hello
now i have a problem i can't resolve.... I try to use SL_SelfTest_Flash.
When i try to call above function only one time. The test result is returned as ST_PASS
but, if i continuously call above function, The test results are always returned as ST_FAIL after first call.
i used USB Jtag debugger and monitoring register value changes at Esm1, Epc, and FlashWrapper.
and i can't find any difference. Just i can only monitor there is no esm signalling.
could you explain why is this phenomenon is generated?
thanks
