop = true;
        static uint32_t u32Count   = 0ul;
        ui16Check = 0u;
        while(dmaREG->PEND & (1ul << 0) != 0ul)
            /* Wait till DMA TX transfer has been finished */
        while(mibspiREG5->DMACTRL[0] & (1ul << 14) != 0ul)
        /* Generate some dummy data to send */
        for (i32Index = 0l ; i32Index < ((sizeof(source) / sizeof(source[0])) - 1); i32Index++)
            /* Calculate a checksum for the dummy data packet */
            ui16Check       += ui16Index2;
            source[i32Index] = ui16Index2++;
        /* Add checksum to the end of the data packet */
        source[(sizeof(source) / sizeof(source[0])) - 1] = ui16Check;
        /* Enable DMA control in the MIBSPI, this will be auto cleared (Auto-disable of DMA channel Feature) */
        /* The first DMA request pulse is generated right after setting TXDMAENAx to load the first transmit data. */
        mibspiREG5->DMACTRL[0] |= (1ul << 14); /* Transmit data DMA channel enable. */
        if (true == qFirstLoop)
            /* Trigger MIBSPI transfers */
            mibspiTransfer(mibspiREG5, 0ul);
            qFirstLoop = false;
        else
            /* Do Nothing */
        if (u32Count % 10000ul == 0ul)
            gioSetBit(LEDPORT, LEDPIN, !gioGetBit(LEDPORT, LEDPIN));
        u32Count++;
    while(1);
/* USER CODE END */
    return 0;
/* USER CODE BEGIN (4) */
/* USER CODE END */
Symptoms: the program runs through the first main loop, then on the second entry, keeps waiting here:
Nothing happens with the MibSPI5 pins. No CS low, no clock, no data flowing.
My project attached:
8231.TMS570LC43_MibSPIP_Master_Single_DMA.zip
